Ram.Sh
[SOLVED] how to install 64 bit FFmpeg?
Thu Dec 03, 2020 8:06 pm
Hello all,
I'm running 64bit ver on my PI4 4G:
Linux Dev 5.4.79-v8+ #1373 SMP PREEMPT Mon Nov 23 13:32:41 GMT 2020 aarch64 GNU/Linux
I wanted to follow this link "Hardware Accelerated Video Encoding on the Raspberry Pi 4 on Ubuntu 20.04 64-bit" but I have encountered a wall at the first step:
[jump to the full clean walkthrough here]
git clone --depth 1 --branch release/4.3 git@github.com:FFmpeg/FFmpeg.git
Cloning into 'FFmpeg'...
The authenticity of host 'github.com (140.82.121.4)' can't be established.
RSA key fingerprint is SHA256:nThbg6kXUpJWGl7E1IGOCspRomTxdCARLviKw6E5SY8.
Are you sure you want to continue connecting (yes/no)?
my goal is to use the h264_v4l2m2m for hardware-accelerated encoding using 64 bit FFmpeg v4.3 (under the assumption that my current OS is suitable for that).
i have zero experience with git nor compiling ffmpeg...
I need all the help I can get ;)
Many thanks in advance!
Best,
Ram
Re: how to install 64 bit FFmpeg?
Fri Dec 04, 2020 10:03 am
Yes, you want to continue connecting.
SSH has never seen this server key so is just checking you believe it's safe.
Ram.Sh
Fri Dec 04, 2020 10:18 am
Thank you for your reply!
the server response is:
git@github.com: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
clearly, I'm missing something..
Fri Dec 04, 2020 11:17 am
Use
git clone --depth 1 --branch release/4.3 https://github.com/FFmpeg/FFmpeg.git
instead.
The command line they have provided requires you to have an account on Github with your SSH key registered.
Ram.Sh
Fri Dec 04, 2020 11:21 am
that works! thanks much!
i'll continue with this later this weekend (kids and such :)) and update here.
have a great weekend!
RS.
Ram.Sh
Fri Dec 04, 2020 1:10 pm
in between house tasks, trying to move forward, cloned the ffmpeg git and entered the folder which looks like this:
pi@Dev:~/FFmpeg $ ls
total 656
drwxr-xr-x 19 pi pi   4096 Dec  4 14:19 .
drwxr-xr-x 27 pi pi   4096 Dec  4 15:38 ..
-rw-r--r--  1 pi pi  65819 Dec  4 14:19 Changelog
drwxr-xr-x 11 pi pi   4096 Dec  4 14:19 compat
-rwxr-xr-x  1 pi pi 257450 Dec  4 14:19 configure
-rw-r--r--  1 pi pi    418 Dec  4 14:19 CONTRIBUTING.md
-rw-r--r--  1 pi pi  18092 Dec  4 14:19 COPYING.GPLv2
-rw-r--r--  1 pi pi  35147 Dec  4 14:19 COPYING.GPLv3
-rw-r--r--  1 pi pi  26526 Dec  4 14:19 COPYING.LGPLv2.1
-rw-r--r--  1 pi pi   7651 Dec  4 14:19 COPYING.LGPLv3
-rw-r--r--  1 pi pi    274 Dec  4 14:19 CREDITS
drwxr-xr-x  4 pi pi   4096 Dec  4 14:19 doc
drwxr-xr-x  2 pi pi   4096 Dec  4 14:25 ffbuild
drwxr-xr-x  2 pi pi   4096 Dec  4 14:19 fftools
drwxr-xr-x  8 pi pi   4096 Dec  4 14:19 .git
-rw-r--r--  1 pi pi     50 Dec  4 14:19 .gitattributes
-rw-r--r--  1 pi pi    296 Dec  4 14:19 .gitignore
-rw-r--r--  1 pi pi    596 Dec  4 14:19 INSTALL.md
drwxr-xr-x 14 pi pi  45056 Dec  4 14:19 libavcodec
drwxr-xr-x  3 pi pi   4096 Dec  4 14:19 libavdevice
drwxr-xr-x  7 pi pi  20480 Dec  4 14:19 libavfilter
drwxr-xr-x  3 pi pi  20480 Dec  4 14:19 libavformat
drwxr-xr-x  6 pi pi   4096 Dec  4 14:19 libavresample
drwxr-xr-x 12 pi pi  12288 Dec  4 14:19 libavutil
drwxr-xr-x  2 pi pi   4096 Dec  4 14:19 libpostproc
drwxr-xr-x  6 pi pi   4096 Dec  4 14:19 libswresample
drwxr-xr-x  7 pi pi   4096 Dec  4 14:19 libswscale
-rw-r--r--  1 pi pi   4376 Dec  4 14:19 LICENSE.md
-rw-r--r--  1 pi pi    975 Dec  4 14:19 .mailmap
-rw-r--r--  1 pi pi  30146 Dec  4 14:19 MAINTAINERS
-rw-r--r--  1 pi pi   5880 Dec  4 14:19 Makefile
drwxr-xr-x  2 pi pi   4096 Dec  4 14:19 presets
-rw-r--r--  1 pi pi   1790 Dec  4 14:19 README.md
-rw-r--r--  1 pi pi      6 Dec  4 14:19 RELEASE
-rw-r--r--  1 pi pi    831 Dec  4 14:19 RELEASE_NOTES
drwxr-xr-x  8 pi pi   4096 Dec  4 14:19 tests
drwxr-xr-x  3 pi pi   4096 Dec  4 14:19 tools
-rw-r--r--  1 pi pi    531 Dec  4 14:19 .travis.yml
i tried the following command to configure the script:
pi@Dev:~/FFmpeg $ sudo ./configure --enable-avisynth --enable-fontconfig --enable-gpl --enable-libass --enable-nonfree --enable-libfreetype --arch=aarch64 --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxvid --enable-version3 --enable-libaom --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libxml2 --enable-libwebp --enable-libdrm
don't know if the error below is the result of the parameters i set for the configure script or if that is the correct way to use it.. but I got this error:
ERROR: avisynth/avisynth_c.h not found
If you think configure made a mistake, make sure you are using the latest
version from Git.  If the latest version fails, report the problem to the
ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "ffbuild/config.log" produced by configure as this will help
looking at the end of the log file
config.zip
(52.17 KiB) Downloaded 56 times
reveles:
fatal error: avisynth/avisynth_c.h: No such file or directory
 #include <avisynth/avisynth_c.h>
compilation terminated.
after googling for this error I think i should edit the configure script?
configure.zip
(67.43 KiB) Downloaded 92 times
Ram.Sh
Sat Dec 05, 2020 11:04 am
after many hours of what is considered masochistic voodoo time, i have got some progress, this is the output of the configure:
sudo ./configure   --prefix="$HOME/ffmpeg_build"   --pkg-config-flags="--static"   --extra-cflags="-I$HOME/ffmpeg_build/include"   --extra-ldflags="-L$HOME/ffmpeg_build/lib"   --extra-libs="-lpthread -lm"   --bindir="$HOME/bin"   --enable-gpl   --enable-gnutls   --enable-libaom   --enable-libass   --enable-libfdk-aac   --enable-libfreetype   --enable-libmp3lame   --enable-libopus   --enable-libvorbis   --enable-libvpx   --enable-libx264   --enable-libx265   --enable-nonfree   --arch=aarch64   --enable-libxml2   --enable-libwebp   --enable-libdrm
install prefix            /home/pi/ffmpeg_build
source path               .
