FollowingGhosts
Webmin Guide
Fri May 18, 2012 2:25 pm
After losing this the first time round by closing the wrong tab, it's time for a Webmin guide.
This assumes you're running headless over SSH and want to be able to easily manage your Pi server with a GUI. Webmin is perfect for that job.
So, firstly let's get all the dependencies etc. out of the way.
We need to start by fixing user permissions then installing LAMP.
sudo groupadd -f -g33 www-data
sudo apt-get update
sudo apt-get install apache2 php5 libapache2-mod-php5
sudo apt-get install mysql-server mysql-client php5-mysql
sudo apt-get  install  phpmyadmin
sudo apt-get install perl libnet-ssleay-perl openssl libauthen-pam-perl libpam-runtime libio-pty-perl apt-show-versions python
When you're asked for a password, use something that isn't insecure but something you won't forget either. I just used my Pi password.
Now, we need to download the tar version of Webmin
All this does is make a new directory for the webmin source and then copies it and installs it to your Pi.
mkdir webmin
cd webmin
wget http://prdownloads.sourceforge.net/webadmin/webmin-1.580.tar.gz
gunzip webmin-1.580.tar.gz
tar xf webmin-1.580.tar
cd webmin-1.580
sudo ./setup.sh /usr/local/webmin
Note: I recommend not using pi and raspberry or anything similar when the installer prompts you, just for a little extra security. Also, SSL is personal preference, if you're only on a home network, SSL will just make the poor Pi work harder.
Now webmin is set up, just go to http://yourPiipaddress:10000 or whichever port you set.
Note: I take no credit for this guide, I used a LAMP install guide, with some information found on a Pi forum to fix an Apache groups issue, and then the webmin tar instructions. I just thought it would be worth sticking in one place.
Hope this helps someone.
damocov
Re: Webmin Guide
Tue May 29, 2012 10:42 pm
I had a few problems with the tar file method above, so I'd suggest for installs based on the the debian image , downloading the .deb file and installing with dpkg:
I.e. instead of the steps in your second box, do the following:
wget http://prdownloads.sourceforge.net/webadmin/webmin_1.580_all.deb
sudo dpkg --install webmin_1.580_all.deb
mintz
Re: Webmin Guide
Tue May 29, 2012 10:46 pm
You don't need to install Apache to run Webmin. It runs it's own web-server independently of Apache.
Simply follow the guide for Debian on http://www.webmin.com/deb.html
sudo apt-get update
Then access Webmin remotely at https://[your raspberry pi ip address]:10000 or locally at https://localhost:10000
If you want to install Apache or anything else you can then do it through Webmin.
[EDIT] damocov posted nearly the same info while I was posting this[/EDIT]
damocov
Re: Webmin Guide
Tue May 29, 2012 11:14 pm
A case of great minds thinking alike ? (although it's also said that fools seldom differ!).
BrianHeston
Re: Webmin Guide
Tue Jun 05, 2012 3:43 am
So, I've installed Webmin per the instructions above, and it appears to be running. But I can't connect to it. I get a connection refused message when I try. Any idea what might be causing this?
abishur
Re: Webmin Guide
Tue Jun 05, 2012 3:41 pm
BrianHeston wrote:So, I've installed Webmin per the instructions above, and it appears to be running. But I can't connect to it. I get a connection refused message when I try. Any idea what might be causing this?
Are you attempting to connect to this from a different pc or locally?
What URL are you typing in?
Dear forum: Play nice ;-)
BrianHeston
Re: Webmin Guide
Tue Jun 05, 2012 7:17 pm
I tried connecting both locally and remotely. I figured out the problem though. Turns out my partition filled up while doing the webmin install but it acted like it finished successfully anyway.
I ended up growing my partition and reinstalling webmin and now it works fine.
abishur
Re: Webmin Guide
Tue Jun 05, 2012 8:12 pm
BrianHeston wrote:I tried connecting both locally and remotely. I figured out the problem though. Turns out my partition filled up while doing the webmin install but it acted like it finished successfully anyway.
Ah, that explains that. Thanks for sharing with the rest of us! :D
tinalee
Re: Webmin Guide
Fri Jul 20, 2012 4:24 pm
Thanks for the guide! Webmin is the first thing I usually like to install, so I was glad to get this help. I too got caught with the partition size issue, but it's all working now after fixing with gparted. One thing I noticed was that other references to partitioning showed a swap partition, but the wheezy image I used does not have a swap? I'm looking forward to putting my little Pi to some good use now.
aquarat
Re: Webmin Guide
Thu Jul 26, 2012 2:38 pm
I just followed the guide on this page : http://www.webmin.com/deb.html
Which entailed that I add the following :
to /etc/apt/sources.list
I then ran these commands :
wget http://www.webmin.com/jcameron-key.asc
apt-key add jcameron-key.asc
apt-get update
apt-get install webmin
Webmin started successfully during the apt-get install phase of the operation, after which I logged on using https://ipofmypi:10000, username root and my root password.
