Jerd
Prevent Joystick.get_button output?
Sun Sep 30, 2012 8:42 pm
Hi!
I want to create a small "text menu" in which i want to select item with only a gamepad connected. To do this, i thought it would be a great idea to use the pygame's Joystick module, but i keep running into a problem due to some sort of debug mode? this code:
jb = j.get_button(1)
Outputs a "print" on the screen:
SDL_JoystickGetButton value:1
SDL_JoystickGetButton value:0
Is there any (easy, for a newbie like me) solution to fix this?
Best regards /Jon
toxibunny
Re: Prevent Joystick.get_button output?
Sun Sep 30, 2012 11:13 pm
I posted on the forum about 'evdev.py' which might be of help, possibly...
nhsa
Sat Oct 06, 2012 5:49 pm
Hi Jerd,
I've come across this issue with some code I wrote and did some digging as to why it was doing it.
Apparently when pygame v1.9.1 was released, a few lines of debug code was left in. This is what you are seeing.
See http://archives.seul.org/pygame/users/A ... 00110.html
The reason, but not a solution. I'm hoping that one day typing
sudo apt-get install python-pygame
will update to a new version of pygame where this debug code has been removed.
Cheers
Nige
Christoph1985
Thu Mar 07, 2013 6:37 pm
Any solutions for this problem available now?
elektronx.de
Neil Munday
Tue Mar 18, 2014 8:57 pm
Hi all,
I too experienced the same annoying SDL debug statements and after much searching for a solution I decided to build pygame from source myself and patch the offending file (joystick.c).
Here is a BASH script that should do the trick.
I thought I'd share it here in case it helps anyone else out.
The script assumes that you have the gcc compiler, Make etc. installed.
Cheers,
Neil.
#!/bin/bash
# Build script for pygame 1.9 under Raspbian by Neil Munday (www.mundayweb.com)
# March 2014
buildDir=`pwd`/pygame-build
pygameDir=$buildDir/pygame-1.9.1release
echo "Removing system installed pygame..."
sudo apt-get remove python-pygame
echo "Installing dependencies..."
sudo apt-get install libv4l-dev mercurial python-dev python-numpy ffmpeg libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsmpeg-dev libsdl1.2-dev libportmidi-dev libswscale-dev libavformat-dev libavcodec-dev
if [ ! -e /usr/include/linux/videodev.h ]; then
	if [ ! -e /usr/include/libv4l1-videodev.h ]; then
		echo "Error: /usr/include/libv4l1-videodev.h does not exist!"
		exit 1
	fi
	sudo ln -s /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
fi
mkdir -p $buildDir
cd $buildDir
if [ -e $pygameDir]; then
	echo "Removing previous pygame source"
	rm -rf $pygameDir
fi
echo "Downloading pygame source..."
wget http://www.pygame.org/ftp/pygame-1.9.1release.tar.gz
echo "Unpacking pygame source..."
tar xvfz pygame-1.9.1release.tar.gz
echo "Patching joystick.c ..."
cd pygame-1.9.1release
cp src/joystick.c src/joystick.c-orig
grep -v printf src/joystick.c-orig > src/joystick.c
echo "Building pygame (this will take some time!) ..."
python setup.py build
echo "Installing pygame..."
sudo python setup.py install
echo "Done!"
http://pes.mundayweb.com -> The Pi Entertainment System for all your gaming needs
Return to “Python”
