Sebastian
Reboot fails w/ Gembird SilverShield USB power strip attache
Tue Jul 17, 2012 5:12 pm
I plan to use my raspy to control a Gembird SilverShield USB attached power strip. It allows to turn on/off 4 seperate power outlets via USB control. The Linux application sispmctl works well so far on my HP PC w/ SuSE 11.4. Also it works on RPi. But when the RPi reboots, it frequently hangs when coming up again. The error messages on the console are hardly readable as they get spilled out way to fast to read. Only way to get it running again is power off/ power on. Cold boots seem to work reliable though.
I have ried to attached the Gembird via a powered USB hub too, to exclude power comsumption issues, but symptoms stay the same.
Q: Is this known? I have seen another post where the Gembird power strip was proposed.
Q: I can't find a logfile with the error messages after cold start, nothing in messages or dmesg.*. Any idea?
adam van gaalen
Re: Reboot fails w/ Gembird SilverShield USB power strip att
Mon Aug 27, 2012 12:14 pm
I have 5 Gembird Silvershield's, now connected to a Mac Mini. I have some AppleScript-stuff, bought from the internet, running to be able to control the powerstrips from within my home-made shell-scripts. The Apple-Script interface-software however contains some shortcomings/bugs and is never being updated. Email to the supplier results in no replies at all... Therefore it would be great to be able to control them through the Pi.
Some time next week I will try to find the sispmctl-software you mentioned and will try to do some testing with it on my Pi. Will keep you updated...
adam van gaalen
Sun Sep 23, 2012 6:45 pm
Alas, same problems as mentioned on top. Hangs during boot, hangs while trying to access the Gembird ports. Somebody, HELP please!
szahran
Thu Mar 21, 2013 11:21 am
I'm facing the same problem as well, it simply hangs after one or two commands. And I'm connecting it to a high speed USB hub which powered separately. Anyone could find a solution?
obcd
Thu Mar 21, 2013 9:32 pm
What kernel are you using? uname -a should show you that.
What is lsusb telling you about the power strip when it's connected?
adam van gaalen
Thu Mar 21, 2013 11:38 pm
uname -a gives:
Linux blackberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux
lsusb gives the correct info but when accessing the device (either directly or though a US 1.0/2.0/3.0 hub) the system is hung after just a few attempts.
szahran
Mon Mar 25, 2013 10:28 am
uname -a
Linux raspberrypi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv61 GNU/Linux
lsusb
Bus 001 Device 004: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub
Bus 001 Device 005: ID 04b4:fd13 Cypress Semiconductor Corp.
Bus 001 Device 006: ID 046d:c31d Logitech, Inc.
Bus 001 Device 007: ID 046d:c00e Logitech, Inc. M-BJ58/M-BJ69 Optical Wheel Mouse
adam van gaalen
Tue Sep 03, 2013 8:52 pm
it works fine when using the latest kernel! I'm happy!
