buzznz
Black Rectangle Top Left Corner Of Screen
Wed Nov 11, 2015 3:44 am
Hi all,
I have brought one of the new 7 inch Pi touch screens. I have the Pi booting straight to the LXDE desktop. When it is finished booting there is an annoying black rectangle in the top left corner of the screen.
Done a lot off searching on line and in the forum but have not been able to find a solution.
Has anyone else had this problem and or a solution?
Cheers
Buzz
Aramas
Re: Black Rectangle Top Left Corner Of Screen
Fri Nov 13, 2015 7:56 am
When my screen was freezing I always had this black rectangle at the same place.
But it was only when it was freezing...
Try to update your firmware, it fixed my freeze issue, so maybe it will fix your issue too
buzznz
Fri Nov 13, 2015 10:40 pm
Thanks Aramas, I'll give it a try.
Cheers
Buzz
buzznz
Sat Nov 21, 2015 4:18 am
I've just upgraded the firmware using rpi-update. Everything went well, no errors but after rebooting I still have the small black rectangle :(
Cheers
Buzz
buzznz
Sat Nov 21, 2015 5:29 am
Okay, I don't know if I've found the problem, but it may be from using a custom splash screen.
From another post I have found the following work around:
Find the file that is running the fbi command. In may case it is /etc/init.d/asplashscreen
Find the line "/usr/bin/fbi -T 1 -noverbose -a /etc/splash.png" and change the "-T 1" to "-T 2".
Save and reboot.
Credit for this fix to "anigel".
Cheers
Buzz
Return to “Official Display”
