Having failed to get my Pi to boot from my usb hard drive
i find the capacity of the drive is reduced from 256gb to 75 meg
is there some equivalent to SD Formatter to get it back to normal so I
can start again from scratch
JG
Re: USB HDD
fdisk
what sort of drive ?
what instructiuons where you following
Covfefe
Covfefe
Re: USB HDD
Sorry, I'm a bit lost
I've tried different methods as described in this forum without much luck
which is why I wanted to make a fresh start. I was trying to format from windows but always finish up with 75 meg. What would be the syntax for fdisk, would I have to point it to the drive
thanks
JG
i wa
thanks
JG
i wa
Re: USB HDD
Sorry to ask, but do you have a 256GB SD card?
To initialize the card I followed the instructions found on the text of the magpi magazine and i got a card to boot the pi (i used the process described for linux but supose the windows works too)
I think that to begin the process another time you do not need to format the drive. But if you want you have to tell windows to initialize the external disk.
Anyone knows if your card is supported???
Hope you get it working
Josep
Josep
Re: USB HDD
jmanel. The OP said he/she has a Hard Disk, rather than an SD card.
Re: USB HDD
OP,
if this is a hard disk [256GB ]
and you have now somehow made it 75Mb
and you want to re-initialise it back to full size
then
if using windows you will have to go into [start | setting | control panel | adminsitrative tool | computer management | disk management ] and then re partition the drive from there ,
if using linux then use
fdisk
or parted
or
gparted
or cfdisk
if this is a SD card that has been nobbled then there are windows tools for this...
however
OP
we need more info - please be clear in what you have done - give us links to what you have followed and what you want to do
then
fdisk
or parted
or
gparted
or cfdisk
however
OP
Covfefe
Covfefe
Re: USB HDD
Thanks RaTTuS
I got it back in windows following your instructions.
I was trying to use the drive to boot and run the Raspi
I installed squeeze on it using win 32 diskimager as you would with a card
I then tried to follow the instructions as given by andreword at the thread at
http://www.raspberrypi.org/phpBB3/viewt ... 59#p112959
After that it all went pear shaped as you can see from the thread, as I recall
I then tried another method given on the thread and then gave up until i bought
a new wiki approved power hub which was more reliable. At that point I decided to reformat and reinstall squeeze on the drive. This is where we came in.
I am also a bit worried that as the hub would not supply enough power even using a Y cable I used a separate usb power supply to power the drive. This also seems to be feeding power into the Pi. Could this damage the Pi and is there a better way of doing it. Perhaps it may be best to forget the whole thing,
it's just that I had a spare drive and thought I'd try to use it
Would it be safer to run the pi from the hub?
Thanks for your help
JG
JG
Re: USB HDD
It is only possible to start the system from an SD card - i.e. you must have one installed for the pi to work.
This needs to have the firmware on it and the initial boot image (e.g. a kernel). Using special kernel parameters or UBoot (a secondary bootloader that provides more options - still in heavy development), it may be possible to load an OS from other sources.
It is probably to start with just an SD card and then go from there
Re: USB HDD
OK ,
here goes.
on my debian wheezy [it did work for squeeze also]
created the image on the SD card -
booted RPi successfully
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update [if you've not got it then it's worth gettting it]
reboot
make sure everything seems to work ok. - I'm a console man so I don't bother with X - this will come later
sudo fdisk -l
this should show your SD card only
plug in USB HD ,
sudo fdisk -l
this should show another HD probbaly at /dev/sda
sudo fdisk /dev/sda
d
[all partitions]
n
[new partitions create 2 , one that takes up most of the disk and a small 2Gig one at the end that will be used as swap [type 82]]
sudo mkfs.ext4 /dev/sda1
this creates an ext4 filesystem
sudo mkswap /dev/sda2
this makes the swap system [but does not activate it]
sudo dd if=/dev/mmcblk0p2 of=/dev/sda1 bs=32M conv=noerror,sync
this copies the 2nd partition of your sdcard to the 1st partition of your hard disk [possibly this is what you want - though mmcblk0p2 may not be correct for you see the output of fdisk easlier
sudo e2fsck -f /dev/sda1
this checks the file system
sudo resize2fs /dev/sda1
this expands the data to fill the partition
now it gets a bit tricky
sudo cp /boot/cmdline.txt /boot/cmdline.ori
[make a backup of the original file]
sudo vi /boot/cmdline.txt
or your editor of choice
change the /dev/mmcblk0p2 / to be
/dev/sda1
you are changing the boot device from the SD card partition 2 to the Hard disk partition 1
you should also
sudo mount /dev/sda1 /mnt
and change in
/mnt/etc/fstab
the root device also [/dev/mmcblk0p2 /
to be
/dev/sda1
also change the swap parititon to be
/dev/sda2
then
sudo sync
sudo shutdown -r now
then when it comes back it will boot off the SD card and transfer to be running from the HD.
