ejolson
Re: Double base palindromes
Fri Sep 17, 2021 8:32 pm
lurk101 wrote:
Fri Sep 17, 2021 8:29 pm
ejolson wrote:
Fri Sep 17, 2021 8:25 pm
So adding nop's makes it faster? I'm completely lost here.
No, the pio calls were changed from blocking to non blocking. The NOPs are there to give the SM time to run its loop. You can remove one NOP and it still works, but whatever.
Are there timing diagrams that determine how many nop's are needed? Did you just experiment? Were four nop's used earlier
viewtopic.php?p=1914784#p1914784
to obtain the 0.000300 timing?
If the Pico is overclocked do the number of nop's change?
ejolson
Fri Sep 17, 2021 8:52 pm
ejolson wrote:
Fri Sep 17, 2021 3:23 am
lurk101 wrote:
Fri Sep 17, 2021 3:12 am
Just for grins...
On a 600MHz single core Cortex M7
Run time 0.000012 seconds
I fixed the overhead related to the string allocation problems in my Go code and then found another number that is simultaneously a palindrome is bases 2 and 3.
My list is now:
    1100111110011
    100010001
1422773
    101011011010110110101
    2200021200022
5415589
    10100101010001010100101
    101012010210101
90396755477
    1010100001100000100010000011000010101
    22122022220102222022122
I tested numbers up to 100000000000. Unfortunately, none these are also palindromes in base 5. Hopefully I didn't miss any. My code is based on the algorithm which appeared in the first post, so clearly some optimization could help.
At any rate, in order to get the program to scale well to multiple cores I learned something more about slices in Go and am happy about that.
Last night I started a job to check up to 10000000000000 (two more zeros) and didn't find any more base 2 and 3 palindromes. The run took 7 hours. At this rate is will take about 7000000 more hours (800 years) to check all 64-bit integers.
Do you think more than 64-bit integers will be needed to find a number that is simultaneously a palindrome is bases 2, 3 and 5? Is there even is such a number?
Since people have already optimized codes to find numbers which are simultaneously palindromes in bases 2 and 10, are any of those numbers also palindromes in base 3?
ejolson
Fri Sep 17, 2021 11:59 pm
Just for grins...
My list is now:
    1100111110011
    100010001
1422773
    2200021200022
5415589
    101012010210101
90396755477
I followed the approach suggested earlier and created a palindrome generator that only tests known base-3 palindromes to see if they are also palindromes in base 2. Woohoo! I found another double base-2 base-3 palindrome:
381920985378904469
    10101001100110110110001110011011001110001101101100110010101
    2112200222001222121212221002220022112
Unfortunately, 381920985378904469 is not a base-5 palindrome either.
It seems to me the bigger the palindromes get, the less likely they are to be palindromes in another base by chance.
Since 381920985378904469 takes 29 base-5 digits to express, then 14 digits would need to match up for it to be a base-5 palindrome. From a probabilistic point of view, the chances that 14 base-5 digits match is (1/5)^14 or 1 part in 6103515625.
Well, it didn't happen.
Maybe there are no numbers that are simultaneously palindromes in bases 2, 3 and 5. I asked the dog developer, but the reply sounded only like barking. Maybe it's time for a walk.
kilograham
Sat Sep 18, 2021 12:18 am
My 300 number has pio_sm_put() with pio_sm_get_blocking(). I didn't go the nop route defensively, but now release there isn't really any way this result can be delayed - I am used to DMA-ing stuff to/from the PIO. So non blocking with nops is fine
That said you are lucky the compiler isn't stripping out the nops without
__asm__ volatile
or better really in case it decides to move it
__asm__volatile("nop" ::: "memory")
Also you are getting lucky with your core interleaving, as you should really use a different SM for both cores.
lurk101
Sat Sep 18, 2021 12:36 am
Yes, lucky with the NOPs, but core 0 uses PIO0 and core 1 uses PIO1, why different SMs?
lurk101
Sat Sep 18, 2021 12:49 am
The PIO run on the same clock as the CPU, it wouldn't matter.
