carlk3
Context switching breaks SPI/DMA
Fri Mar 12, 2021 3:45 am
I'm having problems with SPI and DMA, when trying to use high speeds in a mult-tasking environment. I've tried to extract a simple test case from my large project, but I can't recreate the problem if I simplify it too much. So, I have posted a complete project, based originally on pico-examples/spi/spi_dma, to https://github.com/carlk3/spi_dma.
The gist of it is that in single-threaded mode, I can run the SPI at a baud rate up to 20,833,333. However, I'm running multiple tasks in FreeRTOS. As soon as I introduce one or more additional tasks, I start to get random, flaky errors. No error indications, just bad data.
In the main program, spi_dma.c, I have defines for the number of tasks and the baud rate. For example, this passes the test:
#define N_TASKS 1
#define BAUD_RATE 20833333
However, this fails:
#define N_TASKS 2
#define BAUD_RATE 5000 * 1000
It eventually yields something like:
T1: Done. Checking...T1: Mismatch at 261/1024: expected 7b, got 67
T1: at /home/carlk/pi/pico/spi_dma/spi_dma.c:283: testTask
(different every time).
If I back the speed way down:
#define N_TASKS 2
#define BAUD_RATE 2000 * 1000
it appears to run OK.
What could be happening here? FreeRTOS uses isr_pendsv for task switching. Why would that mess with the SPI/DMA transfer?
carlk3
Re: Context switching breaks SPI/DMA
Sat Mar 13, 2021 6:09 pm
Doing some more digging on this, and it just gets weirder!
When I do the checking after the transfer, it frequently looks as if the *transmit* buffer has changed! I changed the code to hex dump the expected vs. actual transmit buffer and here is a typical run:
SPI DMA example
Actual frequency: 5681818
T0: Done. Checking...T0: All good
T1: Done. Checking...T1: All good
T0: hexdump_8(Expected:, 0x20002DC8, 1024)
a7 f1 d9 2a 82 c8 d8 fe 43 4d 98 55 8c e2 b3 47 17 11 98 54 2f 11 2d 05 58 f5 6b d6 88 07 99 92
48 33 62 41 f3 0d 23 e5 5f 30 d1 c8 ed 61 0c 4b 02 35 39 81 84 b8 14 a2 9c b4 5a 67 2a ca e5 48
e9 c5 f1 b0 c4 15 8a e5 9b 4d 39 f6 f7 e8 a1 05 d3 fe ed a5 d5 f3 d9 e4 5b fa 6c c3 51 e2 20 ae
0c e1 06 98 6d 61 ff 34 a1 1e 19 fd 36 50 e9 b7 81 8f c3 3a 1e 0f c0 2c 44 55 7a c8 ab 50 c9 b2
de b2 f6 b5 e2 4c 4f dd 9f 88 67 bd ce 1f f2 61 00 8e 78 97 97 0e 34 62 07 d7 5e 47 a1 58 29 8e
5b a2 f5 62 46 86 9c c4 2e 36 2a 02 73 12 64 e6 06 87 ef 53 09 d1 08 53 4f 51 f8 65 8f b4 f0 80
b7 cb 19 ee 9a eb d7 18 cc 4f a2 7c 8c 37 df c1 ad a5 d1 33 d1 3a be 03 f0 21 e9 b1 b7 8c cb d8
2f 7f f2 b3 8c 6d 48 d0 1e 48 1b 2d 4f af 71 71 80 5f d7 f2 d3 9e f4 c4 f1 9b 94 96 e8 1d ab 81
93 b3 73 7e 1b 27 d9 c4 39 57 16 64 41 b9 35 15 e8 f0 3c 95 d8 e8 ce 1e 18 64 fa ad 68 dd fc 59
32 13 01 09 39 0b 0f 1f e5 ca 71 68 05 f8 36 2e 98 dc ca ad c8 6a db ed 25 80 1a 9a 9d cf a6 26
43 19 dd af e8 3a 89 c5 1f 3c 6d 19 9d 38 de 10 e6 60 c3 7b e8 72 c3 f2 b3 16 60 de 8b c9 59 02
b9 10 32 62 cd b9 41 f7 73 76 f5 d3 db b7 a3 d5 a3 87 79 7f c4 81 9a 03 5e ca 70 4c ed b3 71 10
ee 7f 20 6b 0c 88 05 aa eb f4 96 3e 7c 47 08 ce 8d 4e 09 23 66 e7 17 92 a8 a3 b2 bb cd ee 32 1b
3e 15 38 0c 54 1e f0 93 08 88 96 9f 74 57 af e1 85 88 82 6a 41 9d 58 31 1c 17 84 b5 48 4e ec db
39 3f 6a 0a ca 11 b9 1d f0 86 6b 50 0b 8d ee 50 1f d7 eb 9b ce 09 a1 7d 74 12 4b 46 05 ad fc 07
77 be d9 81 6d 8d 7e 84 88 54 4a 18 d8 04 5c b3 28 3b 0a 75 2b 88 1b 5f 50 0f ad b5 90 10 e6 3d
1b 66 4f 8b da 2d bf 33 cb 6b e2 1c 8e b3 ec a9 d9 d5 bf 14 4c 08 e9 57 7e d0 d1 e5 e5 60 87 51
09 b3 40 98 05 80 47 3d bc 2e 68 9a 3b e8 38 e7 7a 0a 33 48 fe 96 0e c9 bf 81 da 36 f1 86 8c a5