C compiler                gcc
C library                 glibc
ARCH                      aarch64 (generic)
big-endian                no
runtime cpu detection     yes
NEON enabled              no
VFP enabled               no
debug symbols             yes
strip symbols             yes
optimize for size         no
optimizations             yes
static                    yes
shared                    no
postprocessing support    yes
network support           yes
threading support         pthreads
safe bitstream reader     yes
texi2html enabled         no
perl enabled              yes
pod2man enabled           yes
makeinfo enabled          yes
makeinfo supports HTML    yes
External libraries:
alsa                    libdrm                  libvorbis               libxcb                  lzma
gnutls                  libfdk_aac              libvpx                  libxcb_shape            sdl2
iconv                   libfreetype             libwebp                 libxcb_shm              sndio
libaom                  libmp3lame              libx264                 libxcb_xfixes           xlib
libass                  libopus                 libx265                 libxml2                 zlib
External libraries providing hardware acceleration:
v4l2_m2m                vaapi                   vdpau
Libraries:
avcodec                 avfilter                avutil                  swresample
avdevice                avformat                postproc                swscale
Programs:
ffmpeg                  ffplay                  ffprobe
Enabled decoders:
aac                     atrac9                  flic                    mp3                     pgm                     truemotion2
aac_fixed               aura                    flv                     mp3adu                  pgmyuv                  truemotion2rt
aac_latm                aura2                   fmvc                    mp3adufloat             pgssub                  truespeech
aasc                    avrn                    fourxm                  mp3float                pictor                  tscc
ac3                     avrp                    fraps                   mp3on4                  pixlet                  tscc2
ac3_fixed               avs                     frwu                    mp3on4float             pjs                     tta
acelp_kelvin            avui                    g2m                     mpc7                    png                     twinvq
adpcm_4xm               ayuv                    g723_1                  mpc8                    ppm                     txd
adpcm_adx               bethsoftvid             g729                    mpeg1_v4l2m2m           prores                  ulti
adpcm_afc               bfi                     gdv                     mpeg1video              prosumer                utvideo
adpcm_agm               bink                    gif                     mpeg2_v4l2m2m           psd                     v210
adpcm_aica              binkaudio_dct           gremlin_dpcm            mpeg2video              ptx                     v210x
adpcm_argo              binkaudio_rdft          gsm                     mpeg4                   qcelp                   v308
adpcm_ct                bintext                 gsm_ms                  mpeg4_v4l2m2m           qdm2                    v408
adpcm_dtk               bitpacked               h261                    mpegvideo               qdmc                    v410
adpcm_ea                bmp                     h263                    mpl2                    qdraw                   vb
adpcm_ea_maxis_xa       bmv_audio               h263_v4l2m2m            msa1                    qpeg                    vble
adpcm_ea_r1             bmv_video               h263i                   mscc                    qtrle                   vc1
adpcm_ea_r2             brender_pix             h263p                   msmpeg4v1               r10k                    vc1_v4l2m2m
adpcm_ea_r3             c93                     h264                    msmpeg4v2               r210                    vc1image
adpcm_ea_xas            cavs                    h264_v4l2m2m            msmpeg4v3               ra_144                  vcr1
adpcm_g722              ccaption                hap                     msrle                   ra_288                  vmdaudio
adpcm_g726              cdgraphics              hca                     mss1                    ralf                    vmdvideo
adpcm_g726le            cdtoons                 hcom                    mss2                    rasc                    vmnc
adpcm_ima_alp           cdxl                    hevc                    msvideo1                rawvideo                vorbis
adpcm_ima_amv           cfhd                    hevc_v4l2m2m            mszh                    realtext                vp3
adpcm_ima_apc           cinepak                 hnm4_video              mts2                    rl2                     vp4
adpcm_ima_apm           clearvideo              hq_hqa                  mv30                    roq                     vp5
adpcm_ima_cunning       cljr                    hqx                     mvc1                    roq_dpcm                vp6
adpcm_ima_dat4          cllc                    huffyuv                 mvc2                    rpza                    vp6a
adpcm_ima_dk3           comfortnoise            hymt                    mvdv                    rscc                    vp6f
adpcm_ima_dk4           cook                    iac                     mvha                    rv10                    vp7
adpcm_ima_ea_eacs       cpia                    idcin                   mwsc                    rv20                    vp8
adpcm_ima_ea_sead       cscd                    idf                     mxpeg                   rv30                    vp8_v4l2m2m
adpcm_ima_iss           cyuv                    iff_ilbm                nellymoser              rv40                    vp9
adpcm_ima_mtf           dca                     ilbc                    notchlc                 s302m                   vp9_v4l2m2m
adpcm_ima_oki           dds                     imc                     nuv                     sami                    vplayer
adpcm_ima_qt            derf_dpcm               imm4                    on2avc                  sanm                    vqa
adpcm_ima_rad           dfa                     imm5                    opus                    sbc                     wavpack
adpcm_ima_smjpeg        dirac                   indeo2                  paf_audio               scpr                    wcmv
adpcm_ima_ssi           dnxhd                   indeo3                  paf_video               screenpresso            webp
adpcm_ima_wav           dolby_e                 indeo4                  pam                     sdx2_dpcm               webvtt
adpcm_ima_ws            dpx                     indeo5                  pbm                     sgi                     wmalossless
adpcm_ms                dsd_lsbf                interplay_acm           pcm_alaw                sgirle                  wmapro
adpcm_mtaf              dsd_lsbf_planar         interplay_dpcm          pcm_bluray              sheervideo              wmav1
adpcm_psx               dsd_msbf                interplay_video         pcm_dvd                 shorten                 wmav2
adpcm_sbpro_2           dsd_msbf_planar         jacosub                 pcm_f16le               sipr                    wmavoice
adpcm_sbpro_3           dsicinaudio             jpeg2000                pcm_f24le               siren                   wmv1
adpcm_sbpro_4           dsicinvideo             jpegls                  pcm_f32be               smackaud                wmv2
adpcm_swf               dss_sp                  jv                      pcm_f32le               smacker                 wmv3
adpcm_thp               dst                     kgv1                    pcm_f64be               smc                     wmv3image
adpcm_thp_le            dvaudio                 kmvc                    pcm_f64le               smvjpeg                 wnv1
adpcm_vima              dvbsub                  lagarith                pcm_lxf                 snow                    wrapped_avframe
adpcm_xa                dvdsub                  libaom_av1              pcm_mulaw               sol_dpcm                ws_snd1
adpcm_yamaha            dvvideo                 libfdk_aac              pcm_s16be               sonic                   xan_dpcm
adpcm_zork              dxa                     libopus                 pcm_s16be_planar        sp5x                    xan_wc3
agm                     dxtory                  libvorbis               pcm_s16le               speedhq                 xan_wc4
aic                     dxv                     libvpx_vp8              pcm_s16le_planar        srgc                    xbin
alac                    eac3                    libvpx_vp9              pcm_s24be               srt                     xbm
alias_pix               eacmv                   loco                    pcm_s24daud             ssa                     xface
als                     eamad                   lscr                    pcm_s24le               stl                     xl
amrnb                   eatgq                   m101                    pcm_s24le_planar        subrip                  xma1
amrwb                   eatgv                   mace3                   pcm_s32be               subviewer               xma2
amv                     eatqi                   mace6                   pcm_s32le               subviewer1              xpm