lurk101
Sat Sep 18, 2021 2:38 am
pio_sm_put translates to a STR instruction, and pio_sm_get to an LDR, each 1 clock cycle. In theory 2 NOPs at one cycle each should be enough.
static unsigned int palindrome(unsigned int n, PIO pio) {
    pio_sm_put(pio, 0, n);
    __asm__ __volatile__("nop" ::: "memory");
    return ((pio_sm_get(pio, 0) >> boot_clz32(n)) == n) ? n : 0;
Running in flash
Sum is 872187
Run time is 0.000284 seconds
running in RAM
Sum is 872187
Run time is 0.000206 seconds
ejolson
Sat Sep 18, 2021 3:50 am
lurk101 wrote:
Tue Sep 14, 2021 6:01 am
My interests are twofold. First it's always surprising how problems are tacked differently based on language, and second how interpreted languages compare speed wise.
For comparison of languages, here is a Go program that solves the original problem:
/*  euler36.go -- Double-base palindromes
    Written 2021 by Eric Olson */
package main
import ( . "fmt"; . "strconv"; . "runtime"; . "os"
    "flag"; "unsafe"; "time")
const (
    b1 = 2; b2 = 10
var (
    xmin,xlim uint64
    tictime float64
func tic() {
    now:=time.Now()
    tictime=float64(now.Unix())+1.0E-9*float64(now.Nanosecond())
func toc() float64 {
    now:=time.Now()
    return float64(now.Unix())+1.0E-9*float64(now.Nanosecond())-tictime
func o1string(b []byte) string {  // avoid the heap
    return *(*string)(unsafe.Pointer(&b))
func dowork(r int,s uint64,c chan uint64) {
    x:=make([]byte,256)
    mkpale:=func(i uint64,b int) uint64 {
        x=x[:0]
        x=AppendUint(x,i,b) // avoid the lock
        m:=len(x)
        x=x[:2*m]
        for i:=m;i<len(x);i++ {
            x[i]=x[len(x)-i-1]
        r,e:=ParseUint(o1string(x),b,64)
        if e!=nil||r>=xlim { return 0 }
        return r
    mkpalo:=func(i uint64,b int) uint64 {
        x=x[:0]
        m:=len(x)
        x=x[:2*m-1]
            x[i]=x[len(x)-i-1]
        return r
    ispal:=func(i uint64,b int) bool {
        x=x[:0]
        for i:=0; i<len(x)/2; i++ {
            if x[i]!=x[len(x)-i-1] {
                return false
        return true
    count:=uint64(0)
    for i:=xmin+uint64(r);;i+=s {
        j:=mkpalo(i,b2)
        if j>0 && ispal(j,b1) { count+=j }
        k:=mkpale(i,b2)
        if k>0 && ispal(k,b1) { count+=k }
        if j==0 && k==0 { break }
    c<-count
func main(){
    ncpu:=GOMAXPROCS(0)
    Printf("euler36--Double-base palindromes\n"+
        "Written 2021 by Eric Olson (GOMAXPROCS=%d)\n\n",ncpu)
    flag.Uint64Var(&xmin,"a",1,"First prefix to sum.")
    flag.Uint64Var(&xlim,"b",1000000,"Upper limit to sum.")
    flag.Parse()
    Printf("Summing palindromes from %d up to %d...",xmin,xlim)
    ret:=make(chan uint64,ncpu)
    tic()
    for r:=1; r<ncpu; r++ {
        go dowork(r,uint64(ncpu),ret)
    dowork(0,uint64(ncpu),ret)
    count:=uint64(0)
    for r:=0; r<ncpu; r++ { count+=<-ret }
    tsec:=toc()
    Printf("done\n")
    Printf("\nSum of all double-base palindromes:  %d\n"+
        "Calculation time %g seconds.\n",count,tsec)
    Exit(0)
The main thing of interest about the program is the use of byte slices rather than strings in the base conversion routines. From what I can tell, strings always create additional allocations on the heap which make it impossible for a string-based program to scale to many cores.
