HermannSW
gettimeofday() not working with SDK?
Mon Jan 25, 2021 9:00 pm
Long ago I used code that just did excessive search for minimal magic 3x3 square consisting of distinct primes for comparing different microcontrollers. Later I added numbers for Intel laptop and Raspberry PIs as well:
viewtopic.php?p=1290845#p1291239
I only needed small changes to get q32.c running on Pico with USB output:
https://stamm-wilbrandt.de/en/forum/q32.c
$ diff q32.c ../../../hello_world/usb/hello_usb.c
3a4
> #include "pico/stdlib.h"
21,22c22,25
<   gettimeofday(&tv1, NULL);      // wait for usec change
<   do  gettimeofday(&tv0, NULL);  while (tv0.tv_usec == tv1.tv_usec);
>   stdio_init_all();
>   sleep_ms(5000);
It was strange that loop waiting for microsecond change did not work and I had to remove.
But final microsecond duration output of 0 seems to indicate that gettimeofday() is not implemented as on Raspberry Pi OS:
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyACM0, 21:47:03
Press CTRL-A Z for help on special keys
 47| 29|101|
113| 59|  5|
 17| 89| 71|
0us
Is it correct that gettimeofday() cannot be used to measure microsecond precision time deltas?
If that is true, is there an alternative microsecond precision time delta measurement method in Pico SDK?
https://stamm-wilbrandt.de/en#raspcatbt
Re: gettimeofday() not working with SDK?
Mon Jan 25, 2021 10:26 pm
kilograham
Mon Jan 25, 2021 11:23 pm
or time_us32() or time_us64()
HermannSW
Tue Jan 26, 2021 7:17 am
Perhaps
https://raspberrypi.github.io/pico-sdk- ... stamp.html
Does not work when using sleep_ms() between taking two timestamps, but does work when doing something.
This is output for 1000 loops incrementing another integer as well, 1700us:
Port /dev/ttyACM0, 08:11:40
10000
1700us
This is the code -- does timer sleep while sleep_ms();
#include <stdio.h>
absolute_time_t t0,t1;
int i,k;
int main(void)
  stdio_init_all();
  sleep_ms(5000);
  t0 = get_absolute_time();
//  sleep_ms(3333);
  k=0;
  for(i=0; i<10000; ++i)
    k++;
  t1 = get_absolute_time();
  printf("\n%d\n%ldus\n", k, absolute_time_diff_us(t0, t1));
  return 0;
HermannSW
Tue Jan 26, 2021 7:24 am
Thanks, time_us_32() does work even when sleeping in between.
And wraps only after more than an hour, I want to measure sub millisecond time deltas:
https://raspberrypi.github.io/pico-sdk- ... ea1610c55d
Below code (correctly) outputs this for sleeping 3.333 seconds:
3333004us
#include <stdio.h>
uint32_t t0,t1;
int main(void)
  stdio_init_all();
  sleep_ms(5000);
  t0 = time_us_32();
  sleep_ms(3333);
  t1 = time_us_32();
  printf("\n%ldus\n", t1-t0);
  return 0;
HermannSW
Tue Jan 26, 2021 7:40 am
time_us_32() resolved the issues with q32.c measurement, magic 3x3 distinct prime square computed in 397us:
Port /dev/ttyACM0, 08:32:34
 47| 29|101|
113| 59|  5|
 17| 89| 71|
397us
Find small diff to q32.c further below, q32.pico.c is here:
https://gist.github.com/Hermann-SW/6772 ... 543d9d3dbe
397us is slower than ESP microcontrollers (and PIs of course), but faster than all Arduinos tested.
Need to figure out how to compile with -O3 for the Pico.
Did figure out (not perfect), added "-O3" after 1st "$(C_FLAGS)" to
/home/pi/pico/pico-examples/build/hello_world/usbCMakeFiles/hello_usb.dir/build.make
-O3 reports 357us:
Port /dev/ttyACM0, 09:01:21
 47| 29|101|
113| 59|  5|
 17| 89| 71|
357us
This is simple pure integer arithmetic single threaded code, but I have numbers for many different MCUs/CPUs:
Small diff of Pico code to q32.c:
3a4
17c18
< struct timeval tv0,tv1;
> uint32_t t0,t1;
21,22c22,26
>   stdio_init_all();
>   sleep_ms(5000);
>   t1 = time_us_32();      // wait for usec change
>   do  t0 = time_us_32();  while (t0 == t1);
41c45
>                   t1 = time_us_32();
47c51
<                     1000000*(tv1.tv_sec-tv0.tv_sec)+tv1.tv_usec-tv0.tv_usec);
>                     t1 - t0);
kilograham
Tue Jan 26, 2021 2:33 pm
Can you clarify this?
HermannSW
Tue Jan 26, 2021 9:32 pm
As I showed, correct time delta was reported when doing something between two calls of get_absolute_time().
Using time_us_32() also works if only sleeping between taking timestamps:
#include <stdio.h>
#include <tusb.h>
int main(void)
  stdio_init_all();
  while (!tud_cdc_connected()) { sleep_ms(100);  }
  printf("tud_cdc_connected()\n");
  uint32_t t0 = time_us_32();
  sleep_ms(3333);
  uint32_t t1 = time_us_32();
  return 0;
Here the correct time delta gets reported:
tud_cdc_connected()
3333003us
Taking timestamps with get_absolute_time() and sleeping in between does not work:
  absolute_time_t t0 = get_absolute_time();
  sleep_ms(3333);
  absolute_time_t t1 = get_absolute_time();
  printf("\n%ldus\n", absolute_time_diff_us(t0, t1));
Incorrectly 0us gets reported:
tud_cdc_connected()
0us
So we have bug1 that gettimeofday does not work at all.
And bug2 that get_absolute_time() does not work for sleeping between taking timestamps.
time_us_32() just works correctly.
kilograham
Wed Jan 27, 2021 1:45 am
it is a 64 bit value on a 32bit architecture, so use %lld or cast it to a 32 bit value
as for gettimeofday() - yes that might be nice to have work from the RTC; it doesn't today, feel free to file an issue against pico-sdk in github
HermannSW
Wed Jan 27, 2021 5:05 am
You are right, with that format change time delta gets reported correctly:
tud_cdc_connected()
3333004us
Done:
https://github.com/raspberrypi/pico-feedback/issues/24
HermannSW
Wed Jan 27, 2021 1:15 pm
Issue got closed, I am not able to reopen, but commented why reopen is really needed for Pico gettimeofday():
https://github.com/raspberrypi/pico-fee ... -768276323
Return to “SDK”
