vajra11
Installation of Mysql connector on Pi
Mon Jul 16, 2018 5:57 am
I want to send data from raspberry pi to MySQL database server running on windows. I am trying to connect to it from a python module.
I need to install packages on raspberry. I spent an hour to find correct packages to connect Mysql database
This is packages I think needs to be installed on raspberry Pi
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install mysqldb
sudo apt-get -y install python-mysql.connector
pip install mysql-python
Am I missing any packages to connect Mysql Database
Re: Installation of Mysql connector on Pi
Mon Jul 16, 2018 7:33 am
That apt install and your pip install are both installing the same piece. Choose one or the other.
You also need to ensure your MySQL/MariaDB server is binding to the 0.0.0.0 address to allow remote connections.
vajra11
Mon Jul 16, 2018 9:53 am
Is it what you are saying
sudo apt-get install mysql-python
sudo apt-get  install python-mysql.connector
suso apt-get install pymysql
Mon Jul 16, 2018 11:46 am
Yes.
vajra11
Mon Jul 16, 2018 12:36 pm
Yes
Thanks @DougieLawson I am following this blog https://howtoraspberrypi.com/enable-mys ... pberry-pi/ to enable remote connection to MySQL server on windows laptop.
I followed up to flush privileges; step. I am struggling after that, I think I have to configure MySQL database installed on window to allow remote connection. In blog there is sudo command and but sudo command doesn't work on windows.
welcome for your any advice
Mon Jul 16, 2018 6:54 pm
Sorry I don't know how MySQL works (or fails) on Windows, I've never dreamt of running it on anything other than Linux.
vajra11
Thu Jul 19, 2018 2:13 pm
I followed the instruction for binding address.
then I check remote connection with below program
Do you see anything wrong in program
import MySQLdb
db = MySQLdb.connect(host="192.168.0.105",  # your host
                     user="vajra",       # username
                     passwd="vajra11",     # password
                     db="temp1")   # name of the database
# Create a Cursor object to execute queries.
cur = db.cursor()
# Select data from table using SQL query.
cur.execute("SELECT * FROM examples")
# print the first and second columns
for row in cur.fetchall() :
    print row[0], " ", row[1]
What is this error
Thu Jul 19, 2018 2:51 pm
Stop using MySQLdb switch to mysql.connector.
sudo apt install python{,3}-mysql.connector
https://dev.mysql.com/doc/connector-pyt ... mples.html
It works much the same as MySQLdb.
import mysql.connector
db = mysql.connector.connect(user='vajra', password='vajra11',
                              host='192.168.0.105',
                              database='temp1')
# ... rest of stuff as before goes here ...
vajra11
Thu Jul 19, 2018 5:00 pm
That's not supporting
  File "dbtest1.py", line 5, in <module>
    database='temp1')
  File "/usr/lib/python3/dist-packages/mysql/connector/__init__.py", line 179, in connect
    return MySQLConnection(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/mysql/connector/connection.py", line 94, in __init__
    self.connect(**kwargs)
  File "/usr/lib/python3/dist-packages/mysql/connector/abstracts.py", line 722, in connect
    self._open_connection()
  File "/usr/lib/python3/dist-packages/mysql/connector/connection.py", line 211, in _open_connection
    self._ssl)
  File "/usr/lib/python3/dist-packages/mysql/connector/connection.py", line 141, in _do_auth
    auth_plugin=self._auth_plugin)
  File "/usr/lib/python3/dist-packages/mysql/connector/protocol.py", line 102, in make_auth
    auth_data, ssl_enabled)
  File "/usr/lib/python3/dist-packages/mysql/connector/protocol.py", line 58, in _auth_response
    auth = get_auth_plugin(auth_plugin)(
  File "/usr/lib/python3/dist-packages/mysql/connector/authentication.py", line 191, in get_auth_plugin
    "Authentication plugin '{0}' is not supported".format(plugin_name))
mysql.connector.errors.NotSupportedError: Authentication plugin 'caching_sha2_password' is not supported
pi@raspberrypi:~/temp1 $ sudo python3 dbtest1.py
    database='temp1')
    self._ssl)
Thu Jul 19, 2018 5:09 pm
Try
sudo apt purge python{,3}-mysql*
sudo pip install mysql-connector-python
sudo pip3 install mysql-connector-python
# if using python3.
The old junk in DebIan Stretch doesn't support the new authentication scheme.
vajra11
Thu Jul 19, 2018 6:04 pm
Try
# if using python3.
Tried
pi@raspberrypi:~/temp1 $ python dbtest1.py
    database='temp1')
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/__init__.py", line 183, in connect
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 100, in __init__
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/abstracts.py", line 736, in connect
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 246, in _open_connection
    self._ssl)
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 166, in _do_auth
    self._auth_switch_request(username, password)
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 210, in _auth_switch_request
    raise errors.get_exception(packet)
mysql.connector.errors.ProgrammingError: 1049 (42000): Unknown database 'temp1'
Thu Jul 19, 2018 6:11 pm
That's an improvement, you're past the authentication error. You now need to ensure that your userid is allowed to make remote connections and can access your "temp1" database.
https://stackoverflow.com/questions/162 ... ote-access
vajra11
Fri Jul 20, 2018 9:48 am
following are the steps I have done for remote connection
Enter password: ******
CREATE USER 'database1'@'localhost' IDENTIFIED BY 'db123';
CREATE USER 'database1'@'%' IDENTIFIED BY 'db123';
GRANT ALL ON *.* TO 'database1'@'localhost';
GRANT ALL ON *.* TO 'database1'@'%';
create database test3;
use test3;
CREATE TABLE tablename ( id int unsigned not null auto_increment, name varchar(20) not null, constraint pk_example primary key (id) );
INSERT INTO tablename ( id, name ) VALUES ( null, 'Sample data' );
describe tablename;
program
db = mysql.connector.connect(user='database1', password='db123',
                              host='192.168.0.104',
                              database='temp3')
cur = db.cursor()
cur.execute("SELECT * FROM tablename")
output error
  File "dbtest1.py", line 10, in <module>
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/cursor.py", line 566, in execute
    self._handle_result(self._connection.cmd_query(stmt))
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 537, in cmd_query
    result = self._handle_result(self._send_cmd(ServerCmd.QUERY, query))
  File "/usr/local/lib/python2.7/dist-packages/mysql/connector/connection.py", line 436, in _handle_result
mysql.connector.errors.ProgrammingError: 1146 (42S02): Table 'temp3.tablename' doesn't exist
DirkS
Fri Jul 20, 2018 10:23 am
Having a quick look at the code / messages...
I see both temp3 and test3 as the database name...
You create test3 and try to connect to temp3
vajra11
Fri Jul 20, 2018 11:49 am
Thanks for catching error. Thanks DougieLawson I appreciate your effort and help
I don't have much knowledge on Mysql programming. My first priority was setting remote connection. I just checking remote connection with sample program. I would learn by writing simple program
I am not sure but I think remote connection has been successfully.
1 Sample data
ivaring
Mon Jan 13, 2020 8:56 pm
Hi there,
I'm trying of getting connected Arduino and Raspberry devices.
The idea is having some kind of access control from Arduino then sending data to a mysql server installed on Raspberry (already working).
The question is how to install new libraries on Raspbian Arduino IDE in order to get this working, then creating necessary databases and sending data as needed.