Performance advice on how to write Go programs is conspicuously missing from most of the documentation while web searches yield a multitude of programmers who claim Go is faster than Python and that performance doesn't matter for the type of programs they write anyway.
In the present case, the lock resulting from the string operations used in the original version of my code caused the program to run at less than 30 percent utilization on a 32-core EPYC server with more than half of that time spent on memory management. My impression is a large number of gophers have lost track of why anyone might want to use a compiled language with parallel concurrency and created a standard library that makes it extremely difficult to use the language efficiently.
In defense of the standard library, the documentation seems to indicate that Go originally allowed strings and byte slices to be freely converted back and forth in O(1) time. These days the operation takes O(n) and involves allocating memory on the heap. Although it's still possible to use an unsafe pointer conversion to convert a byte slice to a string in O(1) time, I think it would be more sensible if the library allowed byte arrays to be passed in as arguments in the first place.
On a Pi 4B a typical run looks like
$ ./euler36
Written 2021 by Eric Olson (GOMAXPROCS=4)
Summing palindromes from 1 up to 1000000...done
Sum of all double-base palindromes:  872187
Calculation time 0.0005865097045898438 seconds.
While the problem size isn't large enough for accurate timings, it's interesting that C running on the Pico is faster. A reasonably sized problem is to search the entire space of 64-bit integers. In that case, I've found it more enjoyable to print the double-base palindromes rather than sum them.
kilograham
Sat Sep 18, 2021 5:20 pm
ah, sorry i wasn't paying attention. as long as they aren't using the same PIO/SM then yes fine.
davidcoton
Sat Sep 18, 2021 5:52 pm
Did you know "palindromic" is an abbreviation for
"Palin's cidromordic snilap"
Please don't ask. :lol:
kilograham
Sat Sep 18, 2021 5:59 pm
you can of course save a few cycles by doing useful work instead of nops.
static unsigned int palindrome(uint sm, unsigned int n) {
    pio_sm_put(pio0, sm, n);
    unsigned int l = faster_clz(n);
    return (pio_sm_get(pio0, sm) >> l) == n ? n : 0;
Sum is 872187
Run time is 0.000263 seconds
ejolson
Sat Sep 18, 2021 7:03 pm
Sum is 872187
Woohoo! I'm happy that getting rid of the nop's makes things even faster. Do you need any volatile keywords in that code so the compiler doesn't reorganize it?
lurk101
Sat Sep 18, 2021 7:58 pm
$ ./euler36
Also on Pi4, the rust version
#![feature(core_intrinsics)]
use bit_reverse::ParallelReverse;
use std::{intrinsics::ctlz, time::SystemTime};
fn palindrome(x : u32) -> u32 {
    if (x.swap_bits() >> ctlz(x)) == x {
        return x;
    0
fn search() -> u32 {
    let mut sum = 0;
    for i in (1..10).step_by(2) {
        sum = sum + palindrome(i) + palindrome(i * 11);
        for j in 0..10 {
            sum = sum + palindrome(i * 101 + j * 10) + palindrome(i * 1001 + j * 110);
            for k in 0..10 {
                sum = sum + palindrome(i * 10001 + j * 1010 + k * 100) +
                       palindrome(i * 100001 + j * 10010 + k * 1100);
    sum
fn main() {
    let start = SystemTime::now();
    let sum = search();
    let finish = SystemTime::now();
    println!("{} {:?}", sum, finish.duration_since(start));
872187 Ok(4.999µs)
lurk101
Sat Sep 18, 2021 8:07 pm
Sum is 872187
Faster yet by moving search and palindrome functions to ram. Might be the end of the road speeding this one up?
lurk101
Sat Sep 18, 2021 8:31 pm
Or
static unsigned int __not_in_flash_func(palindrome)(unsigned int n, uint32_t sm) {
    uint32_t n2 = n << boot_clz32(n); // do the shift while PIO is crunching
    return n2 == pio_sm_get(pio0, sm) ? n : 0;
The stuff in the middle takes so long that you can run the PIO at 1/2 sysclk.
ejolson
Sun Sep 19, 2021 5:58 pm
On the walk it occurred to me, since it's possible to generate palindromes in order for any base, that one could create a base-two palindrome generator, a base-10 palindrome generator and then check when the two intersect.
