devunwired
Re: STICKY: Errata
Wed Jul 18, 2018 4:14 am
Issue 71, Page 23 under Android Zero:
Unfortunately, Android Things does not support the Pi Zero – it requires a bit more power than the board can currently provide, so you’ll need at least a Raspberry Pi 2 to run Android Things on, but preferably a Pi 3
This statement is incorrect. Android Things only supports the Raspberry Pi 3 Model B. It will not run on a Raspberry Pi 2.
https://developer.android.com/things/hardware/
hippy
Re: STICKY: Errata
Wed Jul 18, 2018 12:38 pm
Issue 71, Page 75, line 35 of listing, wind_speed.py -
print( calculate_speed(wind_interval), "cm/h")
Should be "cm/s".
yourunclesdog
Re: STICKY: Errata
Sun Nov 04, 2018 9:53 pm
Hey there! I've just noticed that in issue 75 of the magazine, both number 36 and number 30 in the top 50 voted projects have the PolaPi-Zero's name and description. It's nothing major, I just wanted to let you know.
vinntec
Re: STICKY: Errata
Thu Jan 31, 2019 8:42 am
The link to the PDF on the new issue #78 goes to #77.
icd
Re: STICKY: Errata
Sat Nov 16, 2019 8:36 am
Issue 87 Power Up Your Kitchen
The first part covering temperature and alarms - page 69. In section 03, there is a reference to some Python code "... download the code file temperature.py ..." but no indication where that file is located.
HikerLT
Re: STICKY: Errata
Wed Nov 11, 2020 3:43 pm
Issue 98 - article "build the ultimate home music system".
This is part 3 , and I have to say it's a great project - I built a couple of Rpi4's from part 1 and 2 of the article series, and works great.
I run into problems with the issue 98 part 3 instructions :
step 02 and step 03 show command line to use starting with command "get"....I think this should be "wget"
get https://github.com/badaix/
snapcast/releases/download/v0.20.0/
snapclient_0.20.0-1_armhf.deb
sudo dpkg -i snapclient_0.20.0-1_armhf.deb
Also, the commands shown for step 03, to install the snapcast server, are identical to the commands in step 02, installing the snapcast client.
I think for step 03, should be :
wget https://github.com/badaix/snapcast/rele ... _armhf.deb
Also, further on in step 3, it says the /etc/mopidy/mopidy.conf file should have
[audio]
output = autoaudiosink
However, in the part 1 of the series, contained in issue 96 , step 06 instructs to set
the /etc/mopidy/mopidy.conf file to:
[audio]
output = alsasink
So I'm a bit confused about this [audio] setting...
Continuing on to step 4, setting up the snapcast, I'm not sure what is wrong.
I edited the /etc/mopidy/mopidy.conf file per the instructions in step 03, and followed the step 04 instructions to get the snapcast service "connected"....BUT now the audio playback does not work for Iris. However if I open another tab on the browser, and go to a streaming radio station ( http:/www.wcrb.org ), the audio stream plays fine there.
Re: STICKY: Errata
Wed Nov 11, 2020 5:06 pm
Why not read the package documentation at
https://docs.mopidy.com/en/latest/config/
Rather than the crudely transcribed junk in the MagPi magazine.
-zeta
Hubble spelling error
Sun Feb 07, 2021 4:22 am
In the article by @RosemaryHattersley boldly titled "Hubble Pi" there is a spelling error;-
The Hubble Space Telescope is a catoptric Ritchey–Chrétien with hyperbolic mirrors, not a catadioptric Maksukov with spherical mirrors and lenses.
The telescope featured in the article is difficult to identify from the photograph apart from being cassegrain, but described as "rather small" may well be a Maksutov.
Return to “The MagPi”