anm                     eightbps                magicyuv                pcm_s32le_planar        sunrast                 xsub
ansi                    eightsvx_exp            mdec                    pcm_s64be               svq1                    xwd
ape                     eightsvx_fib            metasound               pcm_s64le               svq3                    y41p
apng                    escape124               microdvd                pcm_s8                  tak                     ylc
aptx                    escape130               mimic                   pcm_s8_planar           targa                   yop
aptx_hd                 evrc                    mjpeg                   pcm_u16be               targa_y216              yuv4
arbc                    exr                     mjpegb                  pcm_u16le               tdsc                    zero12v
ass                     ffv1                    mlp                     pcm_u24be               text                    zerocodec
asv1                    ffvhuff                 mmvideo                 pcm_u24le               theora                  zlib
asv2                    ffwavesynth             motionpixels            pcm_u32be               thp                     zmbv
atrac1                  fic                     movtext                 pcm_u32le               tiertexseqvideo
atrac3                  fits                    mp1                     pcm_u8                  tiff
atrac3al                flac                    mp1float                pcm_vidc                tmv
atrac3p                 flashsv                 mp2                     pcx                     truehd
atrac3pal               flashsv2                mp2float                pfm                     truemotion1
Enabled encoders:
a64multi                comfortnoise            libmp3lame              pcm_alaw                pcx                     tiff
a64multi5               dca                     libopus                 pcm_dvd                 pgm                     truehd
aac                     dnxhd                   libvorbis               pcm_f32be               pgmyuv                  tta
ac3                     dpx                     libvpx_vp8              pcm_f32le               png                     utvideo
ac3_fixed               dvbsub                  libvpx_vp9              pcm_f64be               ppm                     v210
adpcm_adx               dvdsub                  libwebp                 pcm_f64le               prores                  v308
adpcm_g722              dvvideo                 libwebp_anim            pcm_mulaw               prores_aw               v408
adpcm_g726              eac3                    libx264                 pcm_s16be               prores_ks               v410
adpcm_g726le            ffv1                    libx264rgb              pcm_s16be_planar        qtrle                   vc2
adpcm_ima_qt            ffvhuff                 libx265                 pcm_s16le               r10k                    vorbis
adpcm_ima_ssi           fits                    ljpeg                   pcm_s16le_planar        r210                    vp8_v4l2m2m
adpcm_ima_wav           flac                    magicyuv                pcm_s24be               ra_144                  vp8_vaapi
adpcm_ms                flashsv                 mjpeg                   pcm_s24daud             rawvideo                vp9_vaapi
adpcm_swf               flashsv2                mjpeg_vaapi             pcm_s24le               roq                     wavpack
adpcm_yamaha            flv                     mlp                     pcm_s24le_planar        roq_dpcm                webvtt
alac                    g723_1                  movtext                 pcm_s32be               rv10                    wmav1
alias_pix               gif                     mp2                     pcm_s32le               rv20                    wmav2
amv                     h261                    mp2fixed                pcm_s32le_planar        s302m                   wmv1
apng                    h263                    mpeg1video              pcm_s64be               sbc                     wmv2
aptx                    h263_v4l2m2m            mpeg2_vaapi             pcm_s64le               sgi                     wrapped_avframe
aptx_hd                 h263p                   mpeg2video              pcm_s8                  snow                    xbm
ass                     h264_v4l2m2m            mpeg4                   pcm_s8_planar           sonic                   xface
asv1                    h264_vaapi              mpeg4_v4l2m2m           pcm_u16be               sonic_ls                xsub
asv2                    hevc_v4l2m2m            msmpeg4v2               pcm_u16le               srt                     xwd
avrp                    hevc_vaapi              msmpeg4v3               pcm_u24be               ssa                     y41p
avui                    huffyuv                 msvideo1                pcm_u24le               subrip                  yuv4
ayuv                    jpeg2000                nellymoser              pcm_u32be               sunrast                 zlib
bmp                     jpegls                  opus                    pcm_u32le               svq1                    zmbv
cinepak                 libaom_av1              pam                     pcm_u8                  targa
cljr                    libfdk_aac              pbm                     pcm_vidc                text
Enabled hwaccels:
h263_vaapi              hevc_vaapi              mpeg1_vdpau             mpeg4_vaapi             vc1_vdpau               wmv3_vaapi
h264_vaapi              hevc_vdpau              mpeg2_vaapi             mpeg4_vdpau             vp8_vaapi               wmv3_vdpau
h264_vdpau              mjpeg_vaapi             mpeg2_vdpau             vc1_vaapi               vp9_vaapi
Enabled parsers:
aac                     cook                    dvdsub                  h264                    opus                    vc1
aac_latm                dca                     flac                    hevc                    png                     vorbis
ac3                     dirac                   g723_1                  jpeg2000                pnm                     vp3
adx                     dnxhd                   g729                    mjpeg                   rv30                    vp8
av1                     dpx                     gif                     mlp                     rv40                    vp9
avs2                    dvaudio                 gsm                     mpeg4video              sbc                     webp
bmp                     dvbsub                  h261                    mpegaudio               sipr                    xma
cavsvideo               dvd_nav                 h263                    mpegvideo               tak
Enabled demuxers:
aa                      codec2                  hls                     lrc                     pcm_s24le               srt
aac                     codec2raw               hnm                     lvf                     pcm_s32be               stl
ac3                     concat                  ico                     lxf                     pcm_s32le               str
acm                     dash                    idcin                   m4v                     pcm_s8                  subviewer
act                     data                    idf                     matroska                pcm_u16be               subviewer1
adf                     daud                    iff                     mgsts                   pcm_u16le               sup
adp                     dcstr                   ifv                     microdvd                pcm_u24be               svag
ads                     derf                    ilbc                    mjpeg                   pcm_u24le               swf
adx                     dfa                     image2                  mjpeg_2000              pcm_u32be               tak
aea                     dhav                    image2_alias_pix        mlp                     pcm_u32le               tedcaptions
afc                     dirac                   image2_brender_pix      mlv                     pcm_u8                  thp
aiff                    dnxhd                   image2pipe              mm                      pcm_vidc                threedostr
aix                     dsf                     image_bmp_pipe          mmf                     pjs                     tiertexseq
alp                     dsicin                  image_dds_pipe          mov                     pmp                     tmv
amr                     dss                     image_dpx_pipe          mp3                     pp_bnk                  truehd
amrnb                   dts                     image_exr_pipe          mpc                     pva                     tta
amrwb                   dtshd                   image_gif_pipe          mpc8                    pvf                     tty
anm                     dv                      image_j2k_pipe          mpegps                  qcp                     txd
apc                     dvbsub                  image_jpeg_pipe         mpegts                  r3d                     ty
ape                     dvbtxt                  image_jpegls_pipe       mpegtsraw               rawvideo                v210
apm                     dxa                     image_pam_pipe          mpegvideo               realtext                v210x
