hecsys
GDBus.Error:org.freedesktop.PolicyKit1
Sat Feb 14, 2015 6:24 am
I just got my Raspberry Pi 2 and after loading Raspbian every time I boot I get this error
GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed:
Cannot determine user of subject
I also having problem with my wireless N adapter... I can not connect to the internet with it.
Please I need help :)
Re: GDBus.Error:org.freedesktop.PolicyKit1
Sat Feb 14, 2015 6:04 pm
Ignore it, it's not important and will be fixed with a future update.
hecsys
Tue Feb 17, 2015 12:30 am
Thank you DougieLawson! :)
Buda
Fri Feb 20, 2015 8:34 am
open a Terminal, Type
lxsession-edit
to open Desktop Session Settings dialog box and uncheck LXPolKit. Click OK. then reboot.
hecsys
Fri Feb 20, 2015 3:26 pm
Thank you Buda, I will try this and let you know how it goes.
Tentbat
Mon Feb 23, 2015 12:26 am
Buda wrote:open a Terminal, Type
lxsession-edit
This worked like a charm! Thanks. It solved a frustrating problem that, while it had no functional implications, did manage to eat up a lot of time with solutions that didn't work.
Does unchecking LXPolKit have any consequence? Is there value in reinstating it at a later point (after an update) or was it supposed to be off?
Thanks again,
Bret
hobbsy
Thu Feb 26, 2015 2:42 pm
Hi, just got my RPi2 and installed Raspbian. I also got the same pop-up error on entering the desktop but it seems "lxsession-edit" and unticking the "LXPolKit" box makes the error go away. Thanks.
hecsys
Fri Feb 27, 2015 3:29 am
It works!!!! awesome! thank you guys :D :D
Thehamburglar01
Fri Mar 06, 2015 7:33 pm
Typing the command and unchecking the box worked for me as well. I hadn't noticed the error prior to setting TightVNCServer to start automatically on boot.
MrTreeHugger
Sun Aug 27, 2017 12:12 pm
lxsession-edit
Hello, I've got the same problem when connecting via remote desktop. When I type lxsession-edit I don't have the option LXPolKit... Is there anything else to do?
