Here is the header I use with all the functions.
// Header for using the pi plates. It's not as complete as it could be
// but its a good start. It relies on the wiringPi.h and wiringPiSPI.h headers
// at the start of the code the PiPlateInitialize() function must be called to
// set up the spi, then the functions are very similar to they used in the python code
#define GPIObaseADDR 8
#define RELAYbaseADDR 24
#define ppFRAME 25
#define ppINT 22
#define PiPlatesComLine 1
#define PiPlatesComFreq 250000
#pragma once
#include <stdio.h> /// IO functions
#pragma once
#include <stdbool.h> /// Boolean type and values
#pragma once
#include <unistd.h> /// Used to fork and pipe
#pragma once
#include <wiringPi.h> /// for GPIO for raspberry
#pragma once
#include <wiringPiSPI.h>
volatile double PiPlatesDACVcc = 0;
/// Basic Pi Plates Functions ///
/// Initializes the pi plate by setting up the SPI com ///
void PiPlateInitialize()
wiringPiSetupGpio();
pinMode(ppFRAME, OUTPUT);
pinMode(ppINT, INPUT);
pullUpDnControl(ppINT, PUD_UP);
wiringPiSPISetup(PiPlatesComLine, PiPlatesComFreq);
/// The way all the DAC functions talk to the DAC pi plates ///
void ppCMD(char addr, char cmd, char param1, char param2, char bytes2return, char *resp)
char arg[4], i;
arg[0] = addr + GPIObaseADDR;
arg[1] = cmd;
arg[2] = param1;
arg[3] = param2;
digitalWrite(ppFRAME, HIGH);
wiringPiSPIDataRW(PiPlatesComLine, arg, 4);
if(bytes2return>0)
usleep(100);
for(i=0;i<bytes2return;++i)
wiringPiSPIDataRW(PiPlatesComLine, &resp[i], 1);
usleep(1);
digitalWrite(ppFRAME, LOW);
return;
/// The way all the Relay functions talk to the relay pi plates ///
void ppCMDr(char addr, char cmd, char param1, char param2, char bytes2return, char *resp)
char arg[4], i;
arg[0] = addr + RELAYbaseADDR;
arg[1] = cmd;
arg[2] = param1;
arg[3] = param2;
if(bytes2return>0)
usleep(100);
usleep(1000);
usleep(1000);
return;
/// DAC Functions ///
/// ADC Functions ///
// Return voltage from single channel. Reading channel 8 will return the 5VDC power supply voltage. //
double PiPlatesDAC_getADC(char addr, char channel)
char resp[2] = {0};
ppCMD(addr, 0x30, channel, 0, 2, resp);
return (256.0*resp[0] + resp[1])*4.096/1024;
// Puts voltage from all channels into Val //
void PiPlatesDAC_getADCall(char addr, double Val[8])
char resp[16] = {0}, i;
ppCMD(addr, 0x31, 0, 0, 16, resp);
for(i=0;i<8;++i)
Val[i] = (256.0*resp[2*i] + resp[2*i+1])*4.096/1024.0;
/// Digital Input Functions (missing interrupt functions) ///
// Returns single bit value //
bool PiPlatesDAC_getDINbit(char addr, char bit)
char resp = 0;
ppCMD(addr, 0x20, bit, 0, 1, &resp);
usleep(1);
return resp == 1 ? true : false;
// Returns all eight bits //
char PiPlatesDAC_getDINall(char addr)
char resp = 0;
ppCMD(addr, 0x25, 0, 0, 1, &resp);
usleep(1);
return resp;
/// LED functions ///
// Turn on one of the LEDs in the bicolor LED package (0 - red, 1 - green) //
#define PiPlatesDAC_setLED(addr, led) ppCMD(addr, 0x60, led, 0, 0, NULL); usleep(1);
