Re: Pi4 64-bit raspbian kernel for testing - Focus on Pi4
Both kernels (4.19.x and 5.4.x) have changed how the on-board sound module is loaded (snd_bcm2835), resulting in a sightly different ALSA configuration. Use raspi-config to configure your sound output and it should work afterwards.
- mahjongg
- Forum Moderator
now locking this thread, so there will be just one thread for developers to follow.
Re: Pi4 64-bit raspbian kernel for testing - Focus on Pi4 [now defunct thread]
Unlocking as this thread is still useful for reporting issues with the 64-bit kernel unrelated to PiOS64.
The users here are mostly running a 32-bit buster image with just the kernel updated to 64-bit and it's
useful to note regressions when switching between 32 and 64-bit kernels. (Something not possible on PiOS64).
- mahjongg
- Forum Moderator
agreed, I was already wondering if that would be the case....
Possibly, like this one...
Pi 4, 2G:
arm_64bit=1
gpu_mem=256
dtoverlay=vc4-fkms-v3d
omxplayer, as root, playing H.264:
OTOH, as an unprivved user, it works fine. Not convinced that should happen, even so. Did an rpi-update at about 1730, so running whatever was current then.
Pi 4, 2G:
arm_64bit=1
gpu_mem=256
pi4 login: [ 352.850885] Unable to handle kernel paging request at virtual address ffffff7fb0170e40
[ 352.858976] Mem abort info:
[ 352.861815] ESR = 0x96000144
[ 352.864936] EC = 0x25: DABT (current EL), IL = 32 bits
[ 352.870354] SET = 0, FnV = 0
[ 352.873459] EA = 0, S1PTW = 0
[ 352.876665] Data abort info:
[ 352.879606] ISV = 0, ISS = 0x00000144
[ 352.883520] CM = 1, WnR = 1
[ 352.886548] [ffffff7fb0170e40] address between user and kernel address ranges
[ 352.893822] Internal error: Oops: 96000144 [#1] PREEMPT SMP
[ 352.899490] Modules linked in: aes_neon_blk crypto_simd cryptd bnep rpcsec_gss_krb5 evdev v3d gpu_sched raspberrypi_hwmon vc4 cec bcm2835_v4l2(C) videobuf2_vmalloc bcm2835_isp(C) drm_kms_helper drm drm_panel_orientation_quirks w1_gpio snd_soc_core snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops uio_pdrv_genirq uio rpivid_mem snd_bcm2835(C) snd_pcm snd_timer binfmt_misc snd bcm2835_codec(C) videobuf2_dma_contig v4l2_mem2mem bcm2835_mmal_vchiq(C) videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc brcmfmac brcmutil sha256_generic libsha256 cfg80211 8021q garp hci_uart btbcm serdev bluetooth ecdh_generic ecc rfkill vc_sm_cma(C) w1_therm wire cn ip_tables x_tables bridge stp llc ipv6 nf_defrag_ipv6
[ 352.965494] CPU: 2 PID: 85 Comm: vchiq-slot/0 Tainted: G C 5.4.44-v8+ #1320
[ 352.973899] Hardware name: Raspberry Pi 4 Model B Rev 1.1 (DT)
[ 352.979827] pstate: 00000005 (nzcv daif -PAN -UAO)
[ 352.984704] pc : __dma_inv_area+0x28/0x58
[ 352.988777] lr : arch_sync_dma_for_cpu+0x3c/0x50
[ 352.993467] sp : ffffffc011c63bd0
[ 352.996832] x29: ffffffc011c63bd0 x28: ffffffc010eff130
[ 353.002230] x27: ffffff807b551c00 x26: ffffffc0112d3000
[ 353.007628] x25: ffffffc0112d300c x24: 0000000000000002
[ 353.013027] x23: 0000000000000002 x22: 000000000000021c