This led to the closure madness of
/*  palgen.go -- Generator approach to multi-base palindromes
package main
import (
    . "fmt"; . "os"; "math/big"; "unsafe"; "time"; "flag"
const bsize=512
type palgen func() *big.Int
var (
    One=big.NewInt(1)
    cmax int
var tictime float64
func tic() {
    now:=time.Now()
    now:=time.Now()
func mkepalgen(p *big.Int, b int) palgen {
    var z,t big.Int
    x:=make([]byte,bsize)
    z.Set(p)
    f:=func() *big.Int {
        x=x[:0]
        x=z.Append(x,b)
        z.Add(&z,One)
        m:=len(x)
        x=x[:2*m]
            x[i]=x[len(x)-i-1]
        t.SetString(o1string(x),b)
        return &t
    return f
func mkopalgen(p *big.Int, b int) palgen {
    var z,t big.Int
    z.Set(p)
        x=x[:0]
        x=z.Append(x,b)
        z.Add(&z,One)
        m:=len(x)
        x=x[:2*m-1]
            x[i]=x[len(x)-i-1]
        return &t
    return f
func mkpalgen(p *big.Int, b int) palgen {
    var t big.Int
    fe:=mkepalgen(p,b)
    fo:=mkopalgen(p,b)
    te:=fe()
    to:=fo()
        r:=te.Cmp(to)
        if r<=0 {
            t.Set(te)
            te=fe()
        if r>=0 {
            t.Set(to)
            to=fo()
        return &t
    return f
var Bn=[]int{2,10}
type pt struct { t *big.Int; f palgen }
func main(){
    Printf("palgen--Generator approach to multi-base palindromes\n"+
        "Written 2021 by Eric Olson\n\n")
    flag.IntVar(&cmax,"n",19,"Number of palindromes to find.")
    flag.Parse()
    Pn:=make([]pt,len(Bn))
    for n:=0;n<len(Bn);n++ {
        Pn[n].f=mkpalgen(One,Bn[n])
        Pn[n].t=Pn[n].f()
    Printf("Finding %d palindomes in bases %d...\n\n",cmax,Bn)
    tic()
    count:=0
    sum:=big.NewInt(0)
    for {
        nmin:=0
        nmax:=0
        for n:=1;n<len(Bn);n++ {
            if Pn[nmax].t.Cmp(Pn[n].t)<0 { nmax=n }
            if Pn[n].t.Cmp(Pn[nmin].t)<0 { nmin=n }
        if Pn[nmin].t.Cmp(Pn[nmax].t)==0 {
            count++
            sum.Add(sum,Pn[nmin].t)
            Println(Pn[nmin].t)
        Pn[nmin].t=Pn[nmin].f()
        if count>=cmax { break }
    tsec:=toc()
    Printf(
        "\nSum of all multi-base palindromes:  %d\n"+
        "Calculation time %g seconds.\n",sum,tsec)
    Exit(0)
Note the head of barking and code review whined that the single-base palindrome generators have not been combined into a multi-base generator using another closure. Although even madder, that is now under consideration.
Running on an AMD A6-5400K yields
$ ./palgen
Finding 19 palindomes in bases [2 10]...
1
3
5
7
9
33
99
313
585
717
7447
9009
15351
32223
39993
53235
53835
73737
585585
Sum of all multi-base palindromes:  872187
Calculation time 0.0054168701171875 seconds.
One of the reasons it's slower is the use of a big number library in hopes of scaling up the hopeless search to find numbers which are simultaneously palindromes in bases 2, 3 and 5.