d2 47 88 fa 4c 0c 77 8b f0 d1 23 14 28 54 95 63 65 16 cf 40 86 1b 3d 73 7f d3 5d bb 59 1c 5b 5d
25 91 6e b1 d8 61 76 b1 4e 0e 67 d2 d0 39 57 f0 cf 6c 87 83 4b f3 28 54 05 88 36 0b a7 c7 c5 f8
85 41 63 4f b7 ba de 5f 94 ff 67 1d 1f eb dc bd a1 16 d2 da 77 90 38 ed 76 79 89 6c 29 19 8b 26
57 b5 8c 50 ea 05 4f 64 4f 41 29 c8 ba 8d 8d 54 4b 72 76 33 dd 40 75 43 98 04 67 96 e0 38 62 6f
ef 92 37 ce 5b 61 5b c0 86 77 ee 5a bf bd 85 f7 3f 7f 88 68 cb 1b 5f ba 4c 13 09 f1 60 61 aa 13
38 21 fb e2 a7 58 d2 bb e6 aa 04 0a 94 0d 41 b7 d3 b8 69 ce e9 45 15 0a a4 a4 0e 6f f7 19 ee c2
4b 26 81 cd 5c e0 6b 50 27 34 36 58 40 66 04 66 56 d5 ef ed 73 15 75 91 89 d6 88 15 dd b9 e5 f8
d7 fd 53 b6 ec 09 66 16 a7 73 b9 42 1f 67 04 ce d3 6e f4 e4 84 ba 0c 6c 5a 48 55 c7 1c 33 a5 4a
c8 2b e8 03 e5 cf d1 75 77 9f c4 44 b7 e6 aa 90 01 ee fa be bc 0c f9 97 54 88 7c 7b 0a 27 af dd
c4 15 f8 a0 2c 5a f1 ef ea 26 ad 1e 5d 92 b1 e2 9a 8f af 5b 21 86 c3 09 4f 4a 13 7b cf aa 65 d7
b2 74 21 4d b6 4c 86 f3 08 5b 24 93 8e 18 32 fb 31 0a 6f 06 41 81 e2 98 d2 30 62 ab c8 17 ba 17
30 23 c8 c0 4c 5c 3a 1e cb f4 af 72 37 2b 38 1f f6 98 65 c8 f0 e3 c7 0b 93 1c 45 a7 41 9b 3c 44
18 42 eb fa cc 3d 07 0a c3 b4 33 cd 12 0b 6e 85 b7 2d ad cf 40 b2 3b 17 3c 34 f6 be 1b 19 01 f6
62 1f 14 97 b0 85 cf 8e 99 9d 98 6e f8 ff 3a 88 9a 02 38 97 99 83 a8 68 6f 69 e1 0e f9 24 9a 87
T0: hexdump_8(txbuf, 0x200035C8, 1024)
77 be d9 81 6d 8d 7e 84 88 54 4a 18 d8 04 0e d0 e6 a3 ec 3f 88 a2 a3 dc 71 c1 c4 3c 2b 28 cc 7f
96 19 c1 b9 3f 5f 00 e5 cd be b6 3d 5b c1 ab 18 35 5d 66 02 d3 76 f4 73 55 1d 80 d1 1f bc 7b a0
8d 5f c8 d7 c7 7d 8b 27 1f 7a 57 b9 55 42 25 32 91 d1 8e 92 53 5b 43 48 cd ab 52 44 09 bb e6 ae
e0 5d c2 9c 5d 50 db 89 66 94 27 d9 8e 64 15 79 8e 53 18 3c 3d af 7f 96 07 a8 d0 9a e3 ca 72 7d
1c 78 74 79 d9 37 47 f1 3d c0 1c 87 fe 6e 7a 48 81 2b 7e fe f3 c9 a4 be 0c 22 2a 22 e1 68 a6 67
25 69 5a 22 ce 53 6d a8 38 37 e4 71 74 e2 03 08 29 30 f5 45 b0 23 35 ef d4 dd b0 4c 7d 7b 48 1c
38 31 16 15 32 be be 73 18 95 1e 21 be 8c 23 f8 38 57 77 20 3b 47 9b 95 6a ec 56 37 4d 77 c9 24
51 57 d7 a1 5a f9 bc 26 2a 9c 27 56 d4 5c d2 09 e4 2e c6 e9 f9 ce 90 7d 31 e5 7e 52 4b f6 6f 05
cb e8 82 6a 24 bc 4c 5e 5d 8b 46 17 84 cf 71 b1 22 96 f6 2c 50 f6 be d3 3d 76 20 09 5f c3 8d cd
3d 33 85 92 f1 64 c6 68 2f 88 f0 d8 98 92 42 89 b6 d4 34 ca b4 2a 82 12 de 92 a2 b7 f1 9b d1 27
4e 62 7e c4 6c 86 e1 46 9a ec a8 16 e3 53 53 5c 8a 5b a2 35 6d 38 f7 05 fb 9a 4f 88 40 7a 97 d7
10 60 2e 90 33 a0 cd fc e7 f5 78 ab 13 de c1 65 4c fd 75 98 23 3e 8d cf b6 bc b5 8f 9e ae ce 44
3d 77 15 b4 e3 4f b5 ef 05 38 37 fa 01 c2 6b c8 b8 d9 8b 79 ac 50 e2 19 af ae 37 bd 12 f6 11 ca
28 83 0a 5b e9 24 90 5d a0 b5 91 08 aa 15 85 f6 b1 e9 9e 30 f2 20 0e 60 b9 d1 00 81 ad 97 7f 05
07 7f 69 03 29 d2 9b 0f 0c a3 c6 ee 05 23 27 30 8f 60 c4 bd 7e b5 cf c1 45 5e 18 47 83 41 29 09
91 fa 35 0c c5 26 b6 6d 7c 4c bd 9f e7 a2 40 c9 b4 bf d0 b3 33 ec ee b8 91 81 74 29 b0 89 da 8f
96 26 84 2b cb 56 83 3f ad ef 5e 71 c4 62 96 db 02 71 13 df e7 51 bd fd d4 5a 74 2c 24 82 88 a8
T0: Mismatch at 494/1024: expected 5c, got 0e
T0: 	at /home/carlk/pi/pico/spi_dma/spi_dma.c:280: testTask
Even more bizarrely, sometimes checking the same buffer twice yields different results! On a hunch I added a delay after the transfer:
        spi_lock(&spi);
        spi_transfer(&spi, txbuf, rxbuf, TEST_SIZE);
vTaskDelay(pdMS_TO_TICKS(2));
        spi_unlock(&spi);
and with that I can up the baud rate to 20833333 and run two or three tasks successfully.
