Re: 8000 interrupts per second when idle!
We have the FIQ patch working on the 2.91 USB driver. Something in the update to 2.94 broke it.
We've got someone investigating.
dom wrote:We have the FIQ patch working on the 2.91 USB driver. Something in the update to 2.94 broke it.
Is there any progress with this patch?
Bank holiday weekend in the UK - so probably not much work done the last three days. Patience is required!
Oki
I am patient. Oki
I am patient. I just asked...
Does someone still working on this patch to port it to the new driver?
Good news. Costas (one of our interns) found the problem earlier today. I'm just testing, and if it looks good will push it out tomorrow.samsamsam wrote:Hello,
Looks to give about 10% performance boost to the Pi, without the side effects of the SOF patch.
FIQ patch is pushed. Get it from rpi-update. It is disabled by default, but add:
dwc_otg.fiq_fix_enable=1
to cmdline.txt to test. It should give about 10% extra performance to ARM when USB is not busy. It shouldn't change behaviour of USB.
Super news
I am going to test this patch
Thank you very much!
You can check the number of interrupts per second with and without this patch with:
You should get 8000+ when the patch is disabled.
You should get 600+ when the patch is enabled. This will vary based on USB devices connected and how busy they are. When USB is running flat out you may see 8000+.
sh -c "cat /proc/interrupts | grep dwc && sleep 10 && cat /proc/interrupts | grep dwc" | awk '{ if (s==0) s=$2 } END { print ($2-s)/10 }'
Thanks for info.
I will test this patch tonight, however without patch I get:
Is it possible? I use network and 4 ftdiToRs232 converters and 1GB pendrive with root partition.
vmstat give me similar results
root@raspberry-pi:/etc/oscam# sh -c "cat /proc/interrupts | grep dwc && sleep 10 && cat /proc/interrupts | grep dwc" | awk '{ if (s==0) s=$2 } END { print ($2-s)/10 }'
3564
root@raspberry-pi:/etc/oscam# vmstat
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
r b swpd free buff cache si so bi bo in cs us sy id wa
0 0 0 205592 3880 17240 0 0 0 0 3742 161 1 1 95 2
I don't think so. You haven't enabled SOF reduction have you?samsamsam wrote: Is it possible? I use network and 4 ftdiToRs232 converters and 1GB pendrive with root partition.
Is it any different with the USB devices unplugged?
My command line:
Maybe it is related to parameter dwc_otg.speed=1 or smsc95xx.turbo_mode=N? I can not test what happens when I unplug device now but tonight I will test this also.
I must use dwc_otg.speed=1 because without this my FTDI devices always restart. It is probably similar problem to the: http://www.mail-archive.com/linux-usb-u ... 14694.html
Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xec6c4cc5 smsc95xx.macaddr=B8:27:EB:6C:4C:C5 dwc_otg.microframe_schedule=1 smsc95xx.turbo_mode=N sdhci-bcm2708.missing_status=0 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda1 rootfstype=ext4 rootwait dwc_otg.speed=1
Yes, dwc_otg.speed=1 limits speed to full speed (rather than USB 2's high speed) protocol, and so only 1000 interrupts/sec when idle.samsamsam wrote:My command line:Maybe it is related to parameter dwc_otg.speed=1 or smsc95xx.turbo_mode=N? I can not test what happens when I unplug device now but tonight I will test this also.Code: Select all
This patch will have much less benefit if you are using dwc_otg.speed=1.
Yes I know
However I think that the patch will make my RPI more stable. Although right now my RPI is very stable after night battles
OFFTOP
What do you think can I restore the root partition on SD card since the patch: "low-latency mode to sdcard driver"?
If yes what value should be set for the parameter sdhci-bcm2708.missing_status?
OFFTOP
sdhci-bcm2708.missing_status is not recommended now, just leave it off command line. The sdhci-bcm2708.enable_llm is now enabled by default and fixes the USB latency problem caused by sdcard a safer way.samsamsam wrote:What do you think can I restore the root partition on SD card since the patch: "low-latency mode to sdcard driver"?
Thank you very much for your help:) I will move my root partition to the SD and test these two patches:)
Thanks once again
Thanks once again
Stats with new kernel and root partition moved to SD card:
So far, the system is stable
root@raspberry-pi:~# vmstat
0 0 0 179380 27148 17624 0 0 0 0 3316 141 2 2 93 4
Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xec6c4cc5 smsc95xx.macaddr=B8:27:EB:6C:4C:C5 dwc_otg.microframe_schedule=1 smsc95xx.turbo_mode=N dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait dwc_otg.speed=1
Not working for me, getting a kp at boot (details: http://i.imgur.com/PfJG0.jpg). I ran rpi-update. cmdline.txt is containing : dwc_otg.fiq_fix_enable=1. Kernel: 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l.
Looks like it can't find rootfs. Is your rootfs on sdcard, or are you using nfs/usb?Koenkk wrote:Not working for me, getting a kp at boot (details: http://i.imgur.com/PfJG0.jpg). I ran rpi-update. cmdline.txt is containing : dwc_otg.fiq_fix_enable=1. Kernel: 3.2.27+ #102 PREEMPT Sat Sep 1 01:00:50 BST 2012 armv6l.
Does dwc_otg.fiq_fix_enable=0 allow it to boot? Does reverting kernel allow it to boot?
cmdline.txt should contain at least:
working, thanks for this uber fast response!!samsamsam wrote:cmdline.txt should contain at least:Code: Select all
Updated firmware with rip-update set the cmdline option, and after some time my headless system becomes inaccessible with the following error in /var/log/messages:FIQ patch is pushed. Get it from rpi-update. It is disabled by default, but add:
Sep 2 14:37:34 raspi kernel: [ 8406.167322] smsc95xx 1-1.1:1.0: eth0: Failed to w
rite HW_CFG_LRST_ bit in HW_CFG register, ret = -110
Sep 2 14:37:40 raspi kernel: [ 8412.167492] smsc95xx 1-1.1:1.0: eth0: Failed to w
rite register index 0x00000014
(repeated many times)
cmdline.txt:
dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait sdhci-bcm2708.sync_after_dma=0 dwc_otg.microframe_schedule=1 dwc_otg.fiq_fix_enable=1
Also interupts per seconds is 44K! like normally on my system using pl2303 usb to rs232 converter reading serial output from small measurement system.
You can try to add lineat the and of file /etc/sysctl.conf
And add parameter smsc95xx.turbo_mode=N to the cmdline.txt
vm.min_free_kbytes = 16384
If you change to dwc_otg.fiq_fix_enable=0 does the problem go away?rtramon wrote: Sep 2 14:37:34 raspi kernel: [ 8406.167322] smsc95xx 1-1.1:1.0: eth0: Failed to w
cmdline.txt:
If you change to dwc_otg.microframe_schedule=0 does the problem go away?
I applied the patch and in my case (nothing attached to USB) interrupts went from 8000+ to 290.
Question: is there any known 'side effect' to this FIQ patch, or any conditions where it may not be convenient to activate it?