apng                    ea                      image_pbm_pipe          mpjpeg                  redspark                vag
aptx                    ea_cdata                image_pcx_pipe          mpl2                    rl2                     vc1
aptx_hd                 eac3                    image_pgm_pipe          mpsub                   rm                      vc1t
aqtitle                 epaf                    image_pgmyuv_pipe       msf                     roq                     vividas
argo_asf                ffmetadata              image_pictor_pipe       msnwc_tcp               rpl                     vivo
asf                     filmstrip               image_png_pipe          mtaf                    rsd                     vmd
asf_o                   fits                    image_ppm_pipe          mtv                     rso                     vobsub
ass                     flac                    image_psd_pipe          musx                    rtp                     voc
ast                     flic                    image_qdraw_pipe        mv                      rtsp                    vpk
au                      flv                     image_sgi_pipe          mvi                     s337m                   vplayer
av1                     fourxm                  image_sunrast_pipe      mxf                     sami                    vqf
avi                     frm                     image_svg_pipe          mxg                     sap                     w64
avr                     fsb                     image_tiff_pipe         nc                      sbc                     wav
avs                     fwse                    image_webp_pipe         nistsphere              sbg                     wc3
avs2                    g722                    image_xpm_pipe          nsp                     scc                     webm_dash_manifest
bethsoftvid             g723_1                  image_xwd_pipe          nsv                     sdp                     webvtt
bfi                     g726                    ingenient               nut                     sdr2                    wsaud
bfstm                   g726le                  ipmovie                 nuv                     sds                     wsd
bink                    g729                    ircam                   ogg                     sdx                     wsvqa
bintext                 gdv                     iss                     oma                     segafilm                wtv
bit                     genh                    iv8                     paf                     ser                     wv
bmv                     gif                     ivf                     pcm_alaw                shorten                 wve
boa                     gsm                     ivr                     pcm_f32be               siff                    xa
brstm                   gxf                     jacosub                 pcm_f32le               sln                     xbin
c93                     h261                    jv                      pcm_f64be               smacker                 xmv
caf                     h263                    kux                     pcm_f64le               smjpeg                  xvag
cavsvideo               h264                    kvag                    pcm_mulaw               smush                   xwma
cdg                     hca                     live_flv                pcm_s16be               sol                     yop
cdxl                    hcom                    lmlm4                   pcm_s16le               sox                     yuv4mpegpipe
cine                    hevc                    loas                    pcm_s24be               spdif
Enabled muxers:
a64                     dts                     ico                     mpeg2dvd                pcm_s8                  srt
ac3                     dv                      ilbc                    mpeg2svcd               pcm_u16be               stream_segment
adts                    eac3                    image2                  mpeg2video              pcm_u16le               streamhash
adx                     f4v                     image2pipe              mpeg2vob                pcm_u24be               sup
aiff                    ffmetadata              ipod                    mpegts                  pcm_u24le               swf
amr                     fifo                    ircam                   mpjpeg                  pcm_u32be               tee
apng                    fifo_test               ismv                    mxf                     pcm_u32le               tg2
aptx                    filmstrip               ivf                     mxf_d10                 pcm_u8                  tgp
aptx_hd                 fits                    jacosub                 mxf_opatom              pcm_vidc                truehd
asf                     flac                    kvag                    null                    psp                     tta
asf_stream              flv                     latm                    nut                     rawvideo                uncodedframecrc
ass                     framecrc                lrc                     oga                     rm                      vc1
ast                     framehash               m4v                     ogg                     roq                     vc1t
au                      framemd5                matroska                ogv                     rso                     voc
avi                     g722                    matroska_audio          oma                     rtp                     w64
avm2                    g723_1                  md5                     opus                    rtp_mpegts              wav
avs2                    g726                    microdvd                pcm_alaw                rtsp                    webm
bit                     g726le                  mjpeg                   pcm_f32be               sap                     webm_chunk
caf                     gif                     mkvtimestamp_v2         pcm_f32le               sbc                     webm_dash_manifest
cavsvideo               gsm                     mlp                     pcm_f64be               scc                     webp
codec2                  gxf                     mmf                     pcm_f64le               segafilm                webvtt
codec2raw               h261                    mov                     pcm_mulaw               segment                 wtv
crc                     h263                    mp2                     pcm_s16be               singlejpeg              wv
dash                    h264                    mp3                     pcm_s16le               smjpeg                  yuv4mpegpipe
data                    hash                    mp4                     pcm_s24be               smoothstreaming
daud                    hds                     mpeg1system             pcm_s24le               sox
dirac                   hevc                    mpeg1vcd                pcm_s32be               spdif
dnxhd                   hls                     mpeg1video              pcm_s32le               spx
Enabled protocols:
async                   file                    https                   prompeg                 srtp                    udplite
cache                   ftp                     icecast                 rtmp                    subfile                 unix
concat                  gopher                  md5                     rtmps                   tcp
crypto                  hls                     mmsh                    rtmpt                   tee
data                    http                    mmst                    rtmpts                  tls
ffrtmphttp              httpproxy               pipe                    rtp                     udp
Enabled filters:
abench                  asidedata               deflate                 hqdn3d                  perspective             smartblur
abitscope               asoftclip               deflicker               hqx                     phase                   smptebars
acompressor             asplit                  deinterlace_vaapi       hstack                  photosensitivity        smptehdbars
acontrast               ass                     dejudder                hue                     pixdesctest             sobel
acopy                   astats                  delogo                  hwdownload              pixscope                spectrumsynth
acrossfade              astreamselect           denoise_vaapi           hwmap                   pp                      split
acrossover              asubboost               derain                  hwupload                pp7                     spp
acrusher                atadenoise              deshake                 hysteresis              premultiply             sr
acue                    atempo                  despill                 idet                    prewitt                 ssim
addroi                  atrim                   detelecine              il                      procamp_vaapi           stereo3d
adeclick                avectorscope            dilation                inflate                 pseudocolor             stereotools
adeclip                 avgblur                 displace                interlace               psnr                    stereowiden
adelay                  axcorrelate             dnn_processing          interleave              pullup                  streamselect
