Always booting in safe mode
Hi. My raspberry pi is always booting in safe mode. I've tried formatting the card and wrote the image again but it remains the same. When adding "avoid_safe_mode=1" to the "config.txt" it boots normally but the GPIOs won't work! I am running Raspbian and nothing is attached on the GPIOs nor in the USB port. Please I want to know what exactly is causing it to boot into safemode. HELP!
Re: Always booting in safe mode
Is this a brand new Raspberry Pi or have you used it in the past and possibly damaged the GPIO?
- mahjongg
- Forum Moderator
Raspbian will boot into safe mode when during booting it detects that pin 5 of the GPIO header (which has a pull-up to 3V3, so should be high) is low.
Yes, so if it is a brand new Raspberry PI you should be able to get it replaced because it would appear to be faulty. If you have been experimenting with the GPIO then you will probably need to replace the Raspberry Pi if you want to do something with the GPIO.mahjongg wrote:Raspbian will boot into safe mode when during booting it detects that pin 5 of the GPIO header (which has a pull-up to 3V3, so should be high) is low.
I also have a pi booting into safe mode, but I think I may have damaged the GPIO - is it possible to repair it? Even some sort of hack?AndyD wrote:Is this a brand new Raspberry Pi or have you used it in the past and possibly damaged the GPIO?
simonmcc.blogspot.com/search/label/pi
- mahjongg
- Forum Moderator
very unlikely, if you have a defect that shorts the pin to GND. Still, you can disable the safe mode pin check using config.txt.simonmcc wrote:I also have a pi booting into safe mode, but I think I may have damaged the GPIO - is it possible to repair it? Even some sort of hack?AndyD wrote:Is this a brand new Raspberry Pi or have you used it in the past and possibly damaged the GPIO?
With the config.txt change to disable safe mode it still boots into safe modemahjongg wrote:very unlikely, if you have a defect that shorts the pin to GND. Still, you can disable the safe mode pin check using config.txt.simonmcc wrote:I also have a pi booting into safe mode, but I think I may have damaged the GPIO - is it possible to repair it? Even some sort of hack?AndyD wrote:Is this a brand new Raspberry Pi or have you used it in the past and possibly damaged the GPIO?
How can I get file config.txt??
I have the same problem.
Pi always boot in safety mode and I can't acces to GPIO on P1.
I have a rev2 and try on P5, that's work good.
Have you got solution?
I want to use DS18B20 which need to be connect on pin 7 on P1,
Is'it able to modifi WIrinPi to use a pin on P5 instead of pin 7 on P1 ?
it is in the /boot partition - which you see if you pop the SD card into a windows pc. You can edit the config.txt file there, just add avoid_safe_mode=1 into the command linestang wrote:How can I get file config.txt??
Hey
I have been working with Pi for quite a while now and i have hit a dead end
My Problem:
I booted the Pi with some connections to the GPIO pins
This caused it to enter safe mode while booting
I edited the config.txt to ignore safe mode
The GPIO pins are not working thereafter
I have gone through the discussion and I am made to believe that I have to replace my Pi
Can anyone tell me what exactly happened that caused my Pi to enter safe mode
and is there any solution to get my GPIO's breathing again
Thank U
Pi rocks
My Problem:
Thank U
Pi rocks
