hyla
WindowsIoTCoreWatcher
Sat May 02, 2015 3:07 pm
is "WindowsIoTCoreWatcher.exe" working for You? When I click it it seems to be starting up but nothing ever happens ...
Of course with just on "Pi on Windows" it's not yet vital but still ...
Christoph
pauldy
Re: WindowsIoTCoreWatcher
Sat May 02, 2015 4:55 pm
The following shows up in the event log for me when the app spins up and crashes. This is after a full clean install of Win10 x64 and VS 2015 RC then WindowsDeveloperProgramForIoT.
Faulting application name: WindowsIoTCoreWatcher.exe, version: 10.0.10103.0, time stamp: 0x553591f8
Faulting module name: KERNELBASE.dll, version: 10.0.10074.0, time stamp: 0x553acf7b
Exception code: 0xe0434352
Fault offset: 0x00000000000218f8
Faulting process id: 0x10e0
Faulting application start time: 0x01d084f782ba0af4
Faulting application path: C:\Program Files (x86)\Microsoft IoT\WindowsIoTCoreWatcher.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: bca3dacb-ceaf-445f-be98-ac8bd98d8ffd
Faulting package full name:
Faulting package-relative application ID:
ric96
Sat May 02, 2015 5:21 pm
working for me but the "tick" in the check box vanishes away after some time
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
ArtemAnchugov
Sat May 02, 2015 6:05 pm
I have same problem.
And there is a bug filed on MS Feedback Center that is worth upvoting: https://connect.microsoft.com/windowsem ... ls/1295993
RandomPiDude
Sun May 03, 2015 5:38 am
There's a workaround that Ed Dore posted on the IOT Connect forums. There's one typo in his post, which I've corrected below. (Should be corflags, not coreflags). Worked for me.
original source - https://connect.microsoft.com/windowsem ... ls/1295993
Launch the "Developer Command Prompt for VS2015" as Administrator
change the working directory over to "C:\Program Files (x86)\Microsoft IoT"
sn -Vr WindowsIoTCoreWatcher.exe
corflags WindowsIoTCoreWatcher.exe /32BIT+ /FORCE
The first command (sn.exe) tells windows to skip strongname verification of the binary
The second command forces the application to run as a 32bit application
I'm guessing someone isn't testing this stuff on a 64bit OS :-S
hyla
Sun May 03, 2015 9:31 am
RandomPiDude wrote:There's a workaround that Ed Dore posted on the IOT Connect forums. There's one typo in his post, which I've corrected below. (Should be corflags, not coreflags). Worked for me.
Works ... thanks.
Christophs
hyla
Sun May 03, 2015 9:45 am
The "Galileo Watcher" is detecting the Pi as well (Windows 7) ...
Christoph
Return to “Windows 10 for IoT”