I am puzzled. It's almost like the memory needs time to settle, or something.
kilograham
Sat Mar 13, 2021 11:00 pm
If u sure you aren't blowing off the end of your stack? sounds like memory corruption somewhere (perhaps your locking is broken) - i haven't looked closely
Things don't need "time to settle".
fivdi
Sun Mar 14, 2021 9:28 am
At 1536 words or 6144 bytes the stack for testTask is quite big. On the other hand, testTask creates two fairly large buffers called txbuf and rxbuf on the stack, each having 1024 bytes. The Pico has RAM to burn, so you could double or triple the stack size to see if it helps.
If adding the call vTaskDelay(pdMS_TO_TICKS(2)) directly after the call to spi_transfer() resolves the issue and I had to take a wild guess why this resolves the issue, I would say that spi_transfer is returning before the transfer has fully completed and that it needs to wait for something else to happen before it returns.
kilograham
Sun Mar 14, 2021 4:58 pm
yup it sounds like enough stack - i don't know enough about the RP2040 port to know if there could be a byte/word bug in this code
yeah it is always worth checking whether DMA's complete before operations complete (which can be a problem with writing to devices with FIFOs), however triggering on the DMA read complete should be OK.
My best debugging advice is to twiddle some pins at meaningful times and look on a logic probe (or a pico being a logic probe!)
carlk3
Sun Mar 14, 2021 5:47 pm
To make sure, I added a call to vTaskGetInfo and it showed a Stack High Water Mark: 594 (words). (The stack high water mark is the minimum amount of stack space that has ever existed, so the closer the number is to zero the closer the task has come to overflowing its stack.) So, according to FreeRTOS, there is a huge amount of headroom. But, I went ahead and removed the tx and rx buffers from the stacks to static arrays. Now, I see Stack High Water Mark: 1096, but the test still quickly fails without the 2 ms. delay after the spi_transfer().
SPI DMA example
Actual frequency: 20833333
T0: Done. Checking...T3: Done. Checking...T0: All good
T0: Stack High Water Mark: 584
T3: All good
T3: Stack High Water Mark: 594
T2: Done. Checking...T1: Done. Checking...T0: Done. Checking...T3: Done. Checking...T1: All good
T1: Stack High Water Mark: 594
T3: All good
T2: All good
T2: Stack High Water Mark: 594
T2: Done. Checking...T1: Done. Checking...T2: All good
T0: All good
T0: Done. Checking...T1: Done. Checking...T0: All good
T2: Done. Checking...T1: All good
T0: Done. Checking...T3: All good
T0: All good
T1: All good
T1: Done. Checking...T3: All good
T0: Done. Checking...T2: Done. Checking...T0: All good
T1: All good
T3: Done. Checking...T1: Done. Checking...T3: All good
T2: All good
T1: All good
T1: Done. Checking...T0: Done. Checking...T1: All good
T1: All good
T2: Mismatch at 785/1024: expected 05, got d5
T2: 	at /home/carlk/pi/pico/spi_dma/spi_dma.c:297: testTask
SPI DMA example
T0: Stack High Water Mark: 1096
T3: All good
T3: Stack High Water Mark: 1106
T2: Stack High Water Mark: 1106
T1: Stack High Water Mark: 1106
T2: Done. Checking...T3: All good
T2: All good
T1: All good
T3: Stack High Water Mark: 1096
T0: Done. Checking...T1: Stack High Water Mark: 1106
T0: All good
T3: Done. Checking...T2: Done. Checking...T3: All good
T2: All good
T3: All good
T2: All good
T1: Done. Checking...T2: Stack High Water Mark: 1106
T1: All good
T3: All good
T3: Done. Checking...T2: All good
T0: Done. Checking...T2: All good
T3: All good
T0: All good
T0: All good
T2: Done. Checking...T3: Done. Checking...T2: All good
T3: All good
T2: Done. Checking...T1: Done. Checking...T0: Done. Checking...T1: All good
T3: All good
T3: Done. Checking...T1: Done. Checking...T2: Stack High Water Mark: 1106
T1: All good
T3: All good
T0: All good
T3: Done. Checking...T0: Done. Checking...T3: All good
T0: Stack High Water Mark: 1090
T3: Done. Checking...T1: Done. Checking...T2: All good
T3: All good
T1: All good
T3: Done. Checking...T1: Done. Checking...T0: Stack High Water Mark: 1090
T1: Mismatch at 278/1024: expected d8, got de
T1: 	at /home/carlk/pi/pico/spi_dma/spi_dma.c:297: testTask
I've pushed the changes to https://github.com/carlk3/spi_dma/blob/master/spi_dma.c.
carlk3
Sun Mar 14, 2021 5:56 pm
That was my first thought, too. At first, I thought waiting for the DMA to raise IRQ line 0 when the RX channel finishes a block would be sufficient. When that failed, I added
    dma_channel_wait_for_finish_blocking(this->tx_dma);
    dma_channel_wait_for_finish_blocking(this->rx_dma);
just to be sure. Still, no luck. I sprinkled in some
    configASSERT(!dma_channel_is_busy(this->tx_dma));
    configASSERT(!dma_channel_is_busy(this->rx_dma));
but those have never triggered.
audryhome
Sun Mar 14, 2021 10:30 pm
I noticed the same phenomenon on simple DMA-SPI transfers with interrupts, no RTOS, just the sdk and C.
