whayden1
xRDP on Raspbian - no keyboard or mouse upon connect
Sun Mar 01, 2020 11:18 pm
I have a new install on a Pi4 running Raspbian 10 (buster). I have installed "xrdp" and verified that it is running. All packages have been upgraded and updated.
I can connect to the Pi4 via RDP via my Win10 and even an old Win7 machine without issue. I connect, log in and can see the screen. The problem occurs after login. Upon logon I see the desktop, but the keyboard and mouse do not work. They worked at the logon screen, but not when I get to the desktop.
I've tried this a number of times now with the same results.
Any help is greatly appreciated.
PJKram
Re: xRDP on Raspbian - no keyboard or mouse upon connect
Thu Apr 09, 2020 1:58 pm
I have the same problem. When I install raspbian on a SD card everything works fine. But when I use Berryboot and install rasbian on a usb drive, I can start a remote rdp login, I can login, I get a desktop but mouse and keyboard do not work. The xrdp log file tells me that the modules mouse and kbd can not be found.
[ 38.613] (II) LoadModule: "mouse"
[ 38.614] (WW) Warning, couldn't open module mouse
[ 38.614] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 38.614] (II) LoadModule: "kbd"
[ 38.614] (WW) Warning, couldn't open module kbd
[ 38.614] (EE) Failed to load module "kbd" (module does not exist, 0)
[ 38.614] rdpIdentify:
What could be the problem ?
jvriend
Fri Apr 10, 2020 5:29 pm
I have this also when upgraded from Jessie to buster.
With Jessie never had a problem, and with a fresh full install of buster it seem to work
but when i changed some settings in bootconfig.txt so he could see a screen of 6 inch,
it stopped working.
I use an RPI 3B and try to connect with windows 7.
I did notice that i saw the handlings i did on my local-screen (screen just connected with the HDMI) , were also shown on the remote
desktop, as it is a copy of my local-screen.
jvriend
Mon Apr 13, 2020 5:42 pm
I have no clue why, but i just found out that when i turn of the screen-saver on a working
system, after reboot the remote control doesn't have a keyboard and mouse.
When i turned on my screen-saver again, my remote control works again ??
I use the default remote desktop from windows to connect with xrdp on my raspbian Buster
and raspbian buster is the default full installation, and xrdp installed.
I have two machines with the RPI as heart and connected through HDMI to a 6' screen.
I like to test and develop the software on a remote (bigger screen) so i can also test the
connected hardware
jberculo
Re: xRDP on Raspbian - no keyboard or mouse upon (screen blank)connect
Sat Apr 25, 2020 8:47 am
Thanks @jvriend!
This was exactly my issue. Turning on the 'screen blank' option at the display preferences fixed it.
I am also in the dark as of the why, but I guess I now have to find another way to force my pi not to go in sleep mode.
EdwinDigital
Tue Jun 23, 2020 4:50 pm
I also met this problem. Enable [Screen Blanking] works for me well, great thanks, guys!
gonan75
Sun Sep 20, 2020 6:51 pm
Simply amazing. I was ready to rip out my remaining hair over this issue. Who knew that screen blanking being disabled would cause this issue. Thanks everyone!
The_Esch
Tue Nov 17, 2020 7:37 pm
Hello and thank you! it work and I can use mouse & keyboard via xrdp again.
but, how can you prevent the raspi to go to sleep mode?
panca
Sun Apr 11, 2021 7:56 am
Thanks a lot, I was at the end of my wits too until I found this thread. I wonder what causes this and how one could have discovered this systematically? Isn't this kind of a bug? I find something else weird: once the two xrdp-services are enabled, multiple xrpd-related processes are resident in memory, the Xorg-one eating considerable amounts of memory (on a 1gb-model it's 10% of available RAM), even though xrpd is not being used. I happen to have a 64-bit version of RpiOS (Debian) running on another rpi4, where these processes are only loaded once xrpd is activated, and are unloaded again after the user logged off. There xrpd-sesman and xrpd processes are running but they are must be in a dormant waiting/listening state without eating significant memory (0.0 in ps). Maybe there is more misconfiguration in the default xrpd install on default RpiOS?
Sun Apr 11, 2021 8:30 am
xrdp is generic software provided by Debian, it has had no optimizations from RPT / RPF for the Raspberry Pi OS & Hardware.
Hence why RealVNC is offered by default in RaspiOS and RaspiOS64 Beta Operating Systems...
Therefore you need to contact the xrdp developers to make them aware of issues you *feel* need fixing.
