pi@gatepie ~ $ ./SomeScript.sh
./SomeScript.sh: line 2: uuencode: command not found
pi@gatepie ~ $ uuencode
pi@gatepie ~ $ sudo apt-get install command-not-found
Reading package lists... Done
You need to run 'update-command-not-found' as root to update the cache.
pi@gatepie ~ $ sudo update-command-not-found
Downloading complete file http://mirrordirector.raspbian.org/raspbian/dists/wheezy/main/Contents-armhf.gz
OK, you might need to log out and back in again for this to work
The program 'uuencode' is currently not installed. To run 'uuencode' please ask your administrator to install the package 'sharutils'
root@gatepie ~ # uuencode
The program 'uuencode' is currently not installed. You can install it by typing:
apt-get install sharutils
pi@gatepie ~ $ dhcp
No command 'dhcp' found, did you mean:
Command 'dicp' from package 'dish' (main)
Command 'hcp' from package 'lam4-dev' (main)
Command 'chcp' from package 'nilfs-tools' (main)
Command 'dhcpd' from package 'isc-dhcp-server' (main)
Command 'dccp' from package 'dcap' (main)
dhcp: command not found
pi@gatepie ~ $
