HermannSW
Debugging with SWD -- hello_world.elf missing
Wed Feb 03, 2021 6:14 am
I did start using SWD according instructions in chapter 5:
https://datasheets.raspberrypi.org/pico ... df#page=19
But when trying to actually debug I realized that hello_world.elf was missing:
pi@raspberrypi400:~/pico/pico-examples/build/hello_world $ ls -l
total 20
drwxr-xr-x 2 pi pi 4096 Feb  3 07:07 CMakeFiles
-rw-r--r-- 1 pi pi 1260 Feb  3 07:06 cmake_install.cmake
-rw-r--r-- 1 pi pi 4079 Feb  3 07:06 Makefile
drwxr-xr-x 3 pi pi 4096 Feb  3 07:07 serial
drwxr-xr-x 3 pi pi 4096 Feb  3 07:07 usb
pi@raspberrypi400:~/pico/pico-examples/build/hello_world $ find . -name "*.elf"
./usb/hello_usb.elf
./serial/hello_serial.elf
I did cd into usb folder and was successful in single stepping through hello_usb.elf.
But where is hello_world.elf?
I just upgraded to 1.0.1 SDK, not sure whether that has an effect or not.
I only soldered the 3 SWD pins for now:
GregAC
Re: Debugging with SWD -- hello_world.elf missing
Wed Feb 03, 2021 8:47 am
Think is just a typo, there's two versions of the binary one for serial, one for USB.
Probably one to report here: https://github.com/raspberrypi/pico-feedback/
Edit: Someone's already done it: https://github.com/raspberrypi/pico-feedback/issues/28 though they also need to mention hello_world.elf should be hello_serial.elf (or better yet note both are available and you can choose).
HermannSW
Wed Feb 03, 2021 10:10 am
Thanks, both are available, good that the issue was already raised.
Return to “SDK”
