Hi
i want use raspberry pi 3 for router in network plz help me :
1-Where do I download openwrt for raspberry pi 3 ?
i can't find this link :
https://wiki.openwrt.org/toh/start
2-how install openwrt on raspberry pi 3 ?
3-how after install openwrt on raspberry pi 3 change single lan to wan (dhcp client)?
4-how enable wifi and change wifi mode to AP and share internet ?
plz help me.
thanks
Re: How install LEDE/OpenWRT On Raspberry Pi 3 Model B ?
I'd start here and see how you get on.
https://wiki.openwrt.org/toh/raspberry_ ... spberry_pi
this page for raspberry pi 1 & 2 but no support raspberry pi 3 B !321 wrote:I'd start here and see how you get on.
where is download openwrt for raspberry pi 3 ?
http://downloads.openwrt.org/snapshots/ ... 08/generic
openwrt-brcm2708-bcm2708-rpi-ext4-sdcard.img
An image file needs to be written to SD Card, try using https://etcher.io
That didn't work for me, on Pi3.fruitoftheloom wrote:http://downloads.openwrt.org/snapshots/ ... 08/generic
But this did
https://downloads.lede-project.org/rele ... ard.img.gz
Info about Rasberry Pi 3b: https://lede-project.org/toh/hwdata/ras ... errypi_3_b
At the bottom, the link to the image.
Regards.
Regards.
1. https://downloads.openwrt.org/releases/ ... ory.img.gz
2. https://etcher.io/
3. network: (lan to wan)
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd8a:0abc:79d8::/48'
config interface 'lan'
option type 'bridge'
option ipaddr '192.168.1.3'
option netmask '255.255.255.0'
option ip6assign '60'
config interface 'wan'
option proto 'dhcp'
option ifname 'eth0'
option peerdns '0'
option dns '8.8.8.8'
4. wireless:
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option hwmode '11g'
option path 'platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1'
option htmode 'HT20'
option country '00'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'RPi3'
option encryption 'psk2+ccmp'
option key '12345678'
option ifname 'lo'
option proto 'dhcp'
option peerdns '0'
4. wireless:
option channel '11'
option hwmode '11g'
option country '00'
option mode 'ap'
option ssid 'RPi3'
https://youtu.be/lYvtQ0EP9Fg
Check out my video about how to install openwrt on raspberry pi 3 model b.
This video will help you to install and configure openwrt on raspberry pi.
Thanks & Regards
Mr. PcMac
Great video PcMac.
Be aware though that if you are using etcher to flash and OS image onto an SD card it is not necessary to format that SD card first. Etcher will simply overwrite whatever formatting is on there to start with.
Slava Ukrayini.