[ 353.018424] x21: 0000000000000002 x20: 000000000000021c
[ 353.023823] x19: ffffffffb0170c60 x18: 0000000000000000
[ 353.029221] x17: 0000000000000000 x16: 0000000000000000
[ 353.034618] x15: 0000000000000000 x14: 0000000000000000
[ 353.040016] x13: 0000000000000000 x12: 0000000000000000
[ 353.045414] x11: 0000000000000000 x10: 0000000000001980
[ 353.050812] x9 : ffffff807b551c68 x8 : ffffff807cd15560
[ 353.056210] x7 : 0000000000000001 x6 : 000000000000021c
[ 353.061607] x5 : 0000000000000001 x4 : 0000000000000000
[ 353.067005] x3 : 000000000000003f x2 : 0000000000000040
[ 353.072403] x1 : ffffff7fb0170e40 x0 : ffffff7fb0170c60
[ 353.077801] Call trace:
[ 353.080284] __dma_inv_area+0x28/0x58
[ 353.084005] dma_direct_sync_single_for_cpu+0x9c/0xa0
[ 353.089139] dma_direct_unmap_page+0xa4/0xa8
[ 353.095954] dma_direct_unmap_sg+0x58/0x80
[ 353.102547] vchiq_complete_bulk+0xb0/0x278
[ 353.109247] slot_handler_func+0xf6c/0x1580
[ 353.115942] kthread+0xfc/0x128
[ 353.121581] ret_from_fork+0x10/0x1c
[ 353.127652] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21)
[ 353.136299] ---[ end trace 119a545d2f9256d7 ]---
There was a fix to vchi yesterday for a dma_unmap_sg being done against the wrong device. It may not have made it to rpi-update as yet.dickon wrote: ↑Fri Jun 05, 2020 5:45 pmPossibly, like this one...
Pi 4, 2G:
arm_64bit=1
gpu_mem=256
OTOH, as an unprivved user, it works fine. Not convinced that should happen, even so. Did an rpi-update at about 1730, so running whatever was current then.Code: Select all
pi4 login: [ 352.850885] Unable to handle kernel paging request at virtual address ffffff7fb0170e40 [ 352.858976] Mem abort info: [ 352.861815] ESR = 0x96000144 [ 352.864936] EC = 0x25: DABT (current EL), IL = 32 bits [ 352.870354] SET = 0, FnV = 0 [ 352.873459] EA = 0, S1PTW = 0 [ 352.876665] Data abort info: [ 352.879606] ISV = 0, ISS = 0x00000144 [ 352.883520] CM = 1, WnR = 1 [ 352.886548] [ffffff7fb0170e40] address between user and kernel address ranges [ 352.893822] Internal error: Oops: 96000144 [#1] PREEMPT SMP [ 352.899490] Modules linked in: aes_neon_blk crypto_simd cryptd bnep rpcsec_gss_krb5 evdev v3d gpu_sched raspberrypi_hwmon vc4 cec bcm2835_v4l2(C) videobuf2_vmalloc bcm2835_isp(C) drm_kms_helper drm drm_panel_orientation_quirks w1_gpio snd_soc_core snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops uio_pdrv_genirq uio rpivid_mem snd_bcm2835(C) snd_pcm snd_timer binfmt_misc snd bcm2835_codec(C) videobuf2_dma_contig v4l2_mem2mem bcm2835_mmal_vchiq(C) videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc brcmfmac brcmutil sha256_generic libsha256 cfg80211 8021q garp hci_uart btbcm serdev bluetooth ecdh_generic ecc rfkill vc_sm_cma(C) w1_therm wire cn ip_tables x_tables bridge stp llc ipv6 nf_defrag_ipv6 [ 352.965494] CPU: 2 PID: 85 Comm: vchiq-slot/0 Tainted: G C 5.4.44-v8+ #1320 [ 352.973899] Hardware name: Raspberry Pi 4 Model B Rev 1.1 (DT) [ 352.979827] pstate: 00000005 (nzcv daif -PAN -UAO) [ 352.984704] pc : __dma_inv_area+0x28/0x58 [ 352.988777] lr : arch_sync_dma_for_cpu+0x3c/0x50 [ 352.993467] sp : ffffffc011c63bd0 [ 352.996832] x29: ffffffc011c63bd0 x28: ffffffc010eff130 [ 353.002230] x27: ffffff807b551c00 x26: ffffffc0112d3000 [ 353.007628] x25: ffffffc0112d300c x24: 0000000000000002 [ 353.013027] x23: 0000000000000002 x22: 000000000000021c [ 353.018424] x21: 0000000000000002 x20: 000000000000021c [ 353.023823] x19: ffffffffb0170c60 x18: 0000000000000000 [ 353.029221] x17: 0000000000000000 x16: 0000000000000000 [ 353.034618] x15: 0000000000000000 x14: 0000000000000000 [ 353.040016] x13: 0000000000000000 x12: 0000000000000000 [ 353.045414] x11: 0000000000000000 x10: 0000000000001980 [ 353.050812] x9 : ffffff807b551c68 x8 : ffffff807cd15560 [ 353.056210] x7 : 0000000000000001 x6 : 000000000000021c [ 353.061607] x5 : 0000000000000001 x4 : 0000000000000000 [ 353.067005] x3 : 000000000000003f x2 : 0000000000000040 [ 353.072403] x1 : ffffff7fb0170e40 x0 : ffffff7fb0170c60 [ 353.077801] Call trace: [ 353.080284] __dma_inv_area+0x28/0x58 [ 353.084005] dma_direct_sync_single_for_cpu+0x9c/0xa0 [ 353.089139] dma_direct_unmap_page+0xa4/0xa8 [ 353.095954] dma_direct_unmap_sg+0x58/0x80 [ 353.102547] vchiq_complete_bulk+0xb0/0x278 [ 353.109247] slot_handler_func+0xf6c/0x1580 [ 353.115942] kthread+0xfc/0x128 [ 353.121581] ret_from_fork+0x10/0x1c [ 353.127652] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21) [ 353.136299] ---[ end trace 119a545d2f9256d7 ]---
Ta.
It isn't an issue -- works fine as a normal user, which is a bit surprising -- but thought I'd mention it.
I'm trying to run docker on the 32-bit Raspbian with 64-bit Kernel. Unlike the other 32-bit Raspbian with 32-bit kernel, when I try:
The running container is exited promtly, normally within 3 seconds.
This happens ONLY on this 64bit kernel Raspberry Pi4.
Did anybody have the same issue?
Cheers
pi@pi01:~ $ docker run -it -d arm64v8/alpine
ccda6c95f81de8ac3bdb1aff69ac0a7e0059fc21f6b57206e8bb004d1e87ef5c
pi@pi01:~ $ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ccda6c95f81d arm64v8/alpine "/bin/sh" 9 seconds ago Exited (159) 3 seconds ago nifty_gates
Cheers
Welcome to Vision Open
http://www.visionopen.com
It looks with this P4 64-bit Kernel, raspistill and raspivid don't work properly. Even **^C** and **^Z** won't be able to halt the camera application. Did anybody meet the same issue?
pi@pi01:~ $ raspistill -o cam.jpg
Message from syslogd@pi01 at Jun 10 17:45:42 ...
kernel:[ 236.233099] Internal error: Oops: 96000144 [#1] PREEMPT SMP
kernel:[ 236.233916] Code: d1000443 ea03003f 8a230021 54000040 (d50b7e21)
^Cmmal: Aborting program
^C^C^C^C^C^Z^Z^Z^Z^Z
try uninstalling pulseaudio, that solved it for metrabant wrote: ↑Thu Jun 04, 2020 6:48 amCurrently I am running the regular 4.19.97 kernel (as v8+ in 64bit mode) and everything works fine, as in 32bit mode. If I do an apt upgrade to the recently released 4.19.118 kernel video works fine, but analog audio is dead and I can't get it work again, despite numerous experiments. This applies to both 32 and 64 bit mode.
