Hullo
I'm trying to build from the github builder (https://github.com/RPi-Distro/pi-gen). Unfortunately, one of the packages (raspi-copies-and-fills, which implements optimised low-level memory functions for the ARM processors) is no longer on archive.raspberrypi.org.
Is this a deliberate removal of the package?
tia
Tim
- ShiftPlusOne
Re: raspi-copies-and-fills package gone AWOL?
See viewtopic.php?f=28&t=235586
It was pulled ASAP to minimize the damage done. It should be back up with the offending commit reverted shortly.
Edit: It should be back up now.
Hi. I'd like to ask a little help. Yesterday I tried to update my system. There were only this package to update and my system now fails to boot. How can I remove this package, so I can start my system again? I have another sd card, so I could find and edit/remove the necessary files.
Thank you very much!
- DougieLawson
If you can boot a rescue system or mount the SDCard in any other Linux computer then
sudo rm /mnt/etc/ld.so.preload solves the problem.
You can build a rescue system with another SDCard, a copy of plain Raspbian and a USB SDCard reader.
Thank you very much! I used another sd card and deleted the file you mentioned. I've tried to boot, and I got this. Can you help me a little more? I press enter but nothing happens. Thank you again!DougieLawson wrote: ↑Tue Mar 12, 2019 11:54 amIf you can boot a rescue system or mount the SDCard in any other Linux computer then
- DougieLawson
Boot from the rescue system again. Insert the SDCard and run
for X in 1 2 5 6; do sudo umount /dev/sda$X; sudo fsck -f -y /dev/sda$X; done
That should make it bootable.
Thank you! You're a lifesaver! I had to change sda to sdb and uncomment the sda line in /etc/fstab, and it started. Working like before. I'll be more careful in the future.DougieLawson wrote: ↑Tue Mar 12, 2019 5:52 pmBoot from the rescue system again. Insert the SDCard and run
Thank you again! Have a nice day/evening/night!
It is indeed there now. However, postinst looks broken to me. It includes this stanzaShiftPlusOne wrote: ↑Mon Mar 11, 2019 7:05 pmSee viewtopic.php?f=28&t=235586
configure)
FPRELOAD=/etc/ld.so.preload
if [ -f "$FPRELOAD" ]; then
sed -i 's/libcofi_rpi/libarmmem/' "$FPRELOAD"
fi
echo "/usr/lib/arm-linux-gnueabihf/libarmmem-\${PLATFORM}.so" >> "$FPRELOAD"
glibc
ERROR: ld.so: object '/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
- ShiftPlusOne
Two concerns:
1) You now seem to have separate libraries for ARMv6 and ARMv7 systems. What about people that want to use same SD card or nfsroot for multiple type of Pi?
2) Currently when someone opens a chroot shell in the piserver GUI, piserver temporary renames ld.so.preload to something else while the shell is running, because the library gave problems when ran under qemu in the past.
However this has the side effect that if someone runs "apt-get upgrade", your postinst script is not able to update ld.so.preload.
And the package upgrade does seem to delete the old libarmmem.so, causing problems. See: https://github.com/raspberrypi/piserver/issues/52
- ShiftPlusOne
The appropriate one is loaded using that ${PLATFORM} trick.incognitum wrote: 1) You now seem to have separate libraries for ARMv6 and ARMv7 systems. What about people that want to use same SD card or nfsroot for multiple type of Pi?
I'll look into it.incognitum wrote: 2) Currently when someone opens a chroot shell in the piserver GUI, piserver temporary renames ld.so.preload to something else while the shell is running, because the library gave problems when ran under qemu in the past.
In the long term, qemu 4 will have a fix that will get rid of the message, until then we'll need to make sure piserver and the postinst script work together.
I'm running this in a qemu emulator on x86, using a fork from http://bit.ly/2uelq0D in a fedora vm with suitable binfmt settings to get the right binaries running in the right virtualised environments. I've been doing it like this since Jul 2017 and it's been fine.ShiftPlusOne wrote: ↑Thu Mar 14, 2019 1:23 pmBroken in what way? The line in ld.so.preload looks correct to me. Why ld.so is complaining, I'm not sure. Ae you definitely running this on a pi?
Is that not a new line in the packing - sorry, I don't know where the packaging repo is, so I cannot `blame` it.
Looking at an older image, I can see that the change is the ${PLATFORM} token.
If I remove the version (0.6) on that old image (which has:)
And then download and install v 0.10, I get:
which is the same as I was getting in the build process. However, glibc isn't barfing when it reads the file, so, presumably, the variable ${PLATFORM} is defined in its environment. I cannot spot where.
cat /etc/ld.so.preload
/usr/lib/arm-linux-gnueabihf/libarmmem.so
Looks like $PLATFORM is special to ld. Clearly something's not passing this through in my qemu environment.
- ShiftPlusOne
I filed the issue here when I initially saw it:
https://bugs.launchpad.net/qemu/+bug/1813034
The fix should be available in Qemu 4, but that won't be ready any time soon. For now, while you're using qemu, comment the line out.