// Turn off one of the LEDs in the bicolor LED package //
#define PiPlatesDAC_clrLED(addr, led) ppCMD(addr, 0x61, led, 0, 0, NULL); usleep(1);
// Toggle off one of the LEDs in the bicolor LED package //
#define PiPlatesDAC_toggleLED(addr, led) ppCMD(addr, 0x62, led, 0, 0, NULL); usleep(1);
// Returns the status of the LEDs in the bicolor LED package //
char PiPlatesDAC_getLED(int addr, int led)
char resp = 0;
ppCMD(addr, 0x63, led, 0, 1, &resp);
return resp;
/// Switch Functions WIP///
/// Digital Output Functions ///
// Set single bit //
#define PiPlatesDAC_setDOUTbit(addr, bit) ppCMD(addr, 0x10, bit, 0, 0, NULL); usleep(100)
// Clear single bit ///
#define PiPlatesDAC_clrDOUTbit(addr, bit) ppCMD(addr, 0x11, bit, 0, 0, NULL); usleep(100)
// Toggle a single bit //
#define PiPlatesDAC_toggleDOUTbit(addr, bit) ppCMD(addr, 0x12, bit, 0, 0, NULL); usleep(100)
// Control all seven bits at once. The byte value must be in the range of 0 through 127 ///
#define PiPlatesDAC_setDOUTall(addr, bit) ppCMD(addr, 0x13, bit, 0, 0, NULL); usleep(100)
// Return the status of the ouput bit //
char PiPlatesDAC_getDOUTbyte(char addr)
char resp = 0;
ppCMD(addr, 0x14, 0, 0, 1, &resp);
usleep(1);
return resp;
/// PWM and DAC Output Functions ///
// Set PWM signal from 0 to 1023 (0 to 100%) //
void PiPlatesDAC_setPWM(char addr, char channel, short Val)
char hibyte, lobyte;
hibyte = Val>>8;
lobyte = Val - (hibyte<<8);
ppCMD(addr, 0x40+channel, hibyte, lobyte, 0, NULL);
usleep(100);
// Return current PWM setting. Returned value will be a number between 0 and 1023 ///
short PiPlatesDAC_getPWM(char addr, char channel)
short Val;
char resp[2] = {0};
ppCMD(addr, 0x40+channel+2, 0, 0, 2, resp);
Val = 256*resp[0] + resp[1];
return Val;
// Set DAC output voltage from 0 to 4.097 volts //
// Needs about 10ms to settle
void PiPlatesDAC_setDAC(char addr, char channel, double Val)
short IntVal;
if(PiPlatesDACVcc == 0)
printf("Need to run the PiPlatesDAC_calDAC function first");
return;
IntVal = (short)(Val/PiPlatesDACVcc*1024);
hibyte = IntVal>>8;
lobyte = IntVal - (hibyte<<8);
usleep(10);
return;
// Cal the analog output //
void PiPlatesDAC_calDAC(char addr)
PiPlatesDACVcc = PiPlatesDAC_getADC(addr, 8) * 2.0;
sleep(1);
/// Relay Board functions ///
/// Relay functions ///
// Turns on (closes) the specified relay //
#define RelayBoard_relayON(addr, relay) ppCMDr(addr, 0x10, relay, 0, 0, NULL)
// Turns off (opens) the specified relay //
#define RelayBoard_relayOFF(addr, relay) ppCMDr(addr, 0x11, relay, 0, 0, NULL)
// Toggles state of specified relay. If relay is on, this command will turn it off
// If relay is off, this command will turn it on
#define RelayBoard_relayTOGGLE(addr, relay) ppCMDr(addr, 0x12, relay, 0, 0, NULL)
// Controls the state of all relays with a single command “value” is a 7 bit number
// with each bit corresponding to a relay. Bit 0 is relay 1, bit 1 is relay 2, and so on
#define RelayBoard_relayALL(addr, relay) ppCMDr(addr, 0x13, relay, 0, 0, NULL)