if it fails - use another machine to
copy /boot/cmdline.ori to /boot/cmdline.txt
and then reboot back.
YMMV
good luck
here goes.
sudo apt-get update
reboot
sudo fdisk -l
plug in USB HD ,
sudo fdisk -l
sudo fdisk /dev/sda
d
[all partitions]
n
/dev/sda1
you should also
and change in
/mnt/etc/fstab
to be
/dev/sda1
/dev/sda2
then
sudo sync
YMMV
good luck
Covfefe
Covfefe
Re: USB HDD
Thanks for that
When I pluck up some courage I'll give it a try
I'll let you know how I get on
Thanks again
JG
Thanks again
JG
Re: USB HDD
It is actually resize2fs
root@raspberrypi:~# resizefs /dev/sda1
-su: resizefs: command not found
root@raspberrypi:~# resize2fs /dev/sda1
resize2fs 1.42.4 (12-Jun-2012)
Resizing the filesystem on /dev/sda1 to 36621093 (4k) blocks.
The filesystem on /dev/sda1 is now 36621093 blocks long.
Furthermore dd takes forever, if you want to know progress of the dd use following command in another window:
root@raspberrypi:~# killall -USR1 dd
You will see status in original window:
863+0 records in
863+0 records out
28957474816 bytes (29 GB) copied, 4774.26 s, 6.1 MB/s
Kind regards,
Jilles Groenendijk
@JillesDOTCOM
863+0 records in
863+0 records out
Kind regards,
Jilles Groenendijk
@JillesDOTCOM
Re: USB HDD
This is what I did. Based on the previous comments:
1. Logged in to debian with the pi/raspberry account
2. sudo su (switch to su mode without the root password)
3. ls /dev
(list all devices, depending on the type of drive)
Look for /dev/sda
Note your SD card will be listed as /dev/mmcblk0 (with partitions p1, p2, p3)
4. fdisk /dev/sda (obviously change this to match your HDD configuration)
5. p (print the partition table)
6. d <Enter> <number> (for each partition to delete them)
7. n <Enter> p <Enter> 1 <Enter> (Choose appropriate size for your main file area)
8. n <Enter> p <Enter> 2 <Enter> (make sure to have left yourself some swapspace)
9. You can set the boot flag if you want, but it isn’t needed since your booting from the SD card
10. mkfs.ext4 /dev/sda1 (format the first partition)
11. mkswap /dev/sda2 (format the swap space)
12. sudo dd if=/dev/mmcblk0p2 of=/dev/sda1 bs=8M conv=sync,noerror #[change sda1 to whatever you had made it in the fdisk above]
13. wait
14. sudo e2fck /dev/sda1
15. resize2fs /dev/sda1
16. sudo nano /boot/cmdline.txt
17. change mmcblk0p2 to sda1
18. sudo nano /etc/fstab (add swap partition)
19. sudo sync && sudo sync
20. sudo reboot
Jesse Alexander WB2IFS/3
3. ls /dev
Look for /dev/sda
13. wait
20. sudo reboot
Jesse Alexander, WB2IFS/3
[email protected]
Twitter: @scipoet
http://www.linkedin.com/in/jessealexander
"Mastery is the ability to make that which is complex appear simple and easily understood."
[email protected]
Twitter: @scipoet
Re: USB HDD
Just a quick thank you to RaTTus for his excellent post.
Re: USB HDD
I saw this post only after trying a 20GB USB drive and pre-programmed 8GB SD card in Linux Fedora. After connecting both the devices, I ran 'dd' command to transfer all Linux files from SD card to HDD (formatted earlier in ext4). After copying (takes a lot of time), I changed 'cmdline.txt' file to change the boot from /dev/mmcblk0p2 to /dev/sda1. It appears to be working all right. But 'df -h' command does not show the 20GB HDD. Is it OK?