Even before following Fido's advice, the technique, in my opinion, provides an interesting use of closures. Could a similar approach be used in Haskell or even Rust? I wonder if Haskell will ever run on a micro controller like the Pico.
lurk101
Sun Sep 19, 2021 8:50 pm
Don't know about Haskell, but Rust supports an ARMV6-M target.
https://droogmic.github.io/microrust/ge ... BUILD.html
WestfW
Mon Sep 20, 2021 9:53 am
(this has been a more interesting discussion than I had thought it would be. Thank you to everyone who has participated!)
matherp
Mon Sep 20, 2021 10:19 am
Here is a version for MMBasic on the Pico
Option default integer
Timer =0
Dim b$ length 6
Dim c$ length 6
Dim d$,e$
For i=1 To 999999
  b$=Str$(i)
  strrev b$,c$
  If b$=c$ Then
    d$=Bin$(i)
    strrev d$,e$
    If d$=e$ Then
      Print b$,d$
      Inc j,i
    EndIf
  EndIf
Next i
Print Timer/1000 " seconds. Total is ",j
End
CSub strrev
00000000
B085B480 6078AF00 687B6039 60BB781B B2DA68BB 701A683B 60FB2301 68BAE00D
1AD368FB 687A3301 6839441A 440B68FB 701A7812 330168FB 68BB60FB 68FA3301
D3EC429A BF00BF00 46BD3714 4770BC80
End CSub
Uses the ability of MMBasic to call a C routine to reverse the string. Takes 72.1 seconds with a single CPU clocked at 250MHz. Lots of optimisation could of course be done but it demoes the interpreter
ejolson
Mon Sep 20, 2021 2:30 pm
Timer =0
Dim b$ length 6
Dim c$ length 6
Dim d$,e$
For i=1 To 999999
  b$=Str$(i)
  strrev b$,c$
  If b$=c$ Then
    d$=Bin$(i)
    strrev d$,e$
    If d$=e$ Then
      Print b$,d$
      Inc j,i
    EndIf
  EndIf
Next i
End
CSub strrev
00000000
End CSub
It looks like the C binary is included as a sequence of hexadecimal values at the end of the program. Would it be possible to post the C source and explain where those numbers came from?
matherp
Mon Sep 20, 2021 4:41 pm
See the first post in this thread
https://www.thebackshed.com/forum/ViewT ... &TID=14126
matherp
Tue Sep 21, 2021 4:04 pm
Here is a solution in MMbasic by Volhout. 0.888 seconds in interpreted Basic (Pico at 250MHz). I'd be interested in how long the same algorithm would take in Microython
'palindrome numbers are symetrical. in base 10 they should have the form abccba from numbers under 1e6.
'in base 2 they cannot end in a zero, becuase the first bit cannot be zero. This limits to odd numbers.
'in base 10 you will have  to ripple through abccba and abcba and abba and aba and aa and a
OPTION DEFAULT INTEGER
Timer = 0
Total = 0
'6 digits
For a=1 To 9 Step 2
 k=a*100001
 For b=0 To 9
   l=b*10010
   For c=0 To 9
     x=c*1100+l+k
     bincheck
Next c,b,a
'5 digits
For a=1 To 9 Step 2
 k=a*10001
 For b=0 To 9
   l=b*1010
   For c=0 To 9
     x=c*100+l+k
     bincheck
Next c,b,a
'4 digits
For a=1 To 9 Step 2
 k=a*1001
 For b=0 To 9
   x=b*110+k
   bincheck
Next b,a
'3 digits
For a=1 To 9 Step 2
 k=a*101
 For b=0 To 9
   x=b*10+k
   bincheck
Next b,a
'2 digits
For a=1 To 9 Step 2
 x=a*11
 bincheck
Next a
'1 digits, these are all symetrical (b1,b11,b101,b111,b1001)
For x=1 To 9 Step 2
 Total = Total + x
Next x
Print Timer
Print Total
' checking the binary string for symmetry
' the lsb is always 1 (odd), the msb is always 1 (never start with 0)
' so we only check the other digits
' for strings with an odd length we do not test the center bit.
