I also have tearing isses with the Pi 4.
I want to use the Pi 4 as a Media Center for my dads TV with KODI + a Browser, so tearing is a big issue.
I already tried most potential fixes without getting completely rid of the problem.
Is there any news of a reliable fix for this issues?
Please help!
Cheers,
Christian
Here my specs:
pi@raspberrypi:~ $ lsb_release -irdc
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
pi@raspberrypi:~ $ uname -r
5.4.83-v7l+
pi@raspberrypi:~ $ cat /sys/firmware/devicetree/base/model
Raspberry Pi 4 Model B Rev 1.4
pi@raspberrypi:~ $ /opt/vc/bin/vcgencmd version
Jan 8 2021 14:31:16
Copyright (c) 2012 Broadcom
version 194a85abd768c7334bbadc3f1911c10a7d18ed14 (clean) (release) (start)
pi@raspberrypi:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
gpu_mem=128
pi@raspberrypi:~ $ vcgencmd version
Jan 8 2021 14:31:16
pi@raspberrypi:~ $ vcgencmd get_config int
arm_freq=1500
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
disable_overscan=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
init_uart_clock=0x2dc6c00
lcd_framerate=60
mask_gpu_interrupt0=1024
mask_gpu_interrupt1=0x10000
max_framebuffers=2
over_voltage_avs=-20000
pause_burst_frames=1
program_serial_random=1
total_mem=8192
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
