I've been looking primarily for a DAB radio adapter something to stream mp2 audio via the PI - http://www.ebay.co.uk/itm/R820T-ISDB-T- ... 0868189288
Does anyone know if such a device is supported on the PI and whether the DAB or FM radio is fully functional from within Linux??
Richard S.
Re: R820T DAB/FM/TV dongle??
The RTL2832U chipset is supported in Linux 3.6.8 for DVB-T. I've teste on a Desktop PC and not on the Pi.redhawk wrote:I've been looking primarily for a DAB radio adapter something to stream mp2 audio via the PI - http://www.ebay.co.uk/itm/R820T-ISDB-T- ... 0868189288
Richard S.
I've used one of these dongles as a SDR system with the suite gnuradio and gnuradio-companion, always on the desktop PC. I've tried to use gnuradio to decode DAB signals without sucess.
The dongle decodes dab radio with its windows 7 program.
For a working dongle is not enought the rtl2832u chip support, but also required for the other (rf tuner) chip inside.
I used rtl2832u+e4000 tuner with this driver:
https://github.com/ambrosa/DVB-Realtek- ... rnel-3.0.0
The new r820t - as i know - currently is not supported under linux. There is no driver for r820t radio chip in the current media tree:
http://git.linuxtv.org/media_tree.git/t ... dia/tuners
update:
i found a post with new driver sources, that contains r820t driver, too:
https://groups.google.com/forum/#!msg/u ... pqSRnYud4J
update:
From linux 3.10, kernels now include the r820t driver. You need a really recent one for it to work though. Not tested it on a Pi, but just trying it on a laptop. Ubuntu "mainline" kernel 3.10.1-031001-generic, for instance, has a Hz vs kHz error in the tuner code, but the latest linuxtv bundle fixed it for me.
I've had DVB-T working. just investigating DAB signals.
For just FM / ADS-B (planeplotter) stuff, you don't need kernel drivers (they need removing!).
I'd personally recommend "dump1090" if you want to do Mode-S / ADS-B stuff - it just seems to work.
David
David
