I'm a beginner with the raspberry pi 2 B and I also got a Edimax EW-7811UTC wifi adapter, running raspberrypi 3.18.11-v7+ #781 Raspbian, however no matter how much I look on the forums, I just can't get it to work. lsusb detects the device but I don't have the driver installed for it. How can I install the driver and get it working? Any help appreciated!
Re: Edimax EW-7811UTC Help
What do you get from the command:
In the module column on the left you should see "8192cu" listed.
Then try:You should see something like " [ 9.465104] usbcore: registered new interface driver rtl8192cu
lsmod
Then try:
dmesg |grep 8192cu
Try this to install the driverAfter installing reboot and then configure you wifi to connect to your network.
MrEngman
wget https://dl.dropboxusercontent.com/u/80256631/8812au-3.18.11-v7-781.tar.gz
tar xzf 8812au-3.18.11-v7-781.tar.gz
./install.sh
MrEngman
That wifi module does not use the 8192cu driver so he will not see anything about the 8192cu using dmesg.JimmyN wrote:What do you get from the command:In the module column on the left you should see "8192cu" listed.Code: Select all
lsmod
Then try:You should see something like " [ 9.465104] usbcore: registered new interface driver rtl8192cuCode: Select all
dmesg |grep 8192cu
MrEngman
That's interesting, as that's what all my Edimax EW7811 [Realtek RTL8188CUS] adapters use.MrEngman wrote: That wifi module does not use the 8192cu driver so he will not see anything about the 8192cu using dmesg.
MrEngman
lsusb
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 005: ID 1997:2433
Bus 001 Device 006: ID 13fe:5200 Kingston Technology Company Inc.
lsmod
Module Size Used by
ecb 2279 0
md4 3587 0
md5 2045 1
hmac 3067 1
cpufreq_stats 4433 0
nls_utf8 1443 1
cifs 310275 2
i2c_dev 6709 2
snd_bcm2835 21149 3
snd_pcm 90778 1 snd_bcm2835
snd_seq 61097 0
snd_seq_device 7209 1 snd_seq
snd_timer 23007 2 snd_pcm,snd_seq
snd 66325 11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
sg 21859 0
evdev 11000 4
joydev 9766 0
i2c_bcm2708 6200 0
8192cu 569561 0
uio_pdrv_genirq 3666 0
uio 9897 1 uio_pdrv_genirq
dmesg |grep 8192cu
We are talking about two different wifi adapters.JimmyN wrote:That's interesting, as that's what all my Edimax EW7811 adapters use.MrEngman wrote: That wifi module does not use the 8192cu driver so he will not see anything about the 8192cu using dmesg.
MrEngmanSo I should be using a different driver? The 8192cu has always worked fine for me and it's included in Raspbian.Code: Select all
lsusb Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS] Bus 001 Device 005: ID 1997:2433 Bus 001 Device 006: ID 13fe:5200 Kingston Technology Company Inc. lsmod Module Size Used by ecb 2279 0 md4 3587 0 md5 2045 1 hmac 3067 1 cpufreq_stats 4433 0 nls_utf8 1443 1 cifs 310275 2 i2c_dev 6709 2 snd_bcm2835 21149 3 snd_pcm 90778 1 snd_bcm2835 snd_seq 61097 0 snd_seq_device 7209 1 snd_seq snd_timer 23007 2 snd_pcm,snd_seq snd 66325 11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device sg 21859 0 evdev 11000 4 joydev 9766 0 i2c_bcm2708 6200 0 8192cu 569561 0 uio_pdrv_genirq 3666 0 uio 9897 1 uio_pdrv_genirq dmesg |grep 8192cu [ 9.465104] usbcore: registered new interface driver rtl8192cu
Your wifi is an Edimax EW-7811Un and yes it uses the 8192cu driver. The wifi the OP is using is an Edimax EW-7811UTC and uses the 8812au/8821au driver, not the 8192cu driver.
MrEngman
OK, thanks for the clarification and correction.
I successfully got the driver installed and (after a bit of tinkering with the wpa_supplicant file) got wifi!MrEngman wrote:Try this to install the driverAfter installing reboot and then configure you wifi to connect to your network.Code: Select all
wget https://dl.dropboxusercontent.com/u/80256631/8812au-3.18.11-v7-781.tar.gz tar xzf 8812au-3.18.11-v7-781.tar.gz ./install.sh
MrEngman
