I have a Rpi2 with Raspbian. I use it only via command line. Actually I have a problem with locale, I post the output of some commands:
and if I launch "sudo raspi-config" and choose the "Internationalisation Options" then "change locale" I get this error:
pi@raspberrypi ~ $ locale
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANG=en_GB.UTF-8
LANGUAGE=
LC_CTYPE="en_GB.UTF-8"
LC_NUMERIC="en_GB.UTF-8"
LC_TIME="en_GB.UTF-8"
LC_COLLATE="en_GB.UTF-8"
LC_MONETARY="en_GB.UTF-8"
LC_MESSAGES="en_GB.UTF-8"
LC_PAPER="en_GB.UTF-8"
LC_NAME="en_GB.UTF-8"
LC_ADDRESS="en_GB.UTF-8"
LC_TELEPHONE="en_GB.UTF-8"
LC_MEASUREMENT="en_GB.UTF-8"
LC_IDENTIFICATION="en_GB.UTF-8"
LC_ALL=
pi@raspberrypi ~ $ locale -a
locale: Cannot set LC_COLLATE to default locale: No such file or directory
C
C.UTF-8
POSIX
pi@raspberrypi ~ $ sudo apt-get install locales
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
locales : Depends: glibc-2.13-1
Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
E: Unable to correct problems, you have held broken packages.
pi@raspberrypi ~ $ sudo dpkg-reconfigure locales
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
/usr/sbin/dpkg-reconfigure: locales is broken or not fully installed
"There was an error running option I1 Change Locale" and this is the output:
sudo raspi-config
LANGUAGE = (unset),
LC_ALL = (unset),
I don't know what can I do, I suppose that the problem could be in the /etc/apt/sources.list
but I don't know how I can change it.deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb http://archive.mene.za.net/raspbian wheezy contrib
Please help me!
Thank you all!
