npaisnel
Mounting a network HDD on a remote Pi (SOLVED)
Sat Jun 19, 2021 9:56 am
Two Raspberry Pi's here.
The local one has an external HDD /dev/sda1/ mounted on /media/pi/EXT500
This is not for permanent mounting ..just when I am doing an image backup
See comments and posts about fstab entry ..that is for permanent mounting yes? so i do not need it for a temporary mount?
I want to physically connect the HDD via USB to the local Pi and mount it on my Pi that is in the attic over the network to do an image-backup from it, . Save me getting the ladder out, crawling in attic etc.
have tried these links
https://www.cyberciti.biz/faq/linux-mou ... ows-share/
https://www.stuffaboutcode.com/2012/05/ ... share.html
http://cagewebdev.com/raspberry-pi-conn ... ork-drive/
viewtopic.php?t=243891
The local HDD is ext4 format and have smb shares.....so the use of cifs ? is that correct? or ??"
Tied so many combinations ..here are a few I have failed to get to mount
sudo mount -t cifs //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56/media/pi/EXT500 /mnt/netEXT500 -o username=pi,passwrod=WXYZ123, workgroup=home
mount: bad usage
Try 'mount --help' for more information.
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56/media/pi/EXT500 /mnt/netEXT500 -o username=pi,password=WXYZ123,workgroup=home
Couldn't chdir to /mnt/netEXT500: No such file or directory
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56/media/pi/EXT500 /mnt/netEXT500/ -o username=pi,password=WXYZ123,workgroup=home
Couldn't chdir to /mnt/netEXT500/: No such file or directory
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56/media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount error(2): No such file or directory
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount: bad usage
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs //192.168.1.56 /dev/sda1 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount: bad usage
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t smb://192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount: /mnt/netExt500: unknown filesystem type 'smb://192.168.1.56'.
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t cifs//192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount: /mnt/netExt500: unknown filesystem type 'cifs//192.168.1.56'.
mount: bad usage
pi@rsp1a-rsp-tcp:/etc $ sudo mount -t ext4 //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
mount: bad usage
pi@rsp1a-rsp-tcp:/etc $ sudo mount.cifs //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
Couldn't chdir to /media/pi/EXT500: No such file or directory
pi@rsp1a-rsp-tcp:/etc $ cd /media
pi@rsp1a-rsp-tcp:/media $ ls
EXT500
pi@rsp1a-rsp-tcp:/media $ cd EXT500
pi@rsp1a-rsp-tcp:/media/EXT500 $ pwd
/media/EXT500
pi@rsp1a-rsp-tcp:/media/EXT500 $ sudo mount.cifs //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=homecd /mnt
pi@rsp1a-rsp-tcp:/media/EXT500 $ cd /media
EXT500
pi@rsp1a-rsp-tcp:/media/EXT500 $ ls
pi@rsp1a-rsp-tcp:/media/EXT500 $ sudo mount.cifs //192.168.1.56 /media/pi/EXT500 /mnt/Ext500/ -o username=pi,password=WXYZ123,workgroup=homecd /mnt
pi@rsp1a-rsp-tcp:/ $ cd
pi@rsp1a-rsp-tcp:~ $
pi@rsp1a-rsp-tcp:~ $ ls
Dev  Downloads  pishare
pi@rsp1a-rsp-tcp:~ $ cd /
pi@rsp1a-rsp-tcp:/ $ ls
bin   dev  home  lost+found  mnt  proc  run   srv  tmp  var
boot  etc  lib   media       opt  root  sbin  sys  usr
pi@rsp1a-rsp-tcp:/ $ cd mnt
pi@rsp1a-rsp-tcp:/mnt $ ls
netExt500
pi@rsp1a-rsp-tcp:/mnt $ cd netEXT500
-bash: cd: netEXT500: No such file or directory
netExt500
pi@rsp1a-rsp-tcp:/mnt $ cd netExt500/
pi@rsp1a-rsp-tcp:/mnt/netExt500 $ cd ..
pi@rsp1a-rsp-tcp:/mnt $ sudo rm -R *
pi@rsp1a-rsp-tcp:/mnt $ sudo mkdir netExt500
netExt500
it is this
pi@rsp1a-rsp-tcp:/ $ sudo mount.cifs //192.168.1.56 /media/pi/EXT500 /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
that is pissing me off..there bloody well is a /media/pi/EXT500 directory .