aderivative             bandpass                doubleweave             join                    qp                      subtitles
adrawgraph              bandreject              drawbox                 kerndeint               random                  super2xsai
aecho                   bass                    drawgraph               lagfun                  readeia608              superequalizer
aemphasis               bbox                    drawgrid                lenscorrection          readvitc                surround
aeval                   bench                   drawtext                life                    realtime                swaprect
aevalsrc                bilateral               drmeter                 limiter                 remap                   swapuv
afade                   biquad                  dynaudnorm              loop                    removegrain             tblend
afftdn                  bitplanenoise           earwax                  loudnorm                removelogo              telecine
afftfilt                blackdetect             ebur128                 lowpass                 repeatfields            testsrc
afifo                   blackframe              edgedetect              lowshelf                replaygain              testsrc2
afir                    blend                   elbg                    lumakey                 reverse                 thistogram
afirsrc                 bm3d                    entropy                 lut                     rgbashift               threshold
aformat                 boxblur                 eq                      lut1d                   rgbtestsrc              thumbnail
agate                   bwdif                   equalizer               lut2                    roberts                 tile
agraphmonitor           cas                     erosion                 lut3d                   rotate                  tinterlace
ahistogram              cellauto                extractplanes           lutrgb                  sab                     tlut2
aiir                    channelmap              extrastereo             lutyuv                  scale                   tmedian
aintegral               channelsplit            fade                    mandelbrot              scale2ref               tmix
ainterleave             chorus                  fftdnoiz                maskedclamp             scale_vaapi             tonemap
alimiter                chromahold              fftfilt                 maskedmax               scdet                   tonemap_vaapi
allpass                 chromakey               field                   maskedmerge             scroll                  tpad
allrgb                  chromashift             fieldhint               maskedmin               select                  transpose
allyuv                  ciescope                fieldmatch              maskedthreshold         selectivecolor          transpose_vaapi
aloop                   codecview               fieldorder              maskfun                 sendcmd                 treble
alphaextract            color                   fifo                    mcdeint                 separatefields          tremolo
alphamerge              colorbalance            fillborders             mcompand                setdar                  trim
amerge                  colorchannelmixer       find_rect               median                  setfield                unpremultiply
ametadata               colorhold               firequalizer            mergeplanes             setparams               unsharp
amix                    colorkey                flanger                 mestimate               setpts                  untile
amovie                  colorlevels             floodfill               metadata                setrange                uspp
amplify                 colormatrix             format                  midequalizer            setsar                  v360
amultiply               colorspace              fps                     minterpolate            settb                   vaguedenoiser
anequalizer             compand                 framepack               mix                     sharpness_vaapi         vectorscope
anlmdn                  compensationdelay       framerate               movie                   showcqt                 vflip
anlms                   concat                  framestep               mpdecimate              showfreqs               vfrdet
anoisesrc               convolution             freezedetect            mptestsrc               showinfo                vibrance
anull                   convolve                freezeframes            negate                  showpalette             vibrato
anullsink               copy                    fspp                    nlmeans                 showspatial             vignette
anullsrc                cover_rect              gblur                   nnedi                   showspectrum            vmafmotion
apad                    crop                    geq                     noformat                showspectrumpic         volume
aperms                  cropdetect              gradfun                 noise                   showvolume              volumedetect
aphasemeter             crossfeed               gradients               normalize               showwaves               vstack
aphaser                 crystalizer             graphmonitor            null                    showwavespic            w3fdif
apulsator               cue                     greyedge                nullsink                shuffleframes           waveform
arealtime               curves                  haas                    nullsrc                 shuffleplanes           weave
aresample               datascope               haldclut                oscilloscope            sidechaincompress       xbr
areverse                dblur                   haldclutsrc             overlay                 sidechaingate           xfade
arnndn                  dcshift                 hdcd                    owdenoise               sidedata                xmedian
aselect                 dctdnoiz                headphone               pad                     sierpinski              xstack
asendcmd                deband                  hflip                   pal100bars              signalstats             yadif
asetnsamples            deblock                 highpass                pal75bars               signature               yaepblur
asetpts                 decimate                highshelf               palettegen              silencedetect           yuvtestsrc
asetrate                deconvolve              hilbert                 paletteuse              silenceremove           zoompan
asettb                  dedot                   histeq                  pan                     sinc
ashowinfo               deesser                 histogram               perms                   sine
Enabled bsfs:
aac_adtstoasc           dump_extradata          h264_redundant_pps      mjpega_dump_header      null                    trace_headers
av1_frame_merge         eac3_core               hapqa_extract           mov2textsub             opus_metadata           truehd_core
av1_frame_split         extract_extradata       hevc_metadata           mp3_header_decompress   pcm_rechunk             vp9_metadata
av1_metadata            filter_units            hevc_mp4toannexb        mpeg2_metadata          prores_metadata         vp9_raw_reorder
chomp                   h264_metadata           imx_dump_header         mpeg4_unpack_bframes    remove_extradata        vp9_superframe
dca_core                h264_mp4toannexb        mjpeg2jpeg              noise                   text2movsub             vp9_superframe_split
Enabled indevs:
alsa                    kmsgrab                 oss                     v4l2
fbdev                   lavfi                   sndio                   xcbgrab
Enabled outdevs:
alsa                    oss                     sndio                   xv
fbdev                   sdl2                    v4l2
License: nonfree and unredistributable
config.h is unchanged
libavutil/avconfig.h is unchanged
libavfilter/filter_list.c is unchanged
libavcodec/codec_list.c is unchanged
libavcodec/parser_list.c is unchanged
libavcodec/bsf_list.c is unchanged
libavformat/demuxer_list.c is unchanged
libavformat/muxer_list.c is unchanged
libavdevice/indev_list.c is unchanged
libavdevice/outdev_list.c is unchanged
libavformat/protocol_list.c is unchanged
ffbuild/config.sh is unchanged
if i understand it correctly, so the next part should be the "make" part:
sudo make -j4
and the output with errors:
pi@Dev:~/FFmpeg $ sudo make -j4
CC	libavfilter/vf_curves.o
CC	libavfilter/vf_edgedetect.o
CC	libavfilter/vf_elbg.o
CC	libavfilter/vf_entropy.o
CC	libavfilter/vf_eq.o
CC	libavfilter/vf_extractplanes.o
In file included from ./libavutil/bswap.h:38,
                 from ./libavutil/intreadwrite.h:25,
                 from libavfilter/vf_curves.c:25:
libavfilter/vf_curves.c: In function ‘parse_psfile’:
./libavutil/aarch64/bswap.h:31:5: error: invalid 'asm': invalid operand for code 'w'
     __asm__("rev16 %w0, %w0" : "+r"(x));
CC	libavfilter/vf_fade.o
CC	libavfilter/vf_fftdnoiz.o
CC	libavfilter/vf_fftfilt.o
make: *** [ffbuild/common.mak:59: libavfilter/vf_curves.o] Error 1
make: *** Waiting for unfinished jobs....
does anyone know how to resolve this?
graysky
Sat Dec 05, 2020 12:08 pm
In general: never build as root. I do not even recommend running make as root for your install tasks. You can use a package manager for that.
