Clues below:
https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux
Charles J. Cliffe edited this page Apr 1, 2016 · 28 revisions
Pages 8
Building CubicSDR for Linux:
Basic build support: (debian)
$ sudo apt-get install git build-essential automake cmake
Base Dependencies: (debian)
$ sudo apt-get install libpulse-dev libgtk-3-dev
If you didn't install your own OpenGL driver/headers (via Nvidia, AMD binaries or other) this will bring in the appropriate libs and headers:
$ sudo apt-get install freeglut3 freeglut3-dev
Build and install SoapySDR
$ git clone
https://github.com/pothosware/SoapySDR.git
$ cd SoapySDR
SoapySDR$ mkdir build
build$ cd build
build$ cmake ../ -DCMAKE_BUILD_TYPE=Release
build$ make -j4
build$ sudo make install
build$ sudo ldconfig
build$ SoapySDRUtil --info #test SoapySDR install
Build and install liquid-dsp
$ git clone
https://github.com/jgaeddert/liquid-dsp
liquid-dsp$ cd liquid-dsp
liquid-dsp$ ./bootstrap.sh
liquid-dsp$ ./configure --enable-fftoverride
liquid-dsp$ make -j4 #*lots of gcc errors
liquid-dsp$ sudo make install
/root/radio/cubicsdr/liquid-dsp (/dev/pts/0) # make install
installing...
mkdir -p /usr/local/lib
mkdir -p /usr/local/include/liquid
install -m 644 -p libliquid.so libliquid.a /usr/local/lib
install -m 644 -p include/liquid.h /usr/local/include/liquid
liquid-dsp was successfully installed.
On some machines (e.g. Linux) you should rebind your
libraries by running 'ldconfig' to make the shared
object available. You might also need to modify your
LD_LIBRARY_PATH environment variable to include the
directory /usr/local
Please report bugs to
[email protected]
liquid-dsp$ sudo ldconfig
Build static wxWidgets:
Note: replace '~/Develop/wxWidgets-staticlib' with your own path if you prefer, remember it to be used later when building CubicSDR.
$ wget
https://github.com/wxWidgets/wxWidgets/ ... .0.tar.bz2
[ downloading.. ]
$ tar -xvjf wxWidgets-3.1.0.tar.bz2
[ unpacking.. ]
$ cd wxWidgets-3.1.0/
wxWidgets-3.1.0$ mkdir -p ~/Develop/wxWidgets-staticlib
wxWidgets-3.1.0$ ./autogen.sh
wxWidgets-3.1.0$ ./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/Develop/wxWidgets-staticlib` CXXFLAGS="-std=c++0x" --with-libiconv=/usr
[ configuring.. ]
wxWidgets-3.1.0$ make -j4 && make install
[ building and installed to ~/Develop/wxWidgets-staticlib in this example ]
Build CubicSDR
Note: add -DUSE_HAMLIB=1 to cmake command line to include hamlib support.
This will require installing hamlib packages:
Run-time library to control radio transceivers: libhamlib2
Utilities to support the hamlib radio control library: libhamlib-utils
Development library to control radio transceivers: libhamlib++-dev
Run-time library to control radio transceivers: ibhamlib2++c2*Unable to locate package ibhamlib2++c2
Development library to control radio transceivers: libhamlib-dev
Documentation for hamlib library providing a standardised programming
interface: libhamlib-doc
This package provides the perl bindings of the library: libhamlib2-perl* not installed
This package provides the Tcl bindings of the library: libhamlib2-tcl* not installed
This package provides the Python bindings of library: python-libhamlib2
apt-get install libhamlib2 libhamlib-utils libhamlib++-dev libhamlib-dev libhamlib-doc python-libhamlib2
The following NEW packages will be installed:k
libhamlib++-dev libhamlib-dev libhamlib-doc libhamlib-utils libhamlib2
libhamlib2++c2 libusb-dev python-libhamlib2
The following extra packages will be installed:
$ git clone
https://github.com/cjcliffe/CubicSDR.git
CubicSDR$ cd CubicSDR
CubicSDR$ mkdir build
CubicSDR$ cd build
build$ cmake ../ -DUSE_HAMLIB=1 -DCMAKE_BUILD_TYPE=Release -DwxWidgets_CONFIG_EXECUTABLE=~/Develop/wxWidgets-staticlib/bin/wx-config
build$ cmake ../ -DCMAKE_BUILD_TYPE=Release -DwxWidgets_CONFIG_EXECUTABLE=~/Develop/wxWidgets-staticlib/bin/wx-config
build$ make
# You can now run the build from the folder, note if you're on 32-bit linux it will be in x86/
build$ cd x64/./CubicSDR: not found
x64$ ./CubicSDR*
Install CubicSDR (and launcher)
Un-install CubicSDR
build$ sudo make uninstall
Support Modules
SoapyRTLSDR (similar to other Soapy modules):
$ sudo apt-get install librtlsdr-dev
$ git clone
https://github.com/pothosware/SoapyRTLSDR.git
$ cd SoapyRTLSDR
SoapyRTLSDR$ mkdir build
SoapyRTLSDR$ cd build
build$ cmake .. -DCMAKE_BUILD_TYPE=Release
build$ make
# should now show RTL-SDR device if connected
build$ SoapySDRUtil --probe
SoapySDRPlay (similar to other Soapy modules):
** Note: requires API from
http://sdrplay.com/linux.html to be installed first.