DMA interrupt handler is fired before alld data is transmitted, so you need to sync with the spi registers or to add a delay (ugly) if you don't want your dma handler act too soon, IMO this normal, since the DMA engien finishes his job after having posted last data item into the SPI FIFO, doesn't car about SPI registers.
carlk3
Mon Mar 15, 2021 4:23 am
That makes good sense, but I don't think it's the problem in this case, because my logic analyzer shows that the ISR is entered after the SPI transfer is complete:
Screenshot from 2021-03-14 22-17-21.png (63.82 KiB) Viewed 1905 times
Screenshot from 2021-03-14 22-15-06.png (102.47 KiB) Viewed 1905 times
The line labeled "DMA cmplt" is toggled in the ISR itself.
EDIT: Also, I'm triggering on the receive DMA complete event:
    // Tell the DMA to raise IRQ line 0 when the channel finishes a block
    dma_channel_set_irq0_enabled(this->rx_dma, true);
    irq_set_enabled(DMA_IRQ_0, true);
So, that should happen when the DMA has pulled the last byte out of the RX FIFO and copied it to memory, right? And, since SPI is synchronous, of the receive is complete, then so must be the transmit.
But I will peek at the SPI status register, anyway.
carlk3
Mon Mar 15, 2021 5:13 am
I wasn't too sure what I'd see since I'm using SPI loopback. Looks like I get everything except MISO, which I guess makes sense, since that's an input:
Screenshot from 2021-03-14 22-48-55.png (124.22 KiB) Viewed 1894 times
I added some GPIOs:
  • * DMA cmplt: Gets toggled in the RX DMA IRQ handler, and in the task code after notification from the IRQ handler.
    * Task 0: Turned on in void vTaskSwitchContext( void ) when T0 is the new task, off otherwise.
    * Task 1: Turned on in void vTaskSwitchContext( void ) when T1 is the new task, off otherwise.
    * Trigger: Turned on when a data mismatch is detected.
In this case, the error was "T1: Done. Checking...T1: /home/carlk/pi/pico/spi_dma/spi_dma.c:291: testTask: Mismatch at 108/1024: expected 76, got 44". That comes from this block of code:
        // Has the transmit buffer changed?!
        rand_st = seed;
        for (uint i = 0; i < TEST_SIZE; ++i) {
            uint8_t x = rand_r(&rand_st);
            if (txbufs[task_no][i] != x) {
                FAIL("txbuf", txbufs[task_no], TEST_SIZE, seed,
                    "Mismatch at %d/%d: expected %02x, got %02x\n", i, TEST_SIZE,
                    x, txbufs[task_no][i]);
Here is expected data from the pseudo-random number generator:
Expected:
80 90 e0 3a 44 1c 06 56 d6 f7 31 c2 6a 04 86 c3 d5 80 31 08 b5 d7 cb f7 6c c3 8b 53 35 d9 f4 61
21 86 5e aa d0 e0 fe ae 9f 7d dc 60 d3 89 50 f1 22 b7 e2 bd 1e 23 2d 15 3e 72 74 87 73 40 c2 28
fe bf a2 0b 79 89 40 b1 a3 f4 c3 3b f8 06 e1 e2 e9 10 82 d8 ef d0 de 5c ff 71 1d a7 ac 41 4b 6c
34 eb 22 35 c4 bb a4 16 93 49 e6 84 44 3f fa df c6 f2 cf 6b 14 9b 5b 10 0b a3 00 35 83 5a f8 1e
17 28 71 d3 13 57 b1 b1 bf 12 cb ec 4b fa 47 92 7d 34 12 c8 a0 3e 3b 7b 90 99 28 d0 90 53 cf 66
9f 3c b1 1a 03 73 36 12 79 34 10 71 8b 14 09 2e 20 91 e4 ba ac b9 67 f7 d3 9b 56 f4 a0 6e 3c 40
