Hello!
I followed these steps:
First I entered:
sudo systemctl enable serial-getty@ttyUSB0.service
And then I entered:
sudo systemctl start serial-getty@ttyUSB0.service
That was copied from:
http://0pointer.de/blog/projects/serial-console.html
Which provided the details as if I was working on an Intel system running Debian.
After entering the second command string on the serial console screen I immediately saw a prompt arrive on my second Putty terminal.That was running 9600 baud. I need to take this down to 4800 baud. Reason being is that it will be connected to a RS Model 102 who does 4800 rather well, but does 9600 baud poorly. I have vague memories of doing so sometime earlier on this Pi3B but, ah, it was so long ago I can not remember the steps. I found an earlier Forum series on a similar subject, and noted that the correspondent there faced a similar problem. But trying the recommended steps now wasn't at all working.
- Doctorwho8
How would I go about changing the serial baud rate on a TTY
Gregg
Doctor Who8
Gregg
Doctor Who8
Re: How would I go about changing the serial baud rate on a TTY
Normally you would just set the baudrate in the program that uses the serialport. If you are using a dedicated serial-library for your chosen language ( e.g. Pyserial ) those libraries will let you control the baudrate.
But if you just want to change it from the terminal the command is:
(of course use the correct device name for you.. )
.. but is this a usb2serial device connected to the USB port of the Pi ?
.. do you really want to have a login terminal for that ? ( i have no idea what an "RS Model 102" is )
.. what was the motivation for activating getty for that serial port ? ( if you wanted some output you could have just done "echo "Hello" > /dev/ttyUSB0" )
( And why on earth choose the eight Doctor ??
stty -F /dev/ttyUSB0 4800
- Doctorwho8
Hello!topguy wrote: ↑Mon Jul 06, 2020 8:44 amNormally you would just set the baudrate in the program that uses the serialport. If you are using a dedicated serial-library for your chosen language ( e.g. Pyserial ) those libraries will let you control the baudrate.
But if you just want to change it from the terminal the command is:(of course use the correct device name for you.. )Code: Select all
( And why on earth choose the eight Doctor ??![]()
First things last. I chose him because it seems that the reality that Doctor Who does his/her best in seems to be largely ignoring him.
I also used the information here: https://zork.net/~octal/mod100.xhtml there was large amounts of information there. Finally several years ago for a completely different purpose I did manage to change the baud rate on the whole business. Back then I had connected to the same device a Pi3B I had connected to it, two Pi Zeros, one was working as a Gadget Zero Serial, and the other was working as a Gadget Zero Ethernet one. There's an unrelated issue of the WiFi departing in this configuration for the Pi3B when all of that there was connected this time.
Also here http://www.club100.org/ you should find out more information for the Radio Shack TRS-80 Model 102 for it.
Gregg
Doctor Who8
Gregg
Doctor Who8
This thread:
viewtopic.php?t=155807
.. should contain all you need. ( note answers by dgordon2 )
just ask if seomthing is unclear.
