rtek1000
How to update system Date & Time from GPS Neo 6M [Python]
Thu Dec 15, 2016 9:19 pm
I've seen some idea to update the system clock from the GPS, but need an application that receives GPS data and send it to the NTP, then update the system clock.
This code below defines the system without any of this
Tested with Neo 6M GPS Module and Raspberry Pi B
(Python 2.7.9)
Note: this module already has RTC and a battery, you do not need to use DS1307 DS3231 etc.
This gps module tells the date and time in UTC, then the system will be set to UTC.
The system must be preconfigured with your location
Save code in file /home/pi/GPSupdate.py
To run:
$sudo python /home/pi/GPSupdate.py
Note: At interrupt this code with CTRL+C all applications python will stopped, see last lines (killall -9 python)
See:
http://www.gpsinformation.org/dale/nmea.htm#nmea
https://www.u-blox.com/en/evaluation-software-and-tools
https://www.u-blox.com/sites/default/fi ... 005%29.pdf
https://www.u-blox.com/sites/default/fi ... 018%29.pdf (Pag. 63/75: 20.10 RMC)
[RMC] Recommended Minimum data
Message Structure:
$GPRMC,hhmmss,status,latitude,N,longitude,E,spd,cog,ddmmyy,mv,mvE,mode*cs<CR><LF>
Example:
$GPRMC,083559.00,A,4717.11437,N,00833.91522,E,0.004,77.52,091202,,,A*57
Checksum at the end of each sentence: The checksum field consists of a '*' and two hex digits representing an 8 bit exclusive OR of all characters between, but not including, the '$' and '*'
# -*- coding: utf-8 -*-
import datetime
import serial  # http://pyserial.readthedocs.io/en/latest/pyserial.html
import time
from time import sleep
from threading import Thread
import os
import subprocess
import socket
#see http://www.gpsinformation.org/dale/nmea.htm#nmea
# DEVICE = '/dev/ttyUSB0'
DEVICE = '/dev/ttyAMA0'
DataBytes = ""
GpsUpdateInterval = 15  # minute
showGpsData = True
showUpdateMessage = True
def GpsDateTimeUpdate():
    global portRpi
    global DataBytes
    global showGpsData
    global showUpdateMessage
    global GpsUpdateInterval
    countTime = GpsUpdateInterval
    minuteOld = 0
    updateEnable = False
    while True:
        minuteNow = time.strftime("%M")
        if minuteOld != minuteNow:
            minuteOld = minuteNow
            countTime += 1
        if countTime > GpsUpdateInterval:
            countTime = 0
            updateEnable = True
            portRpi.reset_input_buffer()
        if updateEnable:
            if portRpi.isOpen():
                DataBytes = DataBytes + portRpi.read()
                if chr(13) in DataBytes:
                    if chr(10) in DataBytes:
                        DataBytes = DataBytes.replace(chr(10), "")
                        DataBytes = DataBytes.replace(chr(13), "")
                    list1 = DataBytes.split(',')
                    if (len(list1) == 13):
                        if((list1[0] == "$GPRMC") &
                        (len(list1[1]) == 9) &
                        (len(list1[9]) == 6)):
                            if(showGpsData):
                                print DataBytes
                                print
                            checksum = 0
                            for char in range(DataBytes.index('$') + 1,
                            DataBytes.index('*')):
                                checksum = (checksum ^ ord(DataBytes[char]))
                            list2 = list1[len(list1) - 1].split('*')
                            if len(list2) == 2:
                                if int(list2[1], 16) == checksum:
                                    hourGPS = int(list1[1][:2])
                                    minuteGPS = int(list1[1][2:4])
                                    secondGPS = int(list1[1][4:6])
                                    dayGPS = int(list1[9][:2])
                                    monthGPS = int(list1[9][2:4])
                                    yearGPS = int(list1[9][4:6])
                                    setDateTimeUTC(yearGPS,
                                                   monthGPS,
                                                   dayGPS,
