I found a solution to have a high res and good frame rate with motion !!!!!!!
For that simply install mjpeg-streamer (that will give you good res + great frame rate) and tell to motion to use it instead of using /dev/video
More info here
http://www.lavrsen.dk/foswiki/bin/view/ ... pgStreamer
I am able to detect motion on video of 1280x720 at 15 fps.
Hope it helps
Re: Motion low framerate and resolution... not any more...
Thanks a lot! Thia actually works. I have tried very many ways of getting god quality high resolution video, but this is the first that works!
I had to compile it myself usign instructions in http://www.raspberrypi.org/phpBB3/viewt ... p?p=164539.
And I had to add parameter -y to the input. Usefull command (I use local install so ./ is needed):
./mjpg_streamer -i "./input_uvc.so --help"
I am using command line
./mjpg_streamer -i "./input_uvc.so -y -d /dev/video0 -r 640x480 -f 10 -q 100 -n" -o "./output_http.so"
And that uses about 95% CPU in my turbo (arm_freq=1000) overclocked RPi. But it works ! The picture quality is good.