After
and after adding
in config.txt, and after reboot (also hard reboot), i cant connect with Putty and FTP anymore. HDMI also outputs nothing. Any fix to this?
sudo rpi-update
arm_64bit=1
If you remove arm_64bit=1 (e.g. using a PC with sdcard reader) does it boot?user238424 wrote: ↑Sun Jun 14, 2020 1:59 pmin config.txt, and after reboot (also hard reboot), i cant connect with Putty and FTP anymore. HDMI also outputs nothing. Any fix to this?
There is no mmal camera or video acceleration support currently. Only v4l2 is working with 64-bit. raspivid/raspistill uses mmal.
That worked, thanks a lot. By the way, that happened on Model 3b.dom wrote: ↑Mon Jun 15, 2020 9:52 amIf you remove arm_64bit=1 (e.g. using a PC with sdcard reader) does it boot?user238424 wrote: ↑Sun Jun 14, 2020 1:59 pmin config.txt, and after reboot (also hard reboot), i cant connect with Putty and FTP anymore. HDMI also outputs nothing. Any fix to this?
Maybe you missed the topic title:user238424 wrote: ↑Mon Jun 15, 2020 4:36 pmThat worked, thanks a lot. By the way, that happened on Model 3b.dom wrote: ↑Mon Jun 15, 2020 9:52 amIf you remove arm_64bit=1 (e.g. using a PC with sdcard reader) does it boot?user238424 wrote: ↑Sun Jun 14, 2020 1:59 pmin config.txt, and after reboot (also hard reboot), i cant connect with Putty and FTP anymore. HDMI also outputs nothing. Any fix to this?
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
It is still a little surprising that the VC bootloader will happily attempt to boot an aarch64 kernel on its 32b-only ARMs, on older Pis. Got bitten by that one myself.
how do i go back to 32-bit? having issues with linux headers
- bizzymizzyb
i'm getting this error when trying to run gadmin-openvpn-client though I'm uncertain whether or not its due to the 64-bit kernel.
Starting program: /usr/sbin/gadmin-openvpn-client
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[Detaching after fork from child process 27390]
Program received signal SIGSEGV, Segmentation fault.
0xf7fac1dc in strlen () from /usr/lib/arm-linux-gnueabihf/libarmmem-v8l.so
Are you using 32-bit raspbian usespace with 64-bit kernel enabled as described in this thread?bizzymizzyb wrote: ↑Thu Jun 25, 2020 9:16 ami'm getting this error when trying to run gadmin-openvpn-client though I'm uncertain whether or not its due to the 64-bit kernel.
If so just remove arm_64bit=1 from config.txt, reboot and check if issue still happens.
- bizzymizzyb
ahhhh... that's too easy - why not run GDB on it and see exactly where the error occurs?dom wrote: ↑Thu Jun 25, 2020 11:08 amAre you using 32-bit raspbian usespace with 64-bit kernel enabled as described in this thread?bizzymizzyb wrote: ↑Thu Jun 25, 2020 9:16 ami'm getting this error when trying to run gadmin-openvpn-client though I'm uncertain whether or not its due to the 64-bit kernel.
look at that uptime- 12 days - this system is solid as a rock. i'm not taking this baby down because of some silly, contained seg fault preventing me from running gtk config of openvpn ; the command-line version works.
But on a more serious note, there may be an issue with /usr/lib/arm-linux-gnueabihf/libarmmem-v8l.so running in 64-bit. I've never coded arm assmebly but looking at it:
0xf7fac1c0 <+0>: push {r4, lr}
0xf7fac1c4 <+4>: mov r1, r0
0xf7fac1c8 <+8>: tst r0, #248, 30 ; 0x3e0
0xf7fac1cc <+12>: tst r0, #7
0xf7fac1d0 <+16>: bne 0xf7fac24c <strlen+140>
0xf7fac1d4 <+20>: bics r3, r2, r0
0xf7fac1d8 <+24>: beq 0xf7fac24c <strlen+140>
=> 0xf7fac1dc <+28>: vld1.8 {d0-d1}, [r0 :64]!