cc e8 e0 3b 79 d0 b8 69 58 d9 7e 7a 6c a5 c4 c1 8d b4 c9 f0 b8 5d 6f db 66 da de 82 f1 43 bb 08
db be 55 d7 19 f5 6e 71 45 11 b9 fe 9b b9 a8 c1 70 b8 bb 67 ae 1b 7f 13 d0 ce 00 00 62 dd a8 b5
d7 d7 9a 6b da ea 8c 0a e1 d0 1b 1b 8a b1 f9 f9 31 22 58 a4 63 64 36 24 18 01 18 fd 1f e8 11 b2
4c 96 ea 94 fe a0 9d 8d 9c 51 d9 65 d9 60 55 51 07 4c 1d a8 59 0f e1 c3 c6 4b 2a 59 92 94 3e 6e
e8 c7 de a8 11 43 a7 cb c2 37 a1 af b2 39 3c 31 23 0a af a0 55 56 c1 5d dc 78 3a 78 a9 ba c2 54
b3 4d 7e 13 d5 ac c5 c2 ea 01 a3 d2 c5 f5 a2 fc 9f ec d8 ba 68 82 14 da 5a 37 4a 60 fe d9 a3 60
15 80 3f 8a 14 73 e4 5f b7 00 4a 42 08 c5 31 1b b1 50 d4 da 44 a3 e8 2f 57 a7 01 8d c2 63 1c 87
09 94 5c 26 06 3d 3a c2 39 13 24 ea 59 c9 d7 aa 87 7e 45 00 ed 83 30 be 49 de 56 c4 04 0f 7c 98
ac ce 4d 10 46 fa ad eb 7c 21 a0 36 e8 f2 1f 61 d8 b9 a1 d5 0e 9a 8e c6 00 16 cc 37 8a d7 30 eb
8f 7c 83 8a bf e2 77 20 2e 62 3f 5f 56 57 60 84 1d 9c 48 d3 ce 2f 9c 9d 53 95 df 94 06 54 0f f9
bd 4f f4 82 4b dc bf 86 b8 c2 62 08 38 fd 3b aa b9 df 9a 15 2f 78 fb a0 09 0f c3 94 c2 0d eb af
b6 a9 5b 49 ef 61 eb d9 31 77 4d 2e c5 3a 33 9e 0a 35 bc 25 0d 1b 66 c3 d5 ee 1f 5b a1 31 0a ba
1d e5 3e 00 22 55 b6 97 7b 91 e5 79 15 4d 88 ac a5 41 e9 6a 5c aa e6 d0 85 85 93 e2 87 42 f6 9c
9a 8b 59 da 3f a1 5b b0 19 1d b7 3c 6e fd b8 04 c3 04 e0 cb e9 aa 1d 44 b7 33 7e fb ec ef a7 12
ff d1 bb f7 d8 68 45 c9 14 f8 e9 93 85 ab 0e 8c c2 02 47 6d c2 56 5e d9 02 98 d5 2c 88 92 f5 1c
b0 cb 15 03 58 e1 db 09 cb f6 f7 37 40 ea f5 4d dc 42 3e 94 fc 49 a2 c4 59 55 8c 46 4e 55 3f c9
cb 38 93 40 dd 84 86 42 29 84 1f 0d b1 c6 cc ce f7 e2 41 3e d3 d9 b4 3e 3d da c4 a3 4d a3 5a c3
78 9e b4 4c e4 75 57 e9 43 1d 12 73 20 d3 80 f7 a3 6d a3 79 c0 8f b5 59 37 0d 62 8c b8 ac 26 60
ab 2a 87 c9 3e 19 8e 7c ee 3e 2f 67 14 14 07 13 3b b0 f1 b6 b4 d3 a7 87 e8 72 75 f3 e2 95 c9 04
e6 c2 ee 23 6f cb 31 67 c3 f8 b5 4a df f0 2b 18 df 5c 70 09 5a 70 2e 0b 14 35 8c d6 48 e8 f0 62
51 f2 70 be 8e b0 b0 d8 8f 89 12 3d da 1e 32 7c d0 57 74 2e 6d 65 b6 89 3f 3d 39 bf 5e f7 a6 92
0e 8a 7c 34 1e 7b ea 99 10 19 ab 49 b8 4a b7 2f 30 cc b6 93 d5 7f d9 b3 ec 68 e5 af 81 3d d1 d2
52 66 b0 ad 31 2a 58 92 25 d5 6d a8 12 4d 00 f5 b0 42 ac 21 a5 ea 0f 51 06 3a 30 93 60 d5 01 e5
47 a4 35 29 41 5c 6b 1d bb 2f 86 09 99 c8 6a b6 6b 25 97 2d 77 cb af bb d0 78 b3 86 b8 cc 5f 6e
10 0d d5 6a 4a d4 fd 02 f5 18 fb c2 23 dc 4b eb ea d4 dd d2 2c 44 d5 a9 6f 38 75 23 f9 8f b5 6b
7b aa 43 c4 68 f7 d4 1f f8 cc 10 1f 71 99 14 6b 4d 4f 6b d5 b2 ef 55 0e 80 d6 d0 3a c9 04 2c ed
Here is the TX buffer:
hexdump_8(txbuf, 0x20002588, 1024)
and here is what the logic analyzer saw on MOSI:
80 90 E0 3A 44 1C 06 56 D6 F7 31 C2 6A 04 86 C3 D5 80 31 08 B5 D7 CB F7 6C C3 8B 53 35 D9 F4 61
21 86 5E AA D0 E0 FE AE 9F 7D DC 60 D3 89 50 F1 22 B7 E2 BD 1E 23 2D 15 3E 72 74 87 73 40 C2 28
FE BF A2 0B 79 89 40 B1 A3 F4 C3 3B F8 06 E1 E2 E9 10 82 D8 EF D0 DE 5C FF 71 1D A7 AC 41 4B 6C
34 EB 22 35 C4 BB A4 16 93 49 E6 84 44 3F FA DF C6 F2 CF 6B 14 9B 5B 10 0B A3 00 35 83 5A F8 1E
17 28 71 D3 13 57 B1 B1 BF 12 CB EC 4B FA 47 92 7D 34 12 C8 A0 3E 3B 7B 90 99 28 D0 90 53 CF 66
9F 3C B1 1A 03 73 36 12 79 34 10 71 8B 14 09 2E 20 91 E4 BA AC B9 67 F7 D3 9B 56 F4 A0 6E 3C 40