// Returns a 7-bit number with the current state of each relay. Bit 0 is relay 1, bit 1 is relay 2, and so on
// 1 - relay is on, zero - relay is off
char RelayBoard_relaySTATE(char addr)
char resp = 0;
ppCMDr(addr, 0x14, 0, 0, 1, &resp);
return resp;
// turn on the LED //
#define RelayBoard_setLED(addr) ppCMDr(addr, 0x60, 0, 0, 0, NULL)
// turn off the LED //
#define RelayBoard_clrLED(addr) ppCMDr(addr, 0x61, 0, 0, 0, NULL)
// Toggle the LED //
#define RelayBoard_toggleLED(addr) ppCMDr(addr, 0x62, 0, 0, 0, NULL)
#include "PiPlates.h"
int main()
int k;
char RelayState;
PiPlateInitialize();
for(k=1;k<7;++k)
/// Testing the relayON and RelayOFF functions ///
// RelayBoard_relayON(1,k);
// sleep(1);
// RelayBoard_relayOFF(1,k);
// sleep(1);
/// Testing the relayTOGGLE function ///
RelayBoard_relayTOGGLE(1,k);
sleep(1);
/// Testing the relayALL function ///
// RelayBoard_relayALL(1,k+3);
// sleep(1);
/// Testing the LED functions ///
// RelayBoard_setLED(1);
// sleep(1);
// RelayBoard_clrLED(1);
// sleep(1);
// RelayBoard_toggleLED(1);
// sleep(1);
/// Testing the RelayBoard_relaySTATE function ///
// RelayState = RelayBoard_relaySTATE(1);
// printf("RelayState: %i\n", RelayState);
// sleep(1);
printf("Complete\n");
return 0;
//include </home/pi/Libraries_Mine/CAll.h>
int main()
int k, i;
char ReaultC;
short ResultS;
double Val[8], ReaultD;
bool ResultB;
PiPlatesDAC_calDAC(0);
for(k=0;k<6;++k)
/// Testing the PiPlatesDAC_getDINbit function //
// ResultB = PiPlatesDAC_getDINbit(0, 2);
// printf("Result: %i\n", ResultB);
// sleep(1);
/// Testing the getDINall function ///
// ReaultC = PiPlatesDAC_getDINall(0);
// printf("Result: %i\n", ReaultC);
// sleep(1);
/// Testing the toggle LED function //
// PiPlatesDAC_toggleLED(0, k%2);
// sleep(1);
/// Testing the getADC function ///
// ReaultD = PiPlatesDAC_getADC(0, 1);
// printf("ADC result: %lf\n", ReaultD);
// sleep(1);
/// Testing the setDOUTbit function ///
PiPlatesDAC_setDOUTbit(0, k);
sleep(1);
PiPlatesDAC_clrDOUTbit(0, k);
sleep(1);
/// Testing the toggleDOUTbit ///
// PiPlatesDAC_toggleDOUTbit(0, k);
// sleep(1);
/// Testing the setDOUTall and the getDOUTbyte function ///
// PiPlatesDAC_setDOUTall(0, k);
// ReaultC = PiPlatesDAC_getDOUTbyte(0);
// printf("getDOUTbyte: %i\n", ReaultC);
// sleep(1);
/// Testing the setDAC function ////
// PiPlatesDAC_setDAC(0, 0, (double)k/2.0);
// sleep(1);
/// Testing the setPWM and the getPWM functions ///
// PiPlatesDAC_setPWM(0, 0, k*100);
// ResultS = PiPlatesDAC_getPWM(0, 0);
// printf("PWM out: %i\n", ResultS);
// sleep(1);
/// Testing the getADCall function ///
// PiPlatesDAC_getADCall(0, Val);
// for(i=0;i<8;++i)
// printf("Chan %i: %lf\n", i, Val[i]);
/// Testing the set, clear and getLed Function ///
// PiPlatesDAC_setLED(0, 1);
// PiPlatesDAC_clrLED(0, 0);
// ReaultC = PiPlatesDAC_getLED(0, 0);
// printf("Led 0 State: %i\n", ReaultC);
// ReaultC = PiPlatesDAC_getLED(0, 1);
// printf("Led 1 State: %i\n", ReaultC);
return 0;
