I'm using a PS2 Eyetoy but it'll will probably work on any cam that streams mjpeg video.
I'm doing it on Debian squeeze with the latest kernel updated with rpi-update which supports many webcams including the PS2 Eyetoy.
First we need to install Netcat on RPi and the target linux machine where we are sending the video stream
sudo apt-get install netcat
sudo apt-get install mplayer
mkfifo a.mjpg
next on the target machine we run Netcat in listen udp mode on any port we want. I'm using port 5000 in this example
nc.traditional -lu -p 5000 > a.mjpg | mplayer -cache 32 -vo gl -demuxer lavf a.mjpg
sudo su
cat /dev/video0 | nc.traditional -u [YOUR TARGET IP HERE] 5000
That's it, the video on the target machine should start in a few seconds.
