Thanks @Dave Finch for this great example! This is my favorite of all the Minecraft scripts out there already. I’ve update this great tool with a little more Python fancy schmanciness. Made it object oriented and added some functionality with the idea of upgrading the algorithm to generate the maze, make it 3D, and add some funkiness.
I made a command line file for use in the terminal and moved the code to a mazeLib.py. Why? Now I can type the command
in a terminal and build the maze like that or I can build and improve upon the Maze object that lives in mazeLib and debug it from an interactive terminal! I'm on my laptop and ssh'd into my pi so I needed a better debugging setup.
Create the two files below, chdir to /home/pi/mcpi/api/python/mcpi. You need to run code from here to work automatically. IMPORTANT, chmod the mazegenerator file you create to be executable by doing
The two files that need to go in /home/pi/mcpi/api/python/mcpi :
mazegenerator (note: do not use a file extension)
#! /usr/bin/python
# Commandline maze generator for Minecraft Pi edition.
# @author: Jonas Avrin cghijinks@gmail.com
import sys
import traceback
import mazeLib
def main():
'''Create a maze instance.'''
m = mazeLib.Maze(sizex=10, sizey=10, max_wall_len=1, verbose=True)
m.clear()
m.initMaze()
m.generate()
if __name__ == '__main__':
try:
result = main()
except KeyboardInterrupt:
print "Bye"
sys.exit(1)
if result:
sys.exit(0)
elif '--debug' in sys.argv:
print traceback.sys.exc_info()
else:
sys.exit(1)
mineLib.py
Created on Feb 18, 2013
@originalAuthor: Dave Finch
import minecraft
import block
import random
from random import randint as rand
class Maze(object):
def __init__(self, **kwargs):
self.verbose = kwargs.setdefault('verbose', False)
# Connect to minecraft :)
self.mc = self.connect()
self.maze = []
self.spl = []
# Define the X and Y size of the maze including the outer walls.
self.sizex = kwargs.get('sizex', None)
self.sizey = kwargs.get('sizey', None)
self.dimms = ()
if self.sizex and self.sizey:
self.dimms = (self.sizex, self.sizey)
else:
self.sizex = kwargs.setdefault('sizex', 21)
self.sizey = kwargs.setdefault('sizey', 21)
if self.verbose:
print '# MAZE DIMMS #\n' \
+ 'sizex: %d sizey: %d:' % (self.sizex, self.sizey)
# Set maximum length of wall
self.max_wall_len = kwargs.setdefault('max_wall_len', 1)
# Find position of player and set base of maze 3 blocks lower.
self.ppos = self.mc.player.getPos()
self.ppos.y -= 3
@property
def dimms(self):
return self.sizex, self.sizey
@dimms.setter
def dimms(self, val):
if not isinstance(val, tuple):
raise TypeError('Dimensions value type must be a tuple(x, y)')
for v in val:
if not self.isodd(v):
self.sizex, self.sizey = [v + 1 for v in val]
else:
self.sizex, self.sizey = [v for v in val]
def isodd(self, num):
return num & 1 and True or False
def create(self):
# Create an empty maze.
self.clear()
self.initMaze()
@staticmethod
def connect():
# Connect to Minecraft.
try:
mc = minecraft.Minecraft.create()
return mc
except:
raise RuntimeError('Minecraft unavailable.')
def clear(self):
# Clear an area for the maze.
for x in xrange(0, self.sizex - 1):
for z in xrange(self.sizey - 1):
self.mc.setBlock(self.ppos.x + x, self.ppos.y, self.ppos.z + z,
block.STONE)
for y in xrange(1, 6):
self.mc.setBlock(self.ppos.x + x, self.ppos.y + y,
self.ppos.z + z, block.AIR)
# Create a function to initialize the maze.
def initMaze(self):
# print player position
if self.verbose:
print 'player pos: %r' % self.ppos
# Create a 2 dimensional array.
self.maze = [[0] * self.sizey for x in xrange(self.sizex)]
# print the maze
if self.verbose:
colsize = 0
for m in self.maze:
print ''.join(('%-*s' % (colsize + 3, i) for i in m))
# Create four walls around the maze.
# 1=wall, 0=walkway.
for x in xrange(0, self.sizex):
self.maze[x][0] = self.maze[x][self.sizey - 1] = 1
self.makeWall(self.ppos.x + x, self.ppos.z + 0)
self.makeWall(self.ppos.x + x, self.ppos.z + self.sizey - 1)
for y in xrange(0, self.sizey):
self.maze[0][y] = self.maze[self.sizex - 1][y] = 1
self.makeWall(self.ppos.x, self.ppos.z + y)
self.makeWall(self.ppos.x + self.sizex - 1, self.ppos.z + y)
# Make every other cell a starting point.
# 2=starting point.
# Also create a list of these points to speed up the main loop.
for y in xrange(2, self.sizey - 1, 2):
for x in xrange(2, self.sizex - 2, 2):
self.maze[x][y] = 2
self.spl.append((x, y))
# print the initialized maze
if self.verbose:
colsize = 0
print 'maze initialized: \n'
for m in self.maze:
print '\n', 'rand spl: %r' % self.spl
# Shuffle the list of points and we can choose a random point by
# simply "popping" it off the list.
random.shuffle(self.spl)
if self.verbose:
print 'rand spl: %r' % self.spl
# Create a function for picking a random direction.
def randDir(self):
r = rand(0, 3)
# Up.
if r == 0:
rv = (0, -1)
# Down.
if r == 1:
rv = (0, 1)
# Left.
if r == 2:
rv = (-1, 0)
# Right.
if r == 3:
rv = (1, 0)
return rv
def generate(self):
# Loop until we have no more starting points (2's in the empty maze)
while filter(lambda x: 2 in x, self.maze):
