I already have 20 of the RPi3 at work as a replacement for HP ThinClient.
Works wonderfully, costs only a fraction of a "real" thin client of e.g. HP and is also faster in the configuration.
Now I have bought a RPi4 (4GB), because more and more colleagues use two monitors, which is not possible with the RPi3.
What I noticed right now is that the RPi4 itself is faster than the RPI3, where the RemoteDesktop task is inferior to the "old one". Even on the RPi2 it worked better.
With the RPi3, there is absolutely no jerking or line building during the RDP session. The picture is really there immediately, as if I would not access the server by RDP, but sit directly in front of it and that even over WLAN or good InterNet connection.
On the RPi4 I have to use because of the "/ multimon" feature "xfreerdp-x11". The image structure is horrible and in comparison to what I know of the RPi3 not reasonable. How to use over a slow 1MBit internet connection. Lines / blockwise screen layout.
Also the program used on the RPi3 "rdesktop" (unfortunately without /multimon) builds up the picture just as slowly.
I have set up the GPU as on the RPi3 whole 512MB memory. Unfortunately with the same effect.
My assumption is that the operating system (Buster) has to do with it.
Has anyone similar experience or ideas on i can set the PRi4 (as RDP client) to runs it just as fast as on the RPi3?
Thank you