Some syntax some where I have wrong?
npaisnel
Re: Mounting a network HDD on a remote Pi
Sat Jun 19, 2021 10:06 am
Well . i got it to 'execute' with no error.
but it does not show the mount
pi@rsp1a-rsp-tcp:/mnt/netExt500 $ sudo mount -a //192.168.1.56 /media/pi/EXT500/ /mnt/netExt500/ -o username=pi,password=WXYZ123,workgroup=home
netExt500
pi@rsp1a-rsp-tcp:/mnt/netExt500 $ ls
The HDD on the other machine has this :
pi@HomeVision:/mnt $ cd /media/pi
pi@HomeVision:/media/pi $ ls
EXT500
pi@HomeVision:/media/pi $ cd EXT500
pi@HomeVision:/media/pi/EXT500 $ ls
BiT  lost+found  PepperMint  RPi2  RPi3  timeshift
npaisnel
Sat Jun 19, 2021 10:30 am
If I do smb://192.168.1.56/ext on the mac, then Finder opens and the share is visible...
So pretty sure it is set correctly on the server side.
pi@rsp1a-rsp-tcp:/mnt/netExt500 $ sudo apt-get install smbfs smbclient
Reading package lists... Done
Building dependency tree
Package smbfs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  cifs-utils
E: Package 'smbfs' has no installation candidate
pi@rsp1a-rsp-tcp:/mnt/netExt500 $ sudo apt-get install cifs-utils
cifs-utils is already the newest version (2:6.8-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
npaisnel
Sat Jun 19, 2021 10:36 am
Well....I can go off to the wedding of a friend this afternoon with out this buzzing around my head..
Got !
sudo mount //192.168.1.56/ext /mnt/netExt500/ -o username=pi,password=WXYZ123
epoch1970
Sat Jun 19, 2021 10:39 am
Did you read the official documentation page on this https://www.raspberrypi.org/documentati ... s/samba.md and the manual page for mount? (“man mount”)
You ran
I think I would try
 sudo mount -t cifs  -o username=pi,password=WXYZ123,workgroup=home //192.168.1.56/media/pi/EXT500/ /mnt/netExt500/
/etc/fstab is used to store mount specifications. When the system boots it runs “mount -a”, meaning basically it reads fstab and executes every line not marked with option “noauto”
Add your mount to fstab once it works, with option noauto (or probably better noauto,nofail.)
That will allow you to mount/unmount on demand using a shorter command form, e.g. “mount /mnt/netExt500”
thagrol
Re: Mounting a network HDD on a remote Pi (SOLVED)
Sat Jun 19, 2021 10:51 am
A couple of suggestions:
  1. fstab can be used for temporary/manual mounts. Include the noauto option then sudo mount -a or sudo mount /path/to/mountpoint
  2. You may find that ownership and permissions on the client Pi are not what you expect them to be. They'll most likely be root:root owner an group and 755 permissions for everything.
  3. You might want to switch to NFS instead of CIFS/Samba. NFS is linux native, has better perofrmance, and full support for linux owner, group, and permissions.
npaisnel
Sat Jun 19, 2021 10:57 am
That is one I did not find, no...thank you
I did get it mounted.. but now have permissions issue ..... but off to a wedding now ...or in an hour...
So many links to read..and "man" pages ..TBH unless you are an expert..man ages are about as much use as a chocolate fire guard !
