Spajk
Running headless chromium and chromedriver
Wed Sep 27, 2017 6:20 pm
Hi, I am having problems getting this to work. More specifically, I can't get chromedriver to work.
Do I have to compile everything from scratch?
chgruem
Re: Running headless chromium and chromedriver
Wed Oct 04, 2017 7:32 pm
Since the chromedriver is not in the official raspbian repository, you have to get it from here: https://packages.debian.org/stretch/arm ... r/download
Unpack the file "chromedriver" from the archive to /usr/local/bin
Then follow these steps:
sudo chmod +x /usr/local/bin/chromedriver
sudo apt-get install libminizip1
sudo apt-get install libwebpmux2
If you are on Raspbian Stretch Lite (no desktop environment) you also have to install this package:
sudo apt-get install libgtk-3-0
In your code add these two arguments, when you start the driver:
-headless
-disable-gpu
See also my code below, section //Headless?:
using System;
using OpenQA.Selenium.Chrome;
namespace WiControlForConnectBox.Selenium
	public class LibChrome : LibConnectBox
		public LibChrome (bool HeadlessMode)
			//Optionen einstellen
			var options = new ChromeOptions();
			options.AddArgument(@"disable-translate");
			options.AddArgument(@"disable-infobars");
			//Headless?
			if (HeadlessMode)
				options.AddArgument(@"headless");
				options.AddArgument(@"disable-gpu");
				options.AddArgument(@"window-size=1024,768");
			//Treiber starten (chromedriver muss in /usr/local/bin kopiert werden)
			var driver = new ChromeDriver(options);
			//Timeout festlegen
			driver.Manage().Timeouts().ImplicitWait = TimeSpan.FromSeconds(30);
			//Treiber eintragen
			base.Driver = driver;
Best regards,
chgruem
multifractal
Tue Feb 20, 2018 11:28 pm
@chgruem, Thank you very much for this answer.
I've been searching for a way to set up selenium in my Raspberry for hours.
This was amazing, thank you
Mr-Programs
Sun Oct 14, 2018 11:51 pm
so one thing is that your code seems to be... C#?
using with python Ive been trying to achieve headless scrapping on raspberry pi 3 b+
Ive been following this steps which is unfortunately a closed thread
https://www.reddit.com/r/selenium/comme ... driver_on/
somebody told me i need to put chromium and chromedriver on the same folder??? im actually confused in many aspects
also...
might sound lame but since i did a
sudo mv /usr/lib/chromium-browser/chromedriver /usr/bin/chromedriver
does this mean
driver = webdriver.Chrome('/usr/lib/chromium-browser/chromedriver')
becomes
driver = webdriver.Chrome('chromedriver')
? OR
driver = webdriver.Chrome()
girard
Thu Apr 02, 2020 3:08 am
Apparently the chromium-chromedriver is avaible through apt-get is the only solution that has worked for me. I guess it's easier because the package manager matches the versions [?]... not sure, but it worked.
sudb97
Thu Dec 17, 2020 9:21 am
Thanks your solution worked.
Note: 1. Install chromium-chromedriver using apt-get. i.e apt-get install chromium-chromedriver
2. check the path of chromedriver using "whereis chromedriver"
3. Use the path that is fetched in the above step in your code.
Hope it helps to simplify.