Hope that helps.
EOF
andrea1388
Re: Webmin Guide
Tue Sep 04, 2012 8:51 am
This worked fine for me (taken from the webmin site):
1)
sudo su
edit the /etc/apt/sources.list file on your system and add the lines :
deb http://download.webmin.com/download/repository sarge contrib
deb http://webmin.mirror.somersettechsoluti ... repository sarge contrib
2) You should also fetch and install my GPG key with which the repository is signed, with the commands :
cd /root
3)
apt-get update
All dependencies should be resolved automatically.
Andrea.
Bioshox
Re: Webmin Guide
Tue Sep 04, 2012 1:04 pm
use Raspcontrol: http://raspcontrol.com
Owner of: http://www.fusionstrike.com - I make gorgeous Raspberry Pi Tutorials :)
mcgyver83
Re: Webmin Guide
Tue Oct 16, 2012 10:02 am
I think that raspcontrol is not the same as webmin :D
Raspcontrol only monitor the raspberry...
kaspencer
Re: Webmin Guide
Wed Nov 07, 2012 12:16 pm
Now that is what I call fantastic, Andrea ... thanks alot!
Kenneth Spencer
2xRPi 1, 2xRPi 2, 2xRPi4.
KODI: on RPi 2.
Webserver: on RPi 2.
PDC & fileserver: 4TB disc +RiscOS Pi on RPi 2 + 4.
Book: All about your computer - http://goo.gl/ZQf7c7
caviera
Re: Webmin Guide
Fri Nov 09, 2012 4:26 am
I did all steps, but a got the following error:
webmin ya est� en su versi�n m�s reciente.
Tal vez quiera ejecutar �apt-get -f install� para corregirlo:
Los siguientes paquetes tienen dependencias incumplidas:
webmin : Depende: libnet-ssleay-perl pero no va a instalarse
Depende: libauthen-pam-perl pero no va a instalarse
Depende: libio-pty-perl pero no va a instalarse
Depende: apt-show-versions pero no va a instalarse
E: Dependencias incumplidas. Intente �apt-get -f install� sin paquetes (o especifique una soluci�n).
JVM
Re: Webmin Guide
Mon Feb 25, 2013 3:50 am
andrea1388 wrote:This worked fine for me (taken from the webmin site):
1)
sudo su
cd /root
3)
apt-get update
Andrea.
I've been struggling to install this for a while now on 2013-02-09-wheezy-raspbian but I get the same error as the post above after following Andrea's post to sudo apt-get install webmin...
pi@raspberrypi /root $ sudo apt-get install webmin
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 webmin : Depends: libnet-ssleay-perl but it is not going to be installed
          Depends: libauthen-pam-perl but it is not going to be installed
          Depends: libio-pty-perl but it is not going to be installed
          Depends: apt-show-versions but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Thanks, JVM
Cloudcentric
Re: Webmin Guide
Mon Feb 25, 2013 8:33 am
Well the post you appended to is old, I have successfully installed WebMin on the latest Raspbian "wheezy" image with the 3.6.xx Kernel see in this more recent thread:
http://www.raspberrypi.org/phpBB3/viewt ... in#p295535
This is the instructions I followed, it complains about dependencies but following the prompts, apt-get was able to download blah blah blah
JVM
Re: Webmin Guide
Mon Feb 25, 2013 8:57 am
Thanks for the info Cloudcentric, I gave it a rest and googled again and found this post: http://goraspberry.com/pi/webmin-on-your-raspberry, and now it is working finally! Looking at that thread, next thing I'll look into is Baked Raspberry Pi Mod.
tonyhughes
Re: Webmin Guide
Mon Feb 25, 2013 9:03 am
Webmin is pretty easy to install. Runs slightly slow on pi but very useful and very usable.
fireside
Re: Webmin Guide
Tue Oct 22, 2013 1:43 am
Is there no wifi configuration ability within Webmin?
ronnyvdbr
Re: Webmin Guide
Tue Mar 24, 2015 7:43 pm
Hi, if u want to configure a wireless, see my project:
http://ronnyvdbr.github.io
ronnyvdbr
Re: Webmin Guide
Wed Mar 25, 2015 7:58 pm
Hi everyone, Version 1.1 of the image is now ready and implements a captive portal on the Raspberry WAP.
The version is downloadable from the projects site at http://ronnyvdbr.github.io
wynken
Re: Webmin Guide
Tue May 05, 2015 8:44 pm
Does anyone know how to start/stop Webmin manually from the terminal? The regular commands for Debian don't work.
I don't want it running at boot all the time, it's something of a resource hog on the pi..
firdaus
Re: Webmin Guide
Sun May 21, 2017 2:38 pm
sudo apt-get -f install
tfbiii
Re: Webmin Guide
Mon Oct 09, 2017 4:22 am
Replace all references to "php5" with "php7.0"
-Fred
