jay123035
SOLVED:bad video resolution on boot but changes after reboot
Mon Mar 10, 2014 6:37 pm
because i power the monior and the PI from the same source i have to have hdmi_force_hotplug=1 otherwise the PI does not see the monitor in time to output a video signal. but when that set and first power up the system i get
state 0x120016 [DVI DMT (35) RGB full 5:4], 1280x1024 @ 60Hz, progressive
as output for
tvservice -s
once I reboot I get
state 0x12001a [HDMI CEA (4) RGB lim 16:9], 1280x720 @ 60Hz, progressive
i think it would be ok if i could force the smaller resolution but 1280x720 is not a "good" resolution "mode" http://elinux.org/RPi_config.txt
one thought is to make the Pi reboot every time it is powered up. but that seams like a lame solution.
thanks for your input
Re: bad video resolution on boot but changes after reboot
Mon Mar 10, 2014 6:57 pm
You can download the monitor settings using
sudo tvservice -d /boot/edid.dat
Then edit the /boot/config.txt and add (or uncomment if it exists) the line
hdmi_edid_file=1
When you next boot your Pi will use the settings from the data file instead of looking for the monitor. Very handy if the monitor isn't connected when you power the Pi on. But you may have to change those settings if you use a different monitor.
I don't have hdmi_force_hotplug=1 set, but I do have hdmi_group=2. Not usre if that is needed in your case.
FTrevorGowen
Mon Mar 10, 2014 7:10 pm
jay123035 wrote:because i power the monior and the PI from the same source i have to have hdmi_force_hotplug=1 otherwise the PI does not see the monitor in time to output a video signal. but when that set and first power up the system i get
as output for
tvservice -s
once I reboot I get
Whilst there is/are preferred mode(s) for a (given) HDMI/DVI monitor, I've found that a "native" (T.V.) mode is also O.K. FWIW, some examples of the use of (other) tvservice command options to determine the "optimum" config.txt settings for different display types are shown here:
http://www.cpmspectrepi.webspace.virgin ... tings.html
Trev.
Begining to test Bullseye on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) and Pi's with cameras with Buster on the P3B+, some P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
jay123035
Mon Mar 10, 2014 8:01 pm
rpdom wrote:You can download the monitor settings using
hdmi_edid_file=1
This did the trick, thank you very much.
i was able to remove (comment out)
#hdmi_force_hotplug=1
and
#hdmi_group=2
once i added the
hdmi_edid_file=1
thanks again.