Sub bincheck
 y$=Bin$(x) : w=Len(y$) : z=Int(w/2)
 'Print y$,z,w
 pali=0
 For i=2 To z
   'Print Mid$(y$,i,1),Mid$(y$,w+1-i,1)
   If Mid$(y$,i,1)=Mid$(y$,w+1-i,1) Then
     pali=pali+1
   End If
 Next i
 If pali = z-1 Then
    Total = Total + x
    Print y$," pali"
 End If
End Sub
Tue Sep 21, 2021 5:51 pm
Not ported code but same principle. Generates known odd numbered decimal palindromes, then checks if they are binary palindromes using PIO to reverse the bits - 0.269 seconds at 250 MHz.
import machine
from   rp2     import StateMachine, asm_pio
import time
machine.freq(250_000_000)
@asm_pio()
def ReverseBits():
    pull(block)
    mov(isr, reverse(osr))
    push()
sm = StateMachine(0, ReverseBits)
sm.active(1)
@micropython.native
def Main():
    def Test(n):
        global sum
        sm.put(n)
        x = sm.get()
        while (x & 1) == 0:
            x = x >> 1
        if n == x:
            sum += n
    def f(n, div, mpy):
         return ((n // div) % 10) * mpy
    for n in range(1, 10, 2):
         Test(n)                                                          # a
         Test(n + f(n, 1, 10))                                            # aa
         Test(n + f(n, 1, 100))                                           # a0a
         Test(n + f(n, 1, 1000))                                          # a00a
         Test(n + f(n, 1, 10000))                                         # a000a
         Test(n + f(n, 1, 100000))                                        # a0000a
    for n in range(11, 100, 2):
         Test(n + f(n, 1, 10000)  + f(n, 10, 1000))                       # ab0ba
         Test(n + f(n, 1, 100000) + f(n, 10, 10000))                      # ab00ba
    for n in range(101, 1000, 2):
         if f(n, 100, 1) == f(n, 1, 1):
             Test(n)                                                      # aba and aaa
         if f(n, 100, 1) == f(n, 10, 1):
             Test(n + f(n, 1, 1000))                                      # abba amd aaaa
         Test(n + f(n, 1, 10000)  + f(n, 10, 1000))                       # abcba
         Test(n + f(n, 1, 100000) + f(n, 10, 10000) + f(n, 100, 1000))    # abccba
t = time.ticks_ms()
sum = 0
Main()
t = time.ticks_ms() - t
print("Sum is {}".format(sum))
print("Run time is {} seconds @ {} MHz".format(t / 1000, machine.freq() / 1_000_000))
Sum is 872187
Run time is 0.269 seconds @ 250.0 MHz
Remove the '@micropython.native" decorator and it's 0.335 seconds at 250 MHz. Reworked as '@micropython.viper' would make it faster but it does mean altering the Python source code.
matherp
Tue Sep 21, 2021 6:02 pm
That is definitely cheating using PIO ;)
The MMbasic version is pure interpreted Basic code. I've now got it down to 0.745 seconds by making the code much less nice
Timer =0
GoTo start
bc:
y$=Bin$(x):w=Len(y$):z=w\2
p=0
For i=2 To z
If Peek(byte q+i)=Peek(byte q+w+1-i) Then
Inc p
EndIf
Next
If p = z-1 Then
Inc T,x
EndIf
Return
start:
Option DEFAULT INTEGER
Dim y$
Dim q=Peek(varaddr y$)
For a=100001 To 900009 Step 200002
For b=0 To 90090 Step 10010
x=b+a
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Inc x,1100
GoSub bc
Next :Next
For a=10001 To 90009 Step 20002
For b=0 To 9090 Step 1010
x=b+a
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Inc x,100
GoSub bc
Next :Next
For a=1001 To 9009 Step 2002
For b=0 To 990 Step 110
x=b+a
GoSub bc
Next b,a
For a=101 To 909 Step 202
For b=0 To 90 Step 10
x=b+a
GoSub bc
Next :Next
For x=11 To 99 Step 22
GoSub bc
Next
For x=1 To 9 Step 2
Inc T,x
Next
Print Timer
Print T
Tue Sep 21, 2021 6:20 pm
Using pure Python -
    def Test(n):
        global sum
        b = bin(n)[2:]
        for x in range(len(b) >> 1):
            if b[x] != b[-(x+1)]:
                return
        sum += n
Sum is 872187
Run time is 0.768571 seconds @ 250.0 MHz
Return to “General”
