Hello all I am trying to install mjpg-streamer-r63 on my Pi but i get this error on the make command,
linux/videodev.h: No such file or directory
I have installed libjpeg8-dev
and i have done the update and upgrade command.
i can not seem to find an answer that i can understand (newbie) On the net.
best regards.
Tony
Re: linux/videodev.h: No such file or directory
According to this page, you need to:
After that you should be able to run the 'make' command again, from whatever directory you were running it before.
sudo apt-get install libv4l-dev
cd /usr/include/linux
sudo ln -s ../libv4l1-videodev.h videodev.h
Thank you very much for the help, i did as instructed but it was no help, i even went so fare as to build a new version of the os on a new sd (with updates & upgrades) card and try to install mjpg-streamer on it, just in case i had mucked up the O.S.
same error. i am at a lose.
After you did those steps, did the file /usr/include/libv4l1-videodev.h actually exist?
If you runwhat's the output?
If you run
ls -l /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
I do not see the file!
this is the report that you asked me for, (not that i have a clue what i am looking at!)
pi@raspberrypi /usr/include/linux $ ls -l /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
-rw-r--r-- 1 root root 7135 Dec 11 12:26 /usr/include/libv4l1-videodev.h
lrwxrwxrwx 1 root root 21 Jun 5 20:28 /usr/include/linux/videodev.h -> ../libv4l1-videodev.h
to me that looks like it is there?
I can not thank you enough! This is all very new to me.
Yep, that part is looking good.
Any chance you could post the full output from when you try to run 'make'? I've never used the mjpg-streamer stuff, so I'm just approaching it as a case of "it's software, and I know how to build software"
I also found a post over here on how to get mjpg-streamer to build which uses a slightly different approach - maybe that could help?
This is the error i get when i run "make"
Tony
gcc -O2 -DLINUX -D_GNU_SOURCE -Wall -c -o mjpg_streamer.o mjpg_streamer.c
mjpg_streamer.c:27:28: fatal error: linux/videodev.h: No such file or directory
compilation terminated.
make: *** [mjpg_streamer.o] Error 1
Tony
The post you sent me to worked!!
Thanks so much, email me and i'll send you a link to drive the rover!
Best regards!
Best regards!
Happy to have been of some help, even if it was only with Google-fu!
No thank you, i have only had the Pi two weeks so you where more help then you know! File trees, do on!
