alexgao
Pi400 HDMI connection issues
Wed Sep 22, 2021 12:36 pm
Hello
Recently I've got my pi 400. And it's a first time when I have issues with pi boards
1st - can`t boot from microSD card (when this card perfectly works with pi 4B)
2nd - most critical - HDMI connection. I am using the same cable (microHDMI to HDMI adapter) as for pi 4B and have issues with video output.
To get a picture, I have to dance around of my pi :)
It seems that the case prevents to the normal connection (cable to port)
Does anyone had such issues and has a solution ?
KeithMck
Re: Pi400 HDMI connection issues
Wed Sep 22, 2021 6:25 pm
Personally, I'd just get another card for the RPi400, & buy a genuine HDMI cable, no adapter. ;)
(Not that it helps in your case, but I can swap my SD cards between my RPi4B & RPi400, no problem.)
Joop99
Thu Sep 23, 2021 2:18 pm
As you have a pi4 you should know how to insert the micro sd card. You have to push it into the slot all the way until you here it click. Concerning your monitor issues, are you sure that the p400 is set for the right monitor, if your monitor is NOT multisync and fed with the wrong dimensions then it will stay in most cases black and do nothing. I use adapters and have no issue with it. However my cable shows in some cases that there is a breach somewhere in the cable, if that occurs the screen blacks out and I have to reposition it on the table.
cleverca22
Thu Sep 23, 2021 2:25 pm
of note, only the pi2 and pi400 click like that
the pi4 does not make a click when fully inserted
Thu Sep 23, 2021 4:45 pm
Also the (1)B+, although I removed the spring on mine when the mechanism broke, so it is just a push-pull instead of a push-push now.
Unreadable squiggle
Joop99
Fri Sep 24, 2021 5:11 pm
Didn't know that, little silly not to have same systems throughout the complete product line. Now you can't give universal advice.
Fri Sep 24, 2021 6:08 pm
The "click" mechanisms on the 1B+ and 2 were prone to problems. The 400 doesn't have the same problem because it is in a case and the fit is better.
Unreadable squiggle
Return to “Raspberry Pi 400”