I had to use only a few commands for this operation.
Re: USB HDD
you will have to expand the rootfsvsayanam wrote:I saw this post only after trying a 20GB USB drive and pre-programmed 8GB SD card in Linux Fedora. After connecting both the devices, I ran 'dd' command to transfer all Linux files from SD card to HDD (formatted earlier in ext4). After copying (takes a lot of time), I changed 'cmdline.txt' file to change the boot from /dev/mmcblk0p2 to /dev/sda1. It appears to be working all right. But 'df -h' command does not show the 20GB HDD. Is it OK?
as a dd will just copy the contents and leave it as the original size.
Covfefe
Covfefe
Re: USB HDD
Thank you for the quick reply. I had already run 'sudo resize2fs /dev/sda1' as given in your post. I got messages 'freeing already freed blocks' or something like that which scrolled very fast. After seeing your reply, I ran the command again and I got a message: "The file system is already 4882944 blocks long. Nothing to do!". But 'sudo fdisk -l' says that /dev/sda1 has 19531776 blocks. Why the difference? Does the 20GB HDD have full 20GB for use? Thanks in advance.
Re: USB HDD
Sorry.. I was in a hurry to respond. When I ran 'df -h' after sending the reply, I saw the size of rootfs as 19G out of which 1.8G has been used. Earlier, I was not getting this. Thanks again.
Re: USB HDD
no worries - as long as your happy now ;-p
Covfefe
Covfefe
Re: USB HDD
I have successfully done all the steps above until resize2fs. By now, after running resize2fs to expand the partition to use the 20GB I left available (btw I had to umount /dev/sda1 first because the first try resize2fs told it was not possibile to resize online) it has been over 12 hours that the command is running, and no other output than:sudo resize2fs /dev/sda1
pi@raspberrypi /mnt $ sudo resize2fs /dev/sda1
resize2fs 1.42.5 (29-Jul-2012)
Re: USB HDD
just for the record... after almost 100 hours running I have done a reboot and a new
go figure...
then run resize2fs again and all finished within about 2 minutessudo fsck.ext4 /dev/sda1
Re: USB HDD
Hello. First, thanks for this post.
Got it working with only minor modifications for my unique situation.
However, my external HDD apparently "times out", sleeps, or hibernates after a certain period of inactivity, which makes it impossible for me to log in via SSH (using PuTTY) once it does. (I'm running headless.)
The ext HDD is a Toshiba Canvio 3.0 Plus, 1.5TB.
Furthermore, while I can physically power down the Pi and restart, "sudo reboot" does not seem to work: the Pi lights up, however, I cannot SSH in.
I do run:
regularly.
Any ideas? (Other than "use another drive", please; that is not really an
option right now.)
Thanks in advance!
(Cross-posted to:
The Raspberry Pi Hobbyist: Running From an External Hard Drive)
I do run:
sudo apt-get -y update
sudo apt-get -y dist-upgrade
sudo rpi-update
option right now.)
Thanks in advance!
(Cross-posted to:
Re: USB HDD
leave a screen attached until you have fixed the issues,
does
dmesg
say anything of use after the HD has timed oout?
how are you powering it ?
does
dmesg
Covfefe
Covfefe
Re: USB HDD
Thanks for letting me know you posted here also. Here, the info will help more people.
try this:
apt-get install sdparm
then
sdparm --clear=STANDBY /dev/sdX
(where X is the appropriate letter for your drive)
if that works, then you can run it at each boot by adding it to /etc/rc.local
As a last resort, you could do a cron job to access the drive regularly to keep it awake.
crontab-e
(this will open the cron config file using nano as the edittor)
Add this line (again with the correct letter for your drive)
*/5 * * * * /bin/touch /dev/sdX &>/dev/null
This will access the device every 5 minutes.
Hope this helps.
try this:
then
crontab-e
Hope this helps.
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
Re: USB HDD
u just have to format it to LINUX, then if you want u can make partition for the drive and then mount it (not literally) using mount commands.. this way u could use your HDD in your raspi for storage
Re: USB HDD
is it enough to format and mount the drive as ext4 to avoid the auto-sleep function? I am about to get my toshiba canvio as well...veteranz_guian25 wrote:u just have to format it to LINUX, then if you want u can make partition for the drive and then mount it (not literally) using mount commands.. this way u could use your HDD in your raspi for storage