pi@rsp1a-rsp-tcp:/mnt/netExt500/RPi3/New_images/RSP1a $ sudo /bin/image-backup
Image file to create? /mnt/netExt500/RPi3/New_images/RSP1a/RPi3-210619-API3-RSTCP.img
Initial image file ROOT filesystem size (MB) [1734]? 1800
Added space for incremental updates after shrinking (MB) [0]? 50
Create /mnt/netExt500/RPi3/New_images/RSP1a/RPi3-210619-API3-RSTCP.img (y/n)? y
truncate: cannot open '/mnt/netExt500/RPi3/New_images/RSP1a/RPi3-210619-API3-RSTCP.img' for writing: Permission denied
Unable to create image file
pi@rsp1a-rsp-tcp:/mnt/netExt500/RPi3/New_images/RSP1a $ sudo /bin/./image-backup
Initial image file ROOT filesystem size (MB) [1734]? 1750
the smb.conf file permissions for the share
[ext]
   comment= Mounted USB Drive
   path=/media/pi/EXT500/
   browseable=Yes
   writeable=Yes
   read only = no
   only guest=no
   create mask=0777
   directory mask=0777
   public=yes
   guest ok = yes
npaisnel
Sat Jun 19, 2021 10:58 am
Sorted
pi@HomeVision:/media/pi/EXT500 $ ls -l
total 36
drwxr-xr-x 3 root root  4096 Jun 10 09:39 BiT
drwx------ 2 root root 16384 Jun  8 20:42 lost+found
drwxr-xr-x 4 root root  4096 Jun 15 10:25 PepperMint
drwxr-xr-x 2 root root  4096 Jun 10 19:20 RPi2
drwxr-xr-x 4 root root  4096 Jun 13 10:11 RPi3
drwxr-xr-x 9 root root  4096 Jun 18 20:00 timeshift
pi@HomeVision:/media/pi/EXT500 $ cd RPi3
pi@HomeVision:/media/pi/EXT500/RPi3 $ ls
New_images  Old_Working
pi@HomeVision:/media/pi/EXT500/RPi3 $ ls -l
total 8
drwxr-xr-x 4 root root 4096 Jun 17 19:40 New_images
drwxr-xr-x 2 root root 4096 Jun 10 14:04 Old_Working
pi@HomeVision:/media/pi/EXT500/RPi3 $ sudo chmod -R 777 *
total 8
drwxrwxrwx 4 root root 4096 Jun 17 19:40 New_images
drwxrwxrwx 2 root root 4096 Jun 10 14:04 Old_Working
Sat Jun 19, 2021 10:59 am
This! Plus NFS is a whole lot easier then CIFS to set up.
Unreadable squiggle
npaisnel
Sat Jun 19, 2021 11:01 am
[*]You might want to switch to NFS instead of CIFS/Samba. NFS is linux native, has better perofrmance, and full support for linux owner, group, and permissions.
Thanks..I'll look later..but would that then not screw with access for shares too/from windows machin es..
hmmm..beyond me all of this ....the drive is ext4 format.. and all the shares across the house are smb.
Does Win7/8/10 support NFS ?
thagrol
Sat Jun 19, 2021 11:11 am
Not in my experience. Been running NAS with samba and NFS exports on the same directories for years without problems.
Don't know about 7 & 8, I think 10 does on the Pro editions. There may well be thrid party drivers but I've neither looked for nor used them.
thagrol
Sat Jun 19, 2021 11:21 am
Your permissiosn problems are due to mounting as root and not setting local user, group, or permissions at mount time. CIFS doesn't support any of those. They're set at mount time and cannot be changed.
As mentioned above, from the client's POV everything will be owned by root with a group of root and only root will have write permission.
Try adding file_mode=777,dir_mode=777 to your mount options. It's insecure but should help.
[ext]
   browseable=Yes
   writeable=Yes
   read only = no
   only guest=no
   create mask=0777
   directory mask=0777
   public=yes
   guest ok = yes
You've some synonymns in there but looks fine.
Create mask and directory mask only affect files on the server not how the client sees them.
You only need one of writeable and read only
Likewise public and guest ok
editied for tpyos
npaisnel
Sat Jun 19, 2021 11:30 am
For the times I'll need to do it...once a month or less..jsut to create an image of the attic server machines...jsut for SD card failure security I ti probably a whole new can of worms that I can leave firmly closed.
I have two Pi's in the attic, one for an RSP1a SDR Receiver and another running HA-Bridge - Heyu and a CM11 power line controller for X-10 home control integration with Alexa.
I just want to do the odd monthly or so image..2-3 gb images of headless desktop free systems jus tin case of failure.
I've got me sets of instructional notes to set it all up , so it is all workmen well.
just done and image-backup using the image backup utilities and it worked. fine.
Maybe once i get the HomeVision server up and running and retire the CM11-Heyu HA-Bridge set up in favour of the TW-523_HomeVision hardware -HVXL and HA_Bridge setp..I coudl look at that..bu too now ..enough on my plate..and this has just worked.. :)
npaisnel
Sat Jun 19, 2021 12:51 pm
[ext]
   browseable=Yes
   writeable=Yes
   read only = no
   only guest=no
   create mask=0777
   directory mask=0777
   public=yes
   guest ok = yes
editied for tpyos
It is just the same copy and paste share definition I have been using since I got a pi, in 2018, instructions taken from some tutorial or other.
Change the mount path, name and description and that is it
thagrol
Sat Jun 19, 2021 3:55 pm
Fair enough. I guess the source you copied it from wasn't aware of those points either.