                                                   hourGPS,
                                                   minuteGPS,
                                                   secondGPS)
                                    if showUpdateMessage:
                                        print 'GPS update now'
                                        if(list1[2] == "A"):
                                            print 'Satellite mode'
                                        else:
                                            print 'Local RTC mode'
                                        print
                    DataBytes = ""
        else:
            sleep(0.1)
def setDateTimeUTC2(seconds_epoch):
    command_wait('date -u -s "@' + str(seconds_epoch) + '"')
def setDateTimeUTC(year, month, day, hour, minute, second):
    strUTCyear2set = str(year)
    strUTCmonth2set = str(month)
    strUTCday2set = str(day)
    strUTChour2set = str(hour)
    strUTCminute2set = str(minute)
    strUTCsecond2set = str(second)
    if(len(strUTCyear2set) < 4):
        strUTCyear2set = str(year + 2000)
    if(len(strUTCmonth2set) < 2):
        strUTCmonth2set = '0' + strUTCmonth2set
    if(len(strUTCday2set) < 2):
        strUTCday2set = '0' + strUTCday2set
    if(len(strUTChour2set) < 2):
        strUTChour2set = '0' + strUTChour2set
    if(len(strUTCminute2set) < 2):
        strUTCminute2set = '0' + strUTCminute2set
    if(len(strUTCsecond2set) < 2):
        strUTCsecond2set = '0' + strUTCsecond2set
    command_wait('date -u +%Y%m%d -s "' + strUTCyear2set +
                                          strUTCmonth2set +
                                          strUTCday2set + '"')
    command_wait('date -u +%T -s "' + strUTChour2set + ':' +
                                      strUTCminute2set + ':' +
                                      strUTCsecond2set + '"')
    seconds_epoch = time.mktime(datetime.datetime.now().timetuple())
    seconds_epoch += 3
def command_wait(command):
    ## command = "sudo mount /dev/sda1 /mnt/usb"
    process = subprocess.Popen(command,
                               shell=True,
                               stdout=subprocess.PIPE)
    process.wait()
    if(process.returncode != 0):
        print 'command wait - error: '
        print process.returncode
def command_nowait(command):
    #process = subprocess.Popen(command,
    #                            shell=True,
    #                            stdout=subprocess.PIPE)
                     shell=True,
    ## process.wait()
    ## print process.returncode
def MyIP():
    print("IP: " + get_ip())
def get_ip():
    s = socket.socket(socket.AF_INET,
                      socket.SOCK_DGRAM)
    try:
        # doesn't even have to be reachable
        s.connect(('8.8.8.8', 0))
        IP = s.getsockname()[0]
    except:
        IP = '127.0.0.1'
    finally:
        s.close()
    return IP
    #command_wait("echo " + IP + " > /tmp/relogio.log")
if __name__ == '__main__':
    print 'Start update system DateTime from GPS'
    MyIP()
    print 'UTC: ' + str(datetime.datetime.utcnow())
    print 'Local: ' + str(datetime.datetime.now())
    print 'Test --> set UTC DateTime: 2016/01/01 12:00:00'
    setDateTimeUTC(2016, 1, 1, 12, 0, 0)
    if os.path.exists(DEVICE):
        try:
            portRpi = serial.Serial(DEVICE,
                                    timeout=None,
                                    baudrate=9600,
                                    xonxoff=False,
                                    rtscts=False,
                                    dsrdtr=False)
        except ValueError:
            print('Error: Serial Port')
    Thread1 = Thread(target=GpsDateTimeUpdate)
    Thread1.start()
    secondOld = 0
    while True:
        try:
            secondNow = time.strftime("%S")
            if secondOld != secondNow:
                secondOld = secondNow
                print
            sleep(0.1)
        except (KeyboardInterrupt, SystemExit):
            command_nowait("killall -9 python")
[for non commercial use only]
Using Ninja IDE to edit:
http://ninja-ide.org/
