I keep seeing this messages from kernel
[ 4.707542] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[ 4.898034] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[ 8.664510] mmcblk0: error -110 transferring data, sector 15277816, nr 8, cmd response 0x900, card status 0x200b00
[ 8.681209] mmcblk0: retrying using single block read
[ 11.376161] mmcblk0: error -110 transferring data, sector 15277816, nr 8, cmd response 0x900, card status 0x200b00
[ 11.393135] end_request: I/O error, dev mmcblk0, sector 15277816
[ 14.089132] mmcblk0: error -110 transferring data, sector 15277817, nr 7, cmd response 0x900, card status 0x200b00
[ 14.106436] end_request: I/O error, dev mmcblk0, sector 15277817
[ 16.802785] mmcblk0: error -110 transferring data, sector 15277818, nr 6, cmd response 0x900, card status 0x200b00
[ 16.821289] end_request: I/O error, dev mmcblk0, sector 15277818
[ 19.517612] mmcblk0: error -110 transferring data, sector 15277819, nr 5, cmd response 0x900, card status 0x200b00
[ 19.535258] end_request: I/O error, dev mmcblk0, sector 15277819
[ 22.231613] mmcblk0: error -110 transferring data, sector 15277820, nr 4, cmd response 0x900, card status 0x200b00
[ 22.249274] end_request: I/O error, dev mmcblk0, sector 15277820
[ 24.945598] mmcblk0: error -110 transferring data, sector 15277821, nr 3, cmd response 0x900, card status 0x200b00
[ 24.963489] end_request: I/O error, dev mmcblk0, sector 15277821
[ 27.659994] mmcblk0: error -110 transferring data, sector 15277822, nr 2, cmd response 0x900, card status 0x200b00
[ 27.677838] end_request: I/O error, dev mmcblk0, sector 15277822
[ 30.374316] mmcblk0: error -110 transferring data, sector 15277823, nr 1, cmd response 0x900, card status 0x200b00
[ 30.392102] end_request: I/O error, dev mmcblk0, sector 15277823
[ 30.401864] Buffer I/O error on device mmcblk0p2, logical block 1894367
[ 33.101094] mmcblk0: error -110 transferring data, sector 15277816, nr 8, cmd response 0x900, card status 0x200b00
[ 33.118848] mmcblk0: retrying using single block read
[ 35.814356] mmcblk0: error -110 transferring data, sector 15277816, nr 8, cmd response 0x900, card status 0x200b00
[ 35.832131] end_request: I/O error, dev mmcblk0, sector 15277816
[ 38.528579] mmcblk0: error -110 transferring data, sector 15277817, nr 7, cmd response 0x900, card status 0x200b00
[ 38.546324] end_request: I/O error, dev mmcblk0, sector 15277817
[ 41.242753] mmcblk0: error -110 transferring data, sector 15277818, nr 6, cmd response 0x900, card status 0x200b00
[ 41.260453] end_request: I/O error, dev mmcblk0, sector 15277818
[ 43.956844] mmcblk0: error -110 transferring data, sector 15277819, nr 5, cmd response 0x900, card status 0x200b00
[ 43.974584] end_request: I/O error, dev mmcblk0, sector 15277819
[ 46.670993] mmcblk0: error -110 transferring data, sector 15277820, nr 4, cmd response 0x900, card status 0x200b00
[ 46.688734] end_request: I/O error, dev mmcblk0, sector 15277820
[ 49.386170] mmcblk0: error -110 transferring data, sector 15277821, nr 3, cmd response 0x900, card status 0x200b00
[ 49.403919] end_request: I/O error, dev mmcblk0, sector 15277821
[ 52.101469] mmcblk0: error -110 transferring data, sector 15277822, nr 2, cmd response 0x900, card status 0x200b00
[ 52.119180] end_request: I/O error, dev mmcblk0, sector 15277822
[ 54.815592] mmcblk0: error -110 transferring data, sector 15277823, nr 1, cmd response 0x900, card status 0x200b00
[ 54.833356] end_request: I/O error, dev mmcblk0, sector 15277823
[ 54.843109] Buffer I/O error on device mmcblk0p2, logical block 1894367
[ 66.260780] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 66.680535] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 67.468376] bcm2835 ALSA card created!
Unfortunately those messages speared again. Also when I plug the card into my laptop I get similar ones.
What could it be? Is my card broken? It's fairly new 8 GB Kingston class 4 card. I didn't use it that much.
Is there some way to test for 'badblocks'. I'm not sure if badblocks actually makes sense for SD card.