As to building, I am not using RaspberryPi OS, so I cannot speak to dependencies mapping to packages on it, but you can review the "build recipe" in detail by seeing how another distro, Arch ARM, does it. On Arch ARM, like Arch, packages are built from so-called PKGBUILDs. A bash-like script you can follow along. Here is the ffmpeg one for example. I mucked around with building Debian packages years ago but found their process to be more complex, but you should be able to find the needed files and use them as a guide as you build by hand.
I can tell that you I have successfully built kodi with ffmpeg that has been patched with popcornmix's code (see his gbm fork) that enables hw decoding on Arch ARM aarch64, so it is possible to do in principal.
Ram.Sh
Sat Dec 05, 2020 12:12 pm
thank you for your reply!
running the make without sudo:
pi@Dev:~/FFmpeg $ make -j4
CC	libavfilter/vf_field.o
CC	libavfilter/vf_fieldhint.o
CC	libavfilter/vf_fieldmatch.o
CC	libavfilter/vf_fieldorder.o
CC	libavfilter/vf_fillborders.o
CC	libavfilter/vf_find_rect.o
CC	libavfilter/vf_floodfill.o
libavfilter/vf_curves.c: At top level:
libavfilter/vf_curves.c:784:1: fatal error: opening dependency file libavfilter/vf_curves.d: Permission denied
graysky
Sat Dec 05, 2020 12:16 pm
You replied as I was editing my post above. I added more content to it. As to your specific error, I do not know... perhaps you are missing a dependency? In any case, recommend you either nuke the build and start over or try to reset the permissions on your build to your user/group rather than root/root.
EDIT: also which kernel are you running? As I understand (perhaps incorrectly), key headers and libs for hardware acceleration on RPi4 has been added to the 5.10.y branch. If you're on 5.4.y for example, you might not be able to do it. When I mentioned success above, my RPi4 64-bit install is running a kernel compiled from the 5.10.y branch (5.10.0-rc6 currently). I have not tried with other versions.
Ram.Sh
Sat Dec 05, 2020 12:48 pm
i'm using:
I did as your recommendation and started all from scratch this time without sudo, here's the make command output:
GEN	libavutil/libavutil.version
GEN	libswscale/libswscale.version
GEN	libswresample/libswresample.version
GEN	libpostproc/libpostproc.version
GEN	libavcodec/libavcodec.version
GEN	libavformat/libavformat.version
GEN	libavfilter/libavfilter.version
GEN	libavdevice/libavdevice.version
CC	libavdevice/alldevices.o
CC	libavdevice/alsa.o
CC	libavdevice/alsa_enc.o
CC	libavdevice/alsa_dec.o
CC	libavdevice/avdevice.o
CC	libavdevice/fbdev_common.o
CC	libavdevice/fbdev_dec.o
libavdevice/avdevice.c: In function ‘device_next’:
libavdevice/avdevice.c:88:13: warning: ‘av_oformat_next’ is deprecated [-Wdeprecated-declarations]
             if (!(prev = av_oformat_next(prev)))
In file included from libavdevice/avdevice.h:51,
                 from libavdevice/avdevice.c:23:
./libavformat/avformat.h:2095:17: note: declared here
 AVOutputFormat *av_oformat_next(const AVOutputFormat *f);
libavdevice/avdevice.c:92:13: warning: ‘av_iformat_next’ is deprecated [-Wdeprecated-declarations]
             if (!(prev = av_iformat_next(prev)))
./libavformat/avformat.h:2087:17: note: declared here
 AVInputFormat  *av_iformat_next(const AVInputFormat  *f);
CC	libavdevice/fbdev_enc.o
CC	libavdevice/kmsgrab.o
CC	libavdevice/lavfi.o
CC	libavdevice/oss.o
CC	libavdevice/oss_dec.o
CC	libavdevice/oss_enc.o
CC	libavdevice/sdl2.o
CC	libavdevice/sndio.o
CC	libavdevice/sndio_dec.o
CC	libavdevice/sndio_enc.o
CC	libavdevice/timefilter.o
CC	libavdevice/utils.o
CC	libavdevice/v4l2-common.o
CC	libavdevice/v4l2.o
CC	libavdevice/v4l2enc.o
CC	libavdevice/xcbgrab.o
CC	libavdevice/xv.o
libavdevice/v4l2.c: In function ‘v4l2_get_device_list’:
libavdevice/v4l2.c:1054:58: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 251 [-Wformat-truncation=]
         snprintf(device_name, sizeof(device_name), "/dev/%s", entry->d_name);
libavdevice/v4l2.c:1054:9: note: ‘snprintf’ output between 6 and 261 bytes into a destination of size 256
GEN	libavdevice/libavdevice.pc
CC	libavfilter/aarch64/vf_nlmeans_init.o
CC	libavfilter/aeval.o
CC	libavfilter/af_acontrast.o
CC	libavfilter/af_acopy.o
CC	libavfilter/af_acrossover.o
CC	libavfilter/af_acrusher.o
CC	libavfilter/af_adeclick.o
CC	libavfilter/af_adelay.o
CC	libavfilter/af_aderivative.o
CC	libavfilter/af_aecho.o
CC	libavfilter/af_aemphasis.o
CC	libavfilter/af_afade.o
CC	libavfilter/af_afftdn.o
CC	libavfilter/af_afftfilt.o
CC	libavfilter/af_afir.o
CC	libavfilter/af_aformat.o
CC	libavfilter/af_agate.o
CC	libavfilter/af_aiir.o
CC	libavfilter/af_alimiter.o
CC	libavfilter/af_amerge.o
CC	libavfilter/af_amix.o
CC	libavfilter/af_amultiply.o
CC	libavfilter/af_anequalizer.o
CC	libavfilter/af_anlmdn.o
CC	libavfilter/af_anlms.o
CC	libavfilter/af_anull.o
CC	libavfilter/af_apad.o
CC	libavfilter/af_apulsator.o
CC	libavfilter/af_aphaser.o
CC	libavfilter/af_aresample.o
CC	libavfilter/af_arnndn.o
CC	libavfilter/af_asetnsamples.o
CC	libavfilter/af_asetrate.o
CC	libavfilter/af_ashowinfo.o
CC	libavfilter/af_asoftclip.o
CC	libavfilter/af_astats.o
CC	libavfilter/af_asubboost.o
CC	libavfilter/af_atempo.o