CC E8 E0 3B 79 D0 B8 69 58 D9 7E 7A 6C A5 C4 C1 8D B4 C9 F0 B8 5D 6F DB 66 DA DE 82 F1 43 BB 08
DB BE 55 D7 19 F5 6E 71 45 11 B9 FE 9B B9 A8 C1 70 B8 BB 67 AE 1B 7F 13 D0 CE 00 00 62 DD A8 B5
D7 D7 9A 6B DA EA 8C 0A E1 D0 1B 1B 8A B1 F9 F9 31 22 58 A4 63 64 36 24 18 01 18 FD 1F E8 11 B2
4C 96 EA 94 FE A0 9D 8D 9C 51 D9 65 D9 60 55 51 07 4C 1D A8 59 0F E1 C3 C6 4B 2A 59 92 94 3E 6E
E8 C7 DE A8 11 43 A7 CB C2 37 A1 AF B2 39 3C 31 23 0A AF A0 55 56 C1 5D DC 78 3A 78 A9 BA C2 54
B3 4D 7E 13 D5 AC C5 C2 EA 01 A3 D2 C5 F5 A2 FC 9F EC D8 BA 68 82 14 DA 5A 37 4A 60 FE D9 A3 60
15 80 3F 8A 14 73 E4 5F B7 00 4A 42 08 C5 31 1B B1 50 D4 DA 44 A3 E8 2F 57 A7 01 8D C2 63 1C 87
09 94 5C 26 06 3D 3A C2 39 13 24 EA 59 C9 D7 AA 87 7E 45 00 ED 83 30 BE 49 DE 56 C4 04 0F 7C 98
AC CE 4D 10 46 FA AD EB 7C 21 A0 36 E8 F2 1F 61 D8 B9 A1 D5 0E 9A 8E C6 00 16 CC 37 8A D7 30 EB
8F 7C 83 8A BF E2 77 20 2E 62 3F 5F 56 57 60 84 1D 9C 48 D3 CE 2F 9C 9D 53 95 DF 94 06 54 0F F9
BD 4F F4 82 4B DC BF 86 B8 C2 62 08 38 FD 3B AA B9 DF 9A 15 2F 78 FB A0 09 0F C3 94 C2 0D EB AF
B6 A9 5B 49 EF 61 EB D9 31 77 4D 2E C5 3A 33 9E 0A 35 BC 25 0D 1B 66 C3 D5 EE 1F 5B A1 31 0A BA
1D E5 3E 00 22 55 B6 97 7B 91 E5 79 15 4D 88 AC A5 41 E9 6A 5C AA E6 D0 85 85 93 E2 87 42 F6 9C
9A 8B 59 DA 3F A1 5B B0 19 1D B7 3C 6E FD B8 04 C3 04 E0 CB E9 AA 1D 44 B7 33 7E FB EC EF A7 12
FF D1 BB F7 D8 68 45 C9 14 F8 E9 93 85 AB 0E 8C C2 02 47 6D C2 56 5E D9 02 98 D5 2C 88 92 F5 1C
B0 CB 15 03 58 E1 DB 09 CB F6 F7 37 40 EA F5 4D DC 42 3E 94 FC 49 A2 C4 59 55 8C 46 4E 55 3F C9
CB 38 93 40 DD 84 86 42 29 84 1F 0D B1 C6 CC CE F7 E2 41 3E D3 D9 B4 3E 3D DA C4 A3 4D A3 5A C3
78 9E B4 4C E4 75 57 E9 43 1D 12 73 20 D3 80 F7 A3 6D A3 79 C0 8F B5 59 37 0D 62 8C B8 AC 26 60
AB 2A 87 C9 3E 19 8E 7C EE 3E 2F 67 14 14 07 13 3B B0 F1 B6 B4 D3 A7 87 E8 72 75 F3 E2 95 C9 04
E6 C2 EE 23 6F CB 31 67 C3 F8 B5 4A DF F0 2B 18 DF 5C 70 09 5A 70 2E 0B 14 35 8C D6 48 E8 F0 62
51 F2 70 BE 8E B0 B0 D8 8F 89 12 3D DA 1E 32 7C D0 57 74 2E 6D 65 B6 89 3F 3D 39 BF 5E F7 A6 92
0E 8A 7C 34 1E 7B EA 99 10 19 AB 49 B8 4A B7 2F 30 CC B6 93 D5 7F D9 B3 EC 68 E5 AF 81 3D D1 D2
52 66 B0 AD 31 2A 58 92 25 D5 6D A8 12 4D 00 F5 B0 42 AC 21 A5 EA 0F 51 06 3A 30 93 60 D5 01 E5
47 A4 35 29 41 5C 6B 1D BB 2F 86 09 99 C8 6A B6 6B 25 97 2D 77 CB AF BB D0 78 B3 86 B8 CC 5F 6E
10 0D D5 6A 4A D4 FD 02 F5 18 FB C2 23 DC 4B EB EA D4 DD D2 2C 44 D5 A9 6F 38 75 23 F9 8F B5 6B
7B AA 43 C4 68 F7 D4 1F F8 CC 10 1F 71 99 14 6B 4D 4F 6B D5 B2 EF 55 0E 80 D6 D0 3A C9 04 2C ED
If I diff the expected data, the tx buffer, and the logic analyzer capture, they all match. How bizarre!
kilograham
Mon Mar 15, 2021 1:03 pm
oh! i had assumed you were comparing sent with received, not with rand_r regenerated data.
rand_r is not thread safe
carlk3
Mon Mar 15, 2021 4:34 pm
I'm doing that, too. It compares the tx buffer with the generated sequence, the rx buffer with the generated sequence, and tx vs. rx. Any of the three can fail. I was really surprised to see the tx buffer change. Even more surprised to see it change and then change back.
