Austriker
Touch Screen i2c issue
Mon Sep 14, 2015 7:20 pm
I am having trouble with the touch part of the screen. I power the raspberry using the micro usb from the display and the jumper cables.
I have a raspberry pi 2.
The screen works nicely and the colors are really nice.
But when i tried to wire the touch with the i2c cables.
It works on start up but after that it stops working.
when i try :
sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
40: -- -- -- -- -- 45 -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
but after a while when i try this again :
sudo i2cdetect -y 1
Every -- is replaced by a number
I just found out that the problem comes up when i execute the i2cdetect command. I checked with an Oscilloscope looking at the SDA i2c :
when i execute
sudo i2cdetect -y 1
the first time it keeps working but the second time the signal drops and the touch stop working.
I don't understand why it does this.
Sincerely,
PeterO
Re: Touch Screen i2c issue
Mon Sep 14, 2015 7:32 pm
Which model of the PI are you using ?
You don't need to use the jumper wires on Pi2s and A+ and B+ (I think that's right) Models as the I2C connection is included in the ribbon cable between the PI and the driver board.
PeterO
fjkraan
Mon Sep 14, 2015 7:48 pm
I seem to have a very similar or the same issue.
At startup of the latest Raspian the display is recognized and used, the HDMI display remains black.
When starting the X Window System, the touch screen is working, but after some time (and user activity) it stops. The behaviour is either a mouse pointer jittering vertically at the left, or no response at all. When restarting X the touch isn't working at all. Only a power cycle restores the touch screen for some time. An USB mouse can move the cursor, but the left button is not working.
At this time I am not sure this is a hardware or software (driver) issue.
I use a separate power supply cable for the display and Pi boards to a dual port USB mains charger. The Pi is a new 2B.
sudo i2cdetect -y 1
complains about nonexisting /dev/i2c-1 or /dev/i2c/1.
Austriker
Mon Sep 14, 2015 8:12 pm
I am using the raspberry pi 2.
So i just need to wire the power and the touch should be working ?
Sincerely
PeterO
Mon Sep 14, 2015 8:38 pm
Mouse stopping seems to be fixed in the very latest firmware.. See this thread viewtopic.php?f=43&t=120642&p=815836#p815820
PeterO
Austriker
Mon Sep 14, 2015 9:11 pm
Normally you don't need to wire the i2c to use the touch screen ?
alexeames
Mon Sep 14, 2015 9:32 pm
Austriker wrote:Normally you don't need to wire the i2c to use the touch screen ?
If you have a B+, a Pi2 or an A+ you need not connect the i2c GPIO wires as they are taken care of in the DSI ribbon connector.
Alex Eames RasPi.TV, RasP.iO
PeterO
Tue Sep 15, 2015 9:18 am
There's an echo in here ! :D
PeterO
alexeames
Tue Sep 15, 2015 10:08 am
PeterO
I know. He didn't seem to hear you, so I repeated it :)
Austriker
Tue Sep 15, 2015 3:06 pm
alexeames wrote:
PeterO wrote:
alexeames wrote: If you have a B+, a Pi2 or an A+ you need not connect the i2c GPIO wires as they are taken care of in the DSI ribbon connector.
PeterO
Oh sorry my bad...
Thank you for your help.
Sincerely
Return to “Official Display”