CC	libavfilter/af_axcorrelate.o
CC	libavfilter/af_biquads.o
CC	libavfilter/af_channelmap.o
CC	libavfilter/af_channelsplit.o
CC	libavfilter/af_chorus.o
CC	libavfilter/af_compand.o
CC	libavfilter/af_compensationdelay.o
CC	libavfilter/af_crossfeed.o
CC	libavfilter/af_crystalizer.o
CC	libavfilter/af_dcshift.o
CC	libavfilter/af_deesser.o
CC	libavfilter/af_drmeter.o
CC	libavfilter/af_dynaudnorm.o
CC	libavfilter/af_earwax.o
CC	libavfilter/af_extrastereo.o
CC	libavfilter/af_firequalizer.o
CC	libavfilter/af_flanger.o
CC	libavfilter/af_haas.o
CC	libavfilter/af_hdcd.o
CC	libavfilter/af_headphone.o
CC	libavfilter/af_join.o
CC	libavfilter/af_loudnorm.o
CC	libavfilter/af_mcompand.o
CC	libavfilter/af_pan.o
CC	libavfilter/af_replaygain.o
CC	libavfilter/af_sidechaincompress.o
CC	libavfilter/af_silencedetect.o
CC	libavfilter/af_silenceremove.o
CC	libavfilter/af_stereotools.o
CC	libavfilter/af_stereowiden.o
CC	libavfilter/af_superequalizer.o
CC	libavfilter/af_surround.o
CC	libavfilter/af_tremolo.o
CC	libavfilter/af_vibrato.o
CC	libavfilter/af_volume.o
CC	libavfilter/af_volumedetect.o
CC	libavfilter/allfilters.o
CC	libavfilter/asink_anullsink.o
CC	libavfilter/asrc_afirsrc.o
CC	libavfilter/asrc_anoisesrc.o
CC	libavfilter/asrc_anullsrc.o
CC	libavfilter/asrc_hilbert.o
CC	libavfilter/asrc_sinc.o
CC	libavfilter/asrc_sine.o
CC	libavfilter/audio.o
CC	libavfilter/avf_abitscope.o
CC	libavfilter/avf_ahistogram.o
CC	libavfilter/avf_aphasemeter.o
CC	libavfilter/avf_avectorscope.o
CC	libavfilter/avf_concat.o
CC	libavfilter/avf_showcqt.o
CC	libavfilter/avf_showfreqs.o
CC	libavfilter/avf_showspatial.o
CC	libavfilter/avf_showspectrum.o
CC	libavfilter/avf_showvolume.o
CC	libavfilter/avf_showwaves.o
CC	libavfilter/avfilter.o
CC	libavfilter/avfiltergraph.o
CC	libavfilter/bbox.o
libavfilter/avfiltergraph.c: In function ‘avfilter_graph_free’:
libavfilter/avfiltergraph.c:135:5: warning: ‘resample_lavr_opts’ is deprecated [-Wdeprecated-declarations]
     av_freep(&(*graph)->resample_lavr_opts);
In file included from libavfilter/avfiltergraph.c:39:
libavfilter/avfilter.h:847:32: note: declared here
     attribute_deprecated char *resample_lavr_opts;   ///< libavresample options to use for the auto-inserted resample filters
CC	libavfilter/boxblur.o
CC	libavfilter/buffersink.o
CC	libavfilter/buffersrc.o
CC	libavfilter/colorspace.o
CC	libavfilter/colorspacedsp.o
CC	libavfilter/dnn/dnn_backend_native.o
CC	libavfilter/dnn/dnn_backend_native_layer_conv2d.o
CC	libavfilter/dnn/dnn_backend_native_layer_depth2space.o
CC	libavfilter/dnn/dnn_backend_native_layer_mathbinary.o
CC	libavfilter/dnn/dnn_backend_native_layer_mathunary.o
CC	libavfilter/dnn/dnn_backend_native_layer_maximum.o
CC	libavfilter/dnn/dnn_backend_native_layer_pad.o
CC	libavfilter/dnn/dnn_backend_native_layers.o
CC	libavfilter/dnn/dnn_interface.o
CC	libavfilter/drawutils.o
CC	libavfilter/ebur128.o
CC	libavfilter/f_bench.o
CC	libavfilter/f_cue.o
CC	libavfilter/f_drawgraph.o
CC	libavfilter/f_ebur128.o
CC	libavfilter/f_graphmonitor.o
CC	libavfilter/f_interleave.o
CC	libavfilter/f_loop.o
CC	libavfilter/f_metadata.o
CC	libavfilter/f_perms.o
CC	libavfilter/f_realtime.o
CC	libavfilter/f_reverse.o
CC	libavfilter/f_select.o
CC	libavfilter/f_sendcmd.o
CC	libavfilter/f_sidedata.o
CC	libavfilter/f_streamselect.o
CC	libavfilter/fifo.o
CC	libavfilter/formats.o
CC	libavfilter/framepool.o
CC	libavfilter/framequeue.o
CC	libavfilter/framesync.o
CC	libavfilter/generate_wave_table.o
CC	libavfilter/graphdump.o
CC	libavfilter/graphparser.o
CC	libavfilter/lavfutils.o
libavfilter/lavfutils.c: In function ‘ff_load_image’:
libavfilter/lavfutils.c:91:5: warning: ‘avcodec_decode_video2’ is deprecated [-Wdeprecated-declarations]
     ret = avcodec_decode_video2(codec_ctx, frame, &frame_decoded, &pkt);
In file included from ./libavformat/avformat.h:312,
                 from libavfilter/lavfutils.h:27,
                 from libavfilter/lavfutils.c:22:
./libavcodec/avcodec.h:3073:5: note: declared here
 int avcodec_decode_video2(AVCodecContext *avctx, AVFrame *picture,
CC	libavfilter/lswsutils.o
CC	libavfilter/motion_estimation.o
CC	libavfilter/pthread.o
CC	libavfilter/scale_eval.o
CC	libavfilter/scene_sad.o
CC	libavfilter/setpts.o
CC	libavfilter/settb.o
CC	libavfilter/split.o
CC	libavfilter/src_movie.o
CC	libavfilter/transform.o
CC	libavfilter/trim.o
libavfilter/src_movie.c: In function ‘open_stream’:
libavfilter/src_movie.c:175:5: warning: ‘refcounted_frames’ is deprecated [-Wdeprecated-declarations]
     st->codec_ctx->refcounted_frames = 1;
In file included from libavfilter/src_movie.c:41:
./libavcodec/avcodec.h:1357:9: note: declared here
     int refcounted_frames;
libavfilter/src_movie.c: In function ‘movie_push_frame’:
libavfilter/src_movie.c:530:9: warning: ‘avcodec_decode_video2’ is deprecated [-Wdeprecated-declarations]
         ret = avcodec_decode_video2(st->codec_ctx, frame, &got_frame, pkt);
libavfilter/src_movie.c:533:9: warning: ‘avcodec_decode_audio4’ is deprecated [-Wdeprecated-declarations]
         ret = avcodec_decode_audio4(st->codec_ctx, frame, &got_frame, pkt);
./libavcodec/avcodec.h:3024:5: note: declared here
 int avcodec_decode_audio4(AVCodecContext *avctx, AVFrame *frame,
