Hi, I was messing around with config files trying to have my Pi connect to the Wi-Fi automatically and I forgot the first rule of editing config files, make backups!!! So I want to revert the file to the default format and start over. The file I need is:
/etc/wpa_supplicant/wpa_supplicant.conf
If anyone wants to post the default format for this file that would help a lot. Thank you so much.
Re: Help with "wpa_supplicant.conf"
Try
man wpa_supplicant.conf
Alternatively you could try
sudo wpa_gui
(sudo apt-get install wpagui, if not present on your system),
sudo wpa_gui
Ok, I got it to work again. This whole thing started because I tried to figure out how to connect to a wireless network that has no password on it.
The configuration for the "wpa_supplicant.conf" file that I used it as follows:
The indents are tabs, not spaces F.Y.I.
Also, it is 100% functional except that the "WiFi Config" icon on the Desktop can't be used to control the wireless network configuration, I need to edit the "wpa_supplicant.conf" file if anything needs to be changed.
Moral of the story: MAKE BACKUPS!!!
Thanks to joan for responding by the way.
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="YOUR NETWORK SSID"
proto=RSN
key_mgmt=NONE
Thank you very much, I searched all over for hours and tried everything to get wifi working with MotionPi on my open network and your solution worked great!
here is a good overview viewtopic.php?p=797363#p797363
! OUT OF DATE !
! OUT OF DATE !
Hello!
well i finally registered just to say a huge thank you!!!
my pi is online
my pi is online