0xf7fac1e0 <+32>: bics r3, r2, r0
0xf7fac1e4 <+36>: beq 0xf7fac220 <strlen+96>
0xf7fac1e8 <+40>: vceq.i8 d0, d0, #0
0xf7fac1ec <+44>: vceq.i8 d1, d1, #0
0xf7fac1f0 <+48>: vmov r3, s0
0xf7fac1f4 <+52>: vmov r4, s1
0xf7fac1f8 <+56>: vmov r12, s2
0xf7fac1fc <+60>: vmov lr, s3
0xf7fac200 <+64>: teq r3, #0
0xf7fac204 <+68>: teqeq r4, #0
0xf7fac208 <+72>: teqeq r12, #0
0xf7fac20c <+76>: teqeq lr, #0
0xf7fac210 <+80>: bne 0xf7fac2d0 <strlen+272>
0xf7fac214 <+84>: vld1.8 {d0-d1}, [r0 :64]!
r0 0x0 0
r1 0x0 0
r2 0xff8 4088
r3 0xff8 4088
r4 0x7fa338 8364856
r5 0x0 0
r6 0x851d60 8723808
r7 0x798ea0 7966368
r8 0x45d100 4575488
r9 0x7f85f8 8357368
r10 0x424c50 4344912
r11 0x0 0
r12 0x424edc 4345564
sp 0xfffef560 0xfffef560
lr 0x40d548 4248904
pc 0xf7fac1dc 0xf7fac1dc <strlen+28>
cpsr 0x20000010 536870928
d0 {u8 = {0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff}, u16 = {0x0, 0x0, 0x0, 0xff00}, u32 = {0x0, 0xff000000}, u64 = 0xff00000000000000, f32 = {0x0, 0x0}, f64 = 0x8000000000000000}
d1 {u8 = {0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, u16 = {0xffff, 0xffff, 0xffff, 0xffff}, u32 = {0xffffffff, 0xffffffff}, u64 = 0xffffffffffffffff, f32 = {0x0, 0x0}, f64 = 0x0}
libarmmem*.so is just an accelerated set of memset/memcpy style functions.
You can disable it by commenting out
from /etc/ld.so.preload and then run "sudo ldconfig"
If it still crashes (but now libc) then it's the application at fault (presumably passing in a NULL or otherwise duff pointer).
If it works then there's a bug in libarmmem.
/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so
- bizzymizzyb
still crashes
guess the problem is in gadmin-openvpn-client, same null value in r0
surprised no one noticed it before. As I recall, the KDE openvpn config was giving a segfault as well but I didn't investigate it.
[Detaching after fork from child process 25362]
strlen () at ../sysdeps/arm/armv6/strlen.S:26
26 ../sysdeps/arm/armv6/strlen.S: No such file or directory.
=> 0xf745f830 <+0>: ldrb r2, [r0]
0xf745f834 <+4>: and r3, r0, #7
0xf745f838 <+8>: mov r1, r0
0xf745f83c <+12>: rsb r3, r3, #15
0xf745f840 <+16>: cmp r2, #0
r0 0x0 0
r1 0x5 5
I know that this is an old post, but I wonder if we can apply this modification to the 64 bit raspberry OS to enable installing of mathematica? For my intended applications having 64 bit OS could be useful, but I need mathematica as well.dom wrote: ↑Wed Sep 04, 2019 1:18 pmIf you are daring, edit /opt/Wolfram/WolframEngine/12.0/Executables/mathematica
find lines:and add after:Code: Select all
armv?l) SystemIDList="Linux-ARM";;
You can also make a comparable change to /opt/Wolfram/WolframEngine/12.0/Executables/wolframCode: Select all
aarch64) SystemIDList="Linux-ARM";;
My pi has not yet arrived so I can't test this myself. Many thanks for your help!