I thought rand_r() is the reentrant version of the rand() function, for use with multithreaded applications. In what way is it not thread safe?
Plainsman
Mon Mar 15, 2021 5:06 pm
generic hardware debugging suggestions -
turn off optimization for *all* code generated: add -O0 to the end of CFLAGS or CFLAGS_EXTRA (whichever exists in your build environment). If your problems change significantly, you may be missing a volatile on some hardware related addressing decls -- even down deep into the libraries.
use sequential data for one TX buffer counting up, the same for the other but counting down. may help reduce the sizeof the universe of things you're looking at, make single bit errors more noticeable.
carlk3
Mon Mar 15, 2021 5:08 pm
I have added some checks for SPI Transmit FIFO empty, SPI Receive FIFO empty, and SPI not busy. Now I have all these superfluous actions after the RX DMA complete IRQ has fired:
    dma_channel_abort(this->tx_dma);
    dma_channel_abort(this->rx_dma);
    configASSERT(spi_get_hw(this->hw_inst)->sr &
                 SPI_SSPSR_TFE_BITS);  // SPI Transmit FIFO should be empty
    configASSERT(!(spi_get_hw(this->hw_inst)->sr &
                   SPI_SSPSR_RNE_BITS));  // SPI Receive FIFO should be empty
                   SPI_SSPSR_BSY_BITS));  // SPI should not be busy
but none of these made a difference; it still fails data checks.
kilograham
Mon Mar 15, 2021 6:16 pm
quite right!
kilograham
Mon Mar 15, 2021 6:23 pm
are you sure the task_no are making it thru correctly, and not all 0?
fivdi
Mon Mar 15, 2021 8:54 pm
quite right!
Assuming newlib version 3.1.0 is being used, the source for rand_r can be found at https://github.com/bminor/newlib/blob/n ... b/rand_r.c (or at https://sourceware.org/git/?p=newlib-cy ... 92509c8a5d).
carlk3
Mon Mar 15, 2021 10:13 pm
Major discovery: I removed SPI completely and I can still recreate the problem. This greatly simplifies the test case: https://github.com/carlk3/spi_dma/blob/no-spi/spi_dma.c
Output from a typical run:
example
T0: testTask(task_no=0)
T1: testTask(task_no=1)
T0: Stack High Water Mark: 1348
T1: All good
T1: Stack High Water Mark: 1348
T0: All good
T1: Done. Checking...T0: Stack High Water Mark: 1348
T1: All good
T1: All good
T0: Done. Checking...T1: Stack High Water Mark: 1348
T0: /home/carlk/pi/pico/spi_dma/spi_dma.c:66: testTask
: Mismatch at 809/1024: expected 1b, got 5b
T0: hexdump_8(rxbuf, 0x20001938, 1024)
f5 d3 8d 7f 87 58 88 fc cb e9 c9 00 a6 a6 19 d6 47 33 c9 fc 8e 35 88 11 0a e0 41 83 99 17 cd b8
d8 99 28 c3 da 29 6b b0 1d 92 75 5a c8 23 25 e3 06 a0 ad 84 8c 28 3d e6 d5 1e 10 35 80 5f b0 d8
bd 50 d3 10 4e 3f 9f b0 d1 e9 ac e3 e7 b8 e5 11 7b fa c7 f1 81 da 8d ae 13 f0 44 49 f4 a7 61 0c
25 a5 12 c9 48 24 fd 9c e3 5b 4d f7 a3 f1 bd 27 84 af 4a b0 5a 2d 42 84 cc ff 6e 59 01 f2 5d 16
9a 16 e4 20 a6 e6 ee 98 de 98 36 39 6b 5f d7 23 02 ab 68 c6 c5 2b 9d 28 15 85 1a d6 e3 09 7c ac
11 e7 e0 26 d2 94 d5 4c 8c a3 7e 08 59 36 2c b3 12 95 cf fa 1c 74 1a fb ee f3 ea 31 ad 1e d1 81
26 63 4d cb d0 c2 86 4a 66 ef e8 76 a6 a5 9e 44 07 f0 74 9b 74 b0 3c 0b d2 65 bd 13 27 a5 62 88
8f 7e d8 1b a4 49 da 72 5b d8 52 89 ed 0e 53 54 82 1e 86 d8 7a da de 4c d4 d2 bc c2 ba 59 01 84
bb 1b 59 7c 53 77 8b 4c ad 06 42 2c c3 2c a1 41 b9 d0 b6 bf 8a ba 6b 5a 48 2c ee 09 38 99 f4 0c
97 39 05 1b ad 21 2d 5d af 5f 55 3a 11 ea a4 8b c8 95 5e 07 5a 3e 93 c8 70 81 4e d0 d7 6d f3 74
cb 4c 99 0d b8 af 9b 50 5e b5 47 4c d8 a9 9b 31 b2 20 4a 71 ba 58 4a d8 1b 44 21 9c a1 5c 0c 07
2c 31 98 26 69 2c c4 e6 5b 62 df 7a 92 27 e9 81 e9 97 6d 7e 4e 83 ce 0b 1c 5f 51 e6 c9 1b 53 32
ca 7d 61 41 24 9a 11 00 c2 dc c3 bb 74 d6 19 6a a8 eb 1c 6b 33 b5 47 b7 fa e9 16 31 68 cc 96 51
ba 3f aa 24 fc 5b d1 ba 19 98 c2 df 5e 06 0f a3 8f 9a 87 3e c5 d7 09 94 55 47 8e 20 d8 ea c6 91
ac be 3f 1e 5f 35 2c 59 d2 92 41 f1 23 a9 ca f2 5f 86 c1 d2 6a 1b e3 78 5c 36 e2 d3 0f 09 f5 17
