PiCake
[solved] Pi4 not booting newer kernel getting strange warning
Tue Sep 28, 2021 5:32 pm
Hi all,
Today I installed my Rpi 4 with the Lite image. Updated it and is fine.
After updating I was installing some apps with apt and then I got this message:
Newer kernel available
The currently running kernel version is 5.10.60-v7l+ which is not the expected kernel version 5.10.60-v8+.
Restarting the system to load the new kernel will not be handled automatically, so you should consider rebooting.
It only is booting with 5.10.60-v7l+ after rebooting a couple of times, not with the newer 5.10.60-v8l+.
ls -l /boot |grep kernel
-rwxr-xr-x 1 root root 6354920 Sep 28 17:52 kernel7.img
-rwxr-xr-x 1 root root 6780016 Sep 28 17:52 kernel7l.img
-rwxr-xr-x 1 root root 7906735 Sep 28 17:52 kernel8.img
-rwxr-xr-x 1 root root 6006192 Sep 28 17:52 kernel.img
It's booting the older:
Linux myhost.local 5.10.63-v7l+ #1457 SMP Tue Sep 28 11:26:14 BST 2021 armv7l GNU/Linux.
Have been using Pi's for years and always the kernels get updated just fine via apt and after reboot it loaded the new kernel without problem.
Did I break something?
// edit: fixed the format of my post, marked post as solved.
RonR
Re: Pi4 not booting newer kernel getting strange warning
Tue Sep 28, 2021 10:55 pm
It appears you ran 'rpi-update' instead of 'apt update && apt full-upgrade'.
'rpi-update' gets you the latest unreleased and possibly untested kernel that is generally not for public use:
Linux raspberrypi 5.10.63-v7l+ #1457 SMP Tue Sep 28 11:26:14 BST 2021 armv7l
The latest public release of Raspberry Pi OS from 'apt update && apt full-upgrade'.is:
Linux raspberrypi 5.10.60-v7l+ #1449 SMP Wed Aug 25 15:00:44 BST 2021 armv7l
You can get back to the latest public release of Raspberry Pi OS with:
apt update
apt --reinstall install raspberrypi-kernel raspberrypi-bootloader
Kernel versions ending in '-v7l+' are 32-bit versions (armv7l), while kernel versions ending in '-v8+' are 64-bit versions (aarch64).
Loading of 64-bit kernels is enabled by an 'arm_64bit=1' entry in /boot/config.txt.
trejan
Wed Sep 29, 2021 12:47 am
You've installed needrestart which prints those messages. It doesn't understand the Pi kernel naming scheme since it sees kernel8.img exists and thinks it is newer than kernel7l.img. You need to change a needrestart setting. The most likely reason why you've got needrestart is because you've installed Docker.
PiCake
Wed Sep 29, 2021 6:51 am
apt update
Hi Ron,
Thanks for helping me out. I followed your suggestions and hopefully I am back on the the latest public release.
Are there any benefits off running a 64-bit version on your Pi-4? I have the 4GB version of the Pi-4 .
PiCake
Wed Sep 29, 2021 6:55 am
Yes indeed I installed docker to experiment with containers and since then I got needrestart complaining to me about the other kernel.
Thanks for the link/help!
RonR
Wed Sep 29, 2021 8:00 am
The 64-bit version of Raspberry Pi OS is noticeably faster, and while still beta, is quite stable.
For true 64-bit support, you would need to start from scratch with a Raspberry Pi OS 64-bit image: Lite or Desktop