CC	libavfilter/vaapi_vpp.o
CC	libavfilter/vaf_spectrumsynth.o
CC	libavfilter/vf_addroi.o
CC	libavfilter/vf_alphamerge.o
CC	libavfilter/vf_amplify.o
CC	libavfilter/vf_aspect.o
CC	libavfilter/vf_atadenoise.o
CC	libavfilter/vf_avgblur.o
CC	libavfilter/vf_bbox.o
CC	libavfilter/vf_bilateral.o
CC	libavfilter/vf_bitplanenoise.o
CC	libavfilter/vf_blackdetect.o
CC	libavfilter/vf_blackframe.o
CC	libavfilter/vf_blend.o
CC	libavfilter/vf_bm3d.o
CC	libavfilter/vf_boxblur.o
CC	libavfilter/vf_bwdif.o
CC	libavfilter/vf_cas.o
CC	libavfilter/vf_chromakey.o
CC	libavfilter/vf_chromashift.o
CC	libavfilter/vf_ciescope.o
CC	libavfilter/vf_codecview.o
libavfilter/vf_codecview.c: In function ‘filter_frame’:
libavfilter/vf_codecview.c:223:9: warning: ‘av_frame_get_qp_table’ is deprecated [-Wdeprecated-declarations]
         int8_t *qp_table = av_frame_get_qp_table(frame, &qstride, &qp_type);
In file included from libavfilter/avfilter.h:44,
                 from libavfilter/vf_codecview.c:35:
./libavutil/frame.h:725:9: note: declared here
 int8_t *av_frame_get_qp_table(AVFrame *f, int *stride, int *type);
CC	libavfilter/vf_colorbalance.o
CC	libavfilter/vf_colorchannelmixer.o
CC	libavfilter/vf_colorconstancy.o
CC	libavfilter/vf_colorkey.o
CC	libavfilter/vf_colorlevels.o
CC	libavfilter/vf_colormatrix.o
CC	libavfilter/vf_colorspace.o
CC	libavfilter/vf_convolution.o
CC	libavfilter/vf_convolve.o
CC	libavfilter/vf_copy.o
CC	libavfilter/vf_cover_rect.o
CC	libavfilter/vf_crop.o
CC	libavfilter/vf_cropdetect.o
CC	libavfilter/vf_datascope.o
CC	libavfilter/vf_dblur.o
CC	libavfilter/vf_dctdnoiz.o
CC	libavfilter/vf_deband.o
Ram.Sh
Wed Dec 09, 2020 5:37 pm
the problem was it can't be built on a 64bit os, I had to remove the "arm_64bit=1" in my /boot/config.txt, but then I got other errors ... I'm starting it all from scratch on a fresh ubuntu mate 20.04 64bit on the PI4... its very different from PI OS so every little thing is a battle for me... will update if I'll get it done.
thank you all for your support!
fruitoftheloom
Wed Dec 09, 2020 6:02 pm
arm_64bit=1
So you were running 32bit Userland with 64bit kernel ??
There is a Beta Release which is 64bit Userland and 64bit kernel:
viewtopic.php?f=63&t=275372
Ram.Sh
Wed Dec 09, 2020 6:23 pm
I'll give it a try!!! many thanks for your link!!
Ram.Sh
Wed Dec 09, 2020 10:40 pm
following fruitoftheloom reply, I downloaded the 2020-08-20-raspios-buster-arm64 and installed it.
The FFmpeg ver shipped with this beta is:
pi@Dev64b:~ $ ffmpeg
ffmpeg version 4.1.6-1~deb10u1+rpt1
so moving on to compile the FFmpeg with the needed version, get the code:
go to FFmpeg directory:
cd FFmpeg
install all needed libraries for this build:
sudo apt-get update -qq && sudo apt-get -y install autoconf automake build-essential cmake git-core libass-dev libfreetype6-dev libgnutls28-dev libsdl2-dev libtool libva-dev libvdpau-dev libvorbis-dev libxcb1-dev libxcb-shm0-dev libxcb-xfixes0-dev pkg-config texinfo wget yasm zlib1g-dev libunistring-dev libdrm-dev libopus-dev libvpx-dev libwebp-dev libx264-dev libxml2-dev libfdk-aac-dev libmp3lame-dev
run the configuration script:
./configure \
  --prefix="$HOME/ffmpeg_build" \
  --pkg-config-flags="pkg-config --static" \
  --extra-cflags="-I$HOME/ffmpeg_build/include" \
  --extra-ldflags="-L$HOME/ffmpeg_build/lib" \
  --extra-libs="-lpthread -lm" \
  --bindir="$HOME/bin" \
  --enable-gpl \
  --enable-gnutls \
  --disable-libaom \
  --enable-libass \
  --enable-libfdk-aac \
  --enable-libfreetype \
  --enable-libmp3lame \
  --enable-libopus \
  --enable-libvorbis \
  --enable-libvpx \
  --enable-libx264 \
  --disable-libx265 \
  --enable-nonfree \
  --arch=aarch64 \
  --disable-libxml2 \
  --enable-libwebp \
  --enable-libdrm
and if all went well so far... run the compile command:
 make -j4
and after the compilation ended, I checked the FFmpeg version:
pi@Dev64b:~ $ /home/pi/FFmpeg/ffmpeg
ffmpeg version ca55240 Copyright (c) 2000-2020 the FFmpeg developers
  built with gcc 8 (Debian 8.3.0-6)
  configuration: --prefix=/home/pi/ffmpeg_build --pkg-config-flags='pkg-config --static' --extra-cflags=-I/home/pi/ffmpeg_build/include --extra-ldflags=-L/home/pi/ffmpeg_build/lib --extra-libs='-lpthread -lm' --bindir=/home/pi/bin --enable-gpl --enable-gnutls --disable-libaom --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --disable-libx265 --enable-nonfree --arch=aarch64 --disable-libxml2 --enable-libwebp --enable-libdrm
  libavutil      56. 51.100 / 56. 51.100
  libavcodec     58. 91.100 / 58. 91.100
  libavformat    58. 45.100 / 58. 45.100
  libavdevice    58. 10.100 / 58. 10.100
  libavfilter     7. 85.100 /  7. 85.100
  libswscale      5.  7.100 /  5.  7.100
  libswresample   3.  7.100 /  3.  7.100
  libpostproc    55.  7.100 / 55.  7.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
and a quick test to check if the wanted hardware accelerator works:
/home/pi/FFmpeg/ffmpeg -i /home/pi/final.mp4 -c:v h264_v4l2m2m -b:v 8M -c:a copy test.mp4
video output is as expected and no errors!!
Doug_
Re: [SOLVED] how to install 64 bit FFmpeg?
Fri Dec 18, 2020 6:33 pm
Thanks for posting your solution!
Return to “Advanced users”