65 3c 8b 83 48 a9 7c 8c 99 fe df 4a 8a 0e 16 19 78 b1 1f 60 82 99 51 1d f1 2d 09 1f b0 31 b2 b9
52 33 ef a1 8f 89 3e 99 62 42 a8 54 ab 1b c5 fb 8c 81 3d 3c e5 1a bd 05 7a 70 74 af b0 20 97 f4
1c 19 c2 c9 11 82 d7 b9 35 8c 39 cf b2 b9 a9 b5 6e 1f 9a d8 fa c2 2c 5c 3f 85 8e a4 d3 93 a4 f0
76 d7 99 ee e4 25 66 a1 d2 73 6b 3e 78 fd bf 2a 2f 43 6f c2 94 51 b9 5a 7d 79 17 33 0b 55 13 17
6f b3 4c 15 89 23 64 14 ea 2a 36 77 72 ad 06 d0 6e 44 97 8a e3 d9 78 fd 10 99 a4 23 f7 57 4f e8
91 c4 2a ef 27 30 9b 1e bc ff 37 57 5d c2 94 37 e4 42 77 90 66 b2 aa c9 62 6b 9d 45 7b 4b a3 72
06 20 a4 f0 c0 11 ef 2c ee c5 7d 59 2f a9 a9 fd e3 57 63 99 99 c1 5f ca ca 0e 35 c3 a1 aa 27 4e
ce b7 a5 6b 13 23 11 41 92 65 ca 0e 3e 38 90 e6 bf 7f 99 39 62 53 1e 2f e5 3b 1c d3 21 23 00 3a
aa 63 f2 a7 f7 0a 78 33 b3 fe 0c 20 bc 28 c3 27 79 2a 3b 6c bc cf 40 20 ed ec 2c 4d e6 4c ca 48
e2 72 83 68 15 a0 41 f2 77 9d a3 0a c0 32 0c 32 03 80 cf c8 5a 40 5f b3 9d 84 9a 41 99 2b b0 e8
87 f8 fb 22 c6 1c 33 44 f6 5b 2c c7 5f 37 0d 6a 7b 4c de ac 8e 30 25 44 0e d9 ff 57 55 9b f1 e0
59 83 ba 0a af 6e 74 61 65 dd 4c cd 27 b2 ff b2 04 cc f0 3b 36 26 ec c5 fd 99 75 72 20 77 0d 97
4c 3f ea e1 84 10 d5 cd be 72 08 5b 18 b7 14 a7 cf ae 0e 11 65 94 4b 1c ef e0 3b 72 6d ff 30 86
17 5e 64 e8 23 e5 94 d9 18 13 6e b9 aa 49 96 f3 94 1f 4e 12 c3 85 a6 c9 76 91 27 01 5a 46 2e 47
91 69 59 40 e5 16 b0 5a 62 dd 0d 56 a5 82 aa 5e e4 c8 2f 59 d2 aa 56 22 ba 56 d0 f5 c4 d2 b6 ce
48 c6 c2 f0 65 b8 17 1e 4b 1c 9b 68 36 23 4b 91 27 88 09 6e c1 17 b2 45 b6 9d e4 3a 53 4b 04 e4
28 5d 3d c6 12 91 6e aa cd d8 c8 4a ea fd ae 9a cf 07 aa c7 cc 8b fa 38 4d 3d a4 2b ec 6c cf 97
Expected:
Once again, there is no difference between the expected data and the rxbuf when they are dumped.
ejolson
Mon Mar 15, 2021 11:26 pm
example
T1: All good
T0: All good
T1: All good
T1: All good
Expected:
Thanks for simplifying the example case. This definitely looks like a hardware issue related to an in-progress transfer.
Have you checked if the mismatched data matches the previous contents of RAM and whether after the first mismatch the rest of the data is right or wrong? Is there a fence missing somewhere?
I'm sorry I don't have much to add to this conversation. Please take my post as an encouragement to continue debugging. My post here also serves as an easy way for me to stay updated on developments in this thread. Sorry for the noise.
kilograham
Mon Mar 15, 2021 11:33 pm
hmm.. i have one thought; does the problem go away if you build with
pico_set_divider_implementation(TARGET compiler)
in your CMakeLists.txt?
carlk3
Tue Mar 16, 2021 3:20 pm
Yes, indeed, the problem goes away!
Now to try this in my real application.
cleverca22
Tue Mar 16, 2021 3:25 pm
i think the problem, is that your context switch algo isnt saving/restoring the state of the hardware divider
kilogram's bit of code, switches you to an entirely software driven divider, which is slower, but uses regular arm regs
carlk3
Tue Mar 16, 2021 6:42 pm
Makes sense. So, I need to stick hw_divider_save_state() and hw_divider_restore_state() somewhere into xPortPendSVHandler()?(FreeRTOSConfig.h does `#define xPortPendSVHandler isr_pendsv`).
carlk3
Tue Mar 16, 2021 6:45 pm
Works there, as well.
kilograham
Tue Mar 16, 2021 6:59 pm
Yes something needs to be done for sure, and this would work.
What we do in general (when using the hw divider) is to always read the results in a defined order. I think this is mentioned in both the data sheet and the C/C++ book. IRQ save/restore of divider state takes advantage of this to only save/restore if the interrupted task is "mid division", i.e. it hasn't read the results of the last divide (according to the fact that the dirty flag on the hw divider is cleared when you read the quoitent). you can look (though it isn't well commented) at pico_divider/divider.S
Return to “SDK”