** Also note that the SoapySDRPlay installer will at present time install an earlier SoapySDR binary -- please re-run 'sudo make install' for your SoapySDR build folder to update to the build version after installing.
$ git clone
https://github.com/pothosware/SoapySDRPlay.git
$ cd SoapySDRPlay
SoapySDRPlay$ mkdir build
SoapySDRPlay$ cd build
build$ make
Always ensure to update, build and install SoapySDR before building dependent projects.
Ubuntu 15.10 Note:
If you've installed a graphics driver that includes OpenGL and your libGL.so currently points to an invalid mesa/libGL.so you may get a compiler error:
make[2]: *** No rule to make target '/usr/lib/x86_64-linux-gnu/libGL.so', needed by 'x64/CubicSDR'. Stop.
Checking the link should reveal that it's pointing at a deleted file:
$ ls -lah /usr/lib/x86_64-linux-gnu/libGL.so
lrwxrwxrwx 1 root root 13 Oct 9 01:16 /usr/lib/x86_64-linux-gnu/libGL.so -> mesa/libGL.so
To fix the link first remove the old one:
$ sudo rm /usr/lib/x86_64-linux-gnu/libGL.so
Then check where libGL.so.1 is pointing:
$ ls -lah /usr/lib/x86_64-linux-gnu/libGL.so.1
lrwxrwxrwx 1 root root 15 Dec 20 19:03 /usr/lib/x86_64-linux-gnu/libGL.so.1 -> libGL.so.358.16
And create a new link to the same location:
$ sudo ln -s /usr/lib/x86_64-linux-gnu/libGL.so.358.16 /usr/lib/x86_64-linux-gnu/libGL.so
mkdir cubicsdr && cd cubicsdr
git clone
cd SoapySDR
mkdir build && cd build
make -j4
make install
ldconfig
cd ..
git clone
cd liquid-dsp
./bootstrap.sh
make -j4
make install
ldconfig
cd ..
wget
cd wxWidgets-3.1.0/
./autogen.sh
cd ..
git clone
cd CubicSDR
make
cd x86/
./CubicSDR
make install
cd ..
git clone
cd SoapyRTLSDR
# mkdir: cannot create directory ‘build’: File exists
make
make install
ldconfig
/root/radio/cubicsdr/CubicSDR/build/x86/CubicSDR
Here's how to successfully build CubicSDR under Debian Jessie on the Raspberry Pi3.
The script below was adapted from the information on this page <
https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux>, and reflects the commands that resulted in the successful build.
# Building CubicSDR for Linux
# This script will successfully build CubicSDR under Debian Jessie on the Raspberry Pi3.
# Adapted from https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux
# Larry Dighera June 7, 2016
# [email protected]
git clone https://github.com/pothosware/SoapySDR.git
cd SoapySDR
make -j4
make install
ldconfig
cd ..
git clone https://github.com/jgaeddert/liquid-dsp
cd liquid-dsp
./bootstrap.sh
make -j4
make install
ldconfig
cd ..
wget https://github.com/wxWidgets/wxWidgets/releases/download/v3.1.0/wxWidgets-3.1.0.tar.bz2
cd wxWidgets-3.1.0/
./autogen.sh
cd ..
git clone https://github.com/cjcliffe/CubicSDR.git
cd CubicSDR
make
cd x86/
./CubicSDR
make install
cd ..
git clone https://github.com/pothosware/SoapyRTLSDR.git
cd SoapyRTLSDR
cd build
make
make install
ldconfig
CubicSDR seems to use about 85% of the CPU cycles, and may be reduced about 10% in the CubicSDR Settings drop-down menu.