# Get the X and Y values of the first point in our randomized list.
rx = self.spl[0][0]
ry = self.spl[0][1]
# Pop the first entry in the list, this deletes it,
# the rest move down.
self.spl.pop(0)
# Check to see if our chosen point is still a valid starting point.
ud = False
if self.maze[rx][ry] == 2:
ud = True
# Pick a random wall length up to the maximum.
rc = rand(0, self.max_wall_len)
# Pick a random direction.
rd = self.randDir()
fc = rd
loop = True
while loop:
# Look in each direction, if the current wall being built
# is stuck inside itself start again.
if (self.maze[rx][ry - 2] == 3 and
self.maze[rx][ry + 2] == 3 and
self.maze[rx - 2][ry] == 3 and
self.maze[rx + 2][ry] == 3):
# Code to clear maze area required
self.initMaze(self.sizex, self.sizey)
break
# Look ahead to see if we're okay to go in this direction.
cx = rx + (rd[0] * 2)
cy = ry + (rd[1] * 2)
nc = self.maze[cx][cy]
if nc != 3:
for i in xrange(0, 2):
self.maze[rx][ry] = 3
self.makeWall(self.ppos.x + rx, self.ppos.z + ry)
rx += rd[0]
ry += rd[1]
# .....if not choose another direction.
else:
rd = self.randDir()
# If we hit an existing wall break out of the loop.
if nc == 1:
loop = False
# Update our wall length counter.
# When this hits zero pick another direction.
# This also makes sure the new direction
# isn't the same as the current one.
rc -= 1
if rc <= 0:
dd = rd
de = (fc[0] * -1, fc[1] * -1)
while dd == rd or rd == de:
rd = self.randDir()
# The latest wall has been built so
# change all 3's (new wall) to 1's (existing wall)
if ud:
if self.maze[x][y] == 3:
self.maze[x][y] = 1
def makeWall(self, x, z):
self.mc.setBlock(x, self.ppos.y, z, block.STONE)
self.mc.setBlock(x, self.ppos.y + 1, z, block.STONE)
self.mc.setBlock(x, self.ppos.y + 2, z, block.STONE)
I tried to make a couple improvements by adding in some parameters to control the width, height, max wall size, and turning verbose on and off.
Here's an example of what you can do:
In the /home/pi/mcpi/api/python/mcpi directory launch python by typing python and just look at my terminal below to get an idea.
pi@raspberrypi ~/mcpi/api/python/mcpi $ python
Python 2.7.3 (default, Jan 13 2013, 11:20:46)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import mazeLib
>>> m=mazeLib.Maze(sizex=10, sizey=10, max_wall_len=1)
>>> m.dimms
(11, 11)
>>> m.create()
>>> m.verbose = True
>>> m.create()
player pos: Vec3(9.91611,0.99797,36.0579)
0 0 0 0 0 0 0 0 0 0 0
maze initialized:
1 1 1 1 1 1 1 1 1 1 1
1 0 0 0 0 0 0 0 0 0 1
1 0 2 0 2 0 2 0 2 0 1
rand spl: [(2, 6), (8, 2), (6, 2), (2, 8), (6, 4), (8, 4), (8, 6), (4, 4), (2, 2), (6, 8), (4, 8), (6, 6), (8, 8), (4, 6), (2, 4), (4, 2), (2, 2), (4, 2), (6, 2), (8, 2), (2, 4), (4, 4), (6, 4), (8, 4), (2, 6), (4, 6), (6, 6), (8, 6), (2, 8), (4, 8), (6, 8), (8, 8)]
rand spl: [(8, 4), (8, 2), (4, 4), (4, 2), (8, 2), (6, 4), (4, 8), (2, 8), (2, 2), (4, 8), (4, 6), (2, 8), (4, 2), (6, 6), (2, 6), (8, 4), (8, 6), (4, 4), (8, 8), (6, 2), (6, 8), (2, 4), (6, 6), (8, 6), (2, 6), (6, 4), (6, 2), (2, 4), (2, 2), (6, 8), (4, 6), (8, 8)]
>>> m.generate()
Explanation:
Instance of Maze is created with some custom sizing. You can call it with no arguments and it still works with some built in defaults.
The Maze object has a computed attribute called dimms, short for dimensions
Change the dimms attribute by setting it with another tuple or query it
>>> m.dimms
(11, 11)
m.dimms = (20, 20)
>>> m.dimms
(21, 21)
Q: Why is this spitting out 21 instead of 20? A: The computed attribute checks to see if the number given is even and spits out an odd number. Quick explanation is that it makes it cleaner to do some computations with other functions to actually generate the maze and may help later when extending the object, I'm not sure on that part yet.
This is a method that can be called that just makes it easier to create the maze by combining some of the functions that do the actual building. It initializes it but doesn't do the generating algorithm to actually fill in the maze.
Turn verbose on/off interactively for debugging purposes.
The create method is being called with verbose on. Notice, the formatted printing to better visualize what's happening with the 2d array.
>>> m.create()
maze initialized:
Turn verbose back off:
Generate the maze interior (run the algorithm to make the maze).
That's it! I hope that explains what I did and hopefully it looks a bit cleaner and gives you some alternatives to how you can run scripts in minecraft. I am a bit perplexed as to how thrown together some of the scripts are out there, have a look at PEP8
http://www.python.org/dev/peps/pep-0008/ people! It sounds nit-picky but one of the most important ideas Python was written with is the idea of legible code. That's not to say the original wasn't legible, now it's just more legible!
Have fun debugging and extending the maze! I know I will.
I was having a look at some other maze algorithms like random walk as alternative methods. A 3D maze would be outstanding as well!
