lurk101
Hunt the Wumpus for Pico
Wed May 12, 2021 6:00 pm
ejolson
Re: Hunt the Wumpus for Pico
Tue Jun 29, 2021 3:01 am
viewtopic.php?p=1864165#p1864165
After the modification described in
viewtopic.php?f=144&t=314736
I now have a Wumpus dongle that when plugged into any computer creates a USB serial port to which one can connect and hunt wumpi.
Could the next step in this pico adventure be a Colossal Cave dongle?
Would it be possible to use the Frotz Z code interpreter to make a general dongle for interactive fiction?
https://davidgriffith.gitlab.io/frotz/
How large can a Pico executable be?
hippy
Tue Jun 29, 2021 11:29 am
Any arbitrary C code should be usable with the Pico though one will have to add shims to provide functionality not directly provided by Pico-SDK.
It should also be possible to wrap that code as a MicroPython C Extension to provide easy access to a file system,
My understanding is; as large as the Flash, and one can go higher than that with compression.
lurk101
Tue Jun 29, 2021 3:39 pm
An updated version of Hunt the Wumpus for Pico that saves the cave across power cycles is available here.
hippy
Wed Jun 30, 2021 7:15 pm
I have 'cmake' built the dumb version for the Pico with just a dummy 'int main(void) {}' added. Someone who knows what they are doing better than me can probably take that further, make it do something.
https://github.com/DavidGriffith/frotz/blob/master/DUMB
ejolson
Thu Jul 01, 2021 5:37 pm
As described in
https://kevinboone.me/picoflash.html
do you need to turn off interrupts when writing to flash?
lurk101
Thu Jul 01, 2021 8:45 pm
As described in
Probably would be safer, but I haven't encountered any issues. But then I haven't tries serial over USB. I'll update the repo.
ejolson
Fri Sep 17, 2021 3:46 pm
As described in
Does anyone know how to build serial over USB and UART support into the same binary so the Pico autodetects which device receives input first and then uses that for all subsequent interaction?
This would facilitate building a universal Pico-based wumpus hunting device that could be accessed either from USB or UART without reflashing.
If it works I would also like to include the technique in this Basic interpreter.
viewtopic.php?p=1914739#p1914739
lurk101
Fri Sep 17, 2021 3:53 pm
This isn't sufficient?
ejolson
Fri Sep 17, 2021 4:08 pm
That requires recompiling and flashing a new binary to switch consoles. In order to distribute a fully self-contained wumpus hunting device, it's convenient if there is a single binary that autodetects which console is in use. That's even more the case with a Basic interpreter.
Is the problem there are too many serial ports that might be assigned to different GPIO pins and hardware configurations for autodetect to be practical?
lurk101
Fri Sep 17, 2021 4:14 pm
Don't know. I'm not sure how that would work? The serial pin assigned stays the same whether USB or SERIAL but you can't detect if a serial device is connected or not. Maybe you can detect a unconnected USB port but I wouldn't know how.
ejolson
Fri Sep 17, 2021 4:18 pm
Don't know. I'm not sure how that would work? The serial pin assigned stays the same whether USB or SERIAL but you can detect if a serial device is connected or not. Maybe you can detect a unconnected USB port but I wouldn't know how.
I think one cycles through plausible baud rates and checks for recognizable input. The user has to keep hitting return until the port is recognized.
lurk101
Fri Sep 17, 2021 4:23 pm
Sorry, cross posted. had updated my post to 'can't detect' instead of 'can detect'. The USB driver should have a way to tell you whether its endpoint is connected.
ejolson
Fri Sep 17, 2021 4:29 pm
That's right. I know how to wait until the USB device is connected. While waiting I think one needs to check if the UART is receiving carriage returns. If so, then one switches to the UART for the console.
From a theoretical point of view it should be simpler than finding a wumpus.
lurk101
Fri Sep 17, 2021 4:36 pm
From a theoretical point of view, it should be simpler than finding the wumous.
That should do the trick. Might not be necessary to poll the UART while waiting for a USB endpoint, It happen pretty quick.
Instead of calling stdio_init_all(), maybe
stdio_usb_init();
if (no_usb_endpoint_connected_after_a_few_seconds())
    stdio_uart_init();
lurk101
Tue Sep 21, 2021 8:47 pm
Thinking about it a little longer, I don't think you need to do any special handling at all to get a Pico app to automatically handle USB console or UART console. With
pico_enable_stdio_uart(test 1)
pico_enable_stdio_usb(test 1)
in the CMakeLists you add both USB and UART on the standard IO driver list. Output is sent to both drivers and input is accepted from either.
Works for USB or UART whichever is in use.
#include <stdio.h>
#include <stdio.h>
#include <stdlib.h>
#include "pico/stdlib.h"
int main() {
    stdio_init_all();
    getchar_timeout_us(1000); // swallow the spurious EOF character???
    for (;;) {
        sleep_ms(10000);
        printf("Hit key ");
        getchar();
        printf("\nworks!\n");
ejolson
Thu Sep 23, 2021 2:33 pm
#include <stdio.h>
#include <stdio.h>
#include <stdlib.h>
int main() {
    stdio_init_all();
    for (;;) {
        sleep_ms(10000);
        printf("Hit key ");
        getchar();
That's interesting. Would the speed of output be significantly slower by having two devices active? Is the baud rate of the UART much slower than USB?
lurk101
Thu Sep 23, 2021 3:20 pm
Hard to say. The default serial baud rate is 115200 baud. For interactive use I perceive no difference.
RichardRussell
Thu Sep 23, 2021 10:53 pm
A better test would be the BBC BASIC 'pseudo graphics' demos such as hanoi.bbc, snake.bbc sortdemo.bbc, sudoku.bbc etc. If their screen updates don't get noticeably slower through being capped at 115200 baud you'll probably be OK outputting to both serial and USB.
lurk101
Thu Sep 23, 2021 11:58 pm
I did run the hanoi demo, in fact it's the only one I ran, and it looked normal. In any case, I've found a technique that works by detecting the presence of a driven UART RX pin and allows me to initialize the correct driver without user intervention.
viewtopic.php?f=144&t=319577&start=125#p1916980
Return to “General”
