Can't Get VNCServer to Autostart
Morning all,
Issue 1126 of MIcro Mart featured an excellent Raspberry Pi Starters Guide, written by David Hayward.
The guide explained how to set up your CF card, how to get the GUI to autostart, and also how to get VNCServer to start a session once the GUI had loaded.
Last night I installed Raspbian, and hoped to get VNCServer up and running upon boot again.
The simple way David Hayward got VNCServer up and running wasn't the most elegant method, and in fact, stopped the GUI from loading on the Pi (the GUI was still available if you remotely logged in ), so I decided to use this guide and try to get it running that way:
http://elinux.org/RPi_VNC_Server
I've gone through everything up to the line where it reads "Reboot your Raspberry PI and you should find a vncserver already started." However, when I reboot I'm unable to log on via my Mac.
If I open up a terminal window on the Pi and simply type vncserver (without the :1 and the geometry settings), the Mac's able to connect without an issue. The window I type this in on the Pi also tells me it's session 1, so I can only assume the script to automatically kick the session off isn't working.
I've tried the script with and without the session number and geometry settings, but neither method seems to work.
Are the instructions at elinux.org not applicable to Raspbian, or, as I suspect, could I be doing something wrong?
Any help would be appreciated, as at present the only screen in the house with an HDMI port is the main TV in the house, and I don't think the fiancee would be too impressed with me using that for hours when she wants to watch some rubbish on there.
Thanks for reading!
Thanks for reading!
Re: Can't Get VNCServer to Autostart
I believe these are the instructions I tried with Wheezy beta and they didn't work for me either. As a workaround I am logging into the pi using putty and starting the vncserver manually.
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
Afternoon!
Thank you so much to the both of you for your help.
Thanks to you both I'm now back up and tinkering with my Pi via VNC.
You've made me very happy.
Have a great weekend!
Hey!
I came across this while searching on how to get VNCServer to autostart as well and I've figured it out by following a mixture from the elinux wiki and penguintutor.com as neither were correct for Raspbian.
To get it to autorun, create a file in /etc/init.d call it whatever you want, for this purpose i'll call mine tightvncserver
When the editor comes up, enter the following code
Once thats saved, edit the permissions to make it executable
Then add it to the startup scripts
Reboot your pi and the VNC server should load on boot.
As I said above, a lot of it is copy and pasting from both sites to make it work fully under raspbian. This isn't my own work, just a fix to get it working. Hope this helps people
sudo nano /etc/init.d/tightvncserver
### BEGIN INIT INFO
# Provides: tightvncserver
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start VNC Server at boot time
# Description: Start VNC Server at boot time.
### END INIT INFO
#!/bin/sh
# /etc/init.d/tightvncserver
# Set the VNCUSER variable to the name of the user to start tightvncserver under
VNCUSER='pi'
case "$1" in
start)
su $VNCUSER -c '/usr/bin/tightvncserver :1'
echo "Starting TightVNC server for $VNCUSER "
stop)
pkill Xtightvnc
echo "Tightvncserver stopped"
echo "Usage: /etc/init.d/tightvncserver {start|stop}"
exit 1
esac
exit 0
sudo chmod 755 /etc/init.d/tightvncserver
update-rc.d tightvncserver defaults
I come from the "Fedora" Linux world which uses a slightly different format for the startup scripts, and I haven't had the time to figure out what was wrong with all these examples. So, thanks for getting it working. I am going to give it a try on Wheezy Beta.EJ22 wrote:Hey!
It did not work for me.EJ22 wrote:Hey!
1. First, when I ran "update-rc.d tightvncserver defaults" there were quite a few warnings, although the “tightvncserver” and “Xtightvnc” services are both running when viewed with a “ps -aux” command:
update-rc.d: using dependency based boot sequencing
update-rc.d: warning: tightvncserver start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (2 3 4 5)
update-rc.d: warning: tightvncserver stop runlevel arguments (0 1 6) do not match LSB Default-Stop values (0 1 6)
insserv: Script tightvncserver is broken: incomplete LSB comment.
insserv: missing valid name for `Provides:' please add.
2. Secondly, when I try to vnc into the pi from my Windows computer I get the following error:
"No connection could be made because the target machine actively refused it".
I double checked that it still works when manually starting the vncserver with "/usr/bin/vncserver" and it still works properly, so I reverted back to the old manual method.
alexeames posted a working version here. I am now up and running:
by alexeames » 25 Jul 2012 02:20
Stewart Watkiss shows you how to do what the OP wants right here. I've tried it on Wheezy beta and Raspbian and it works an absolute treat...
http://www.penguintutor.com/linux/tightvnc
Video to prove it of me playing Chuckie Egg on spectrum emulator through tightvnc
http://raspi.tv/2012/install-and-use-ti ... oid-or-ios
i removed the bash info because that was giving me errors for impropeer `Provides:' .. but now if i do
sudo update-rc.d tightvncserver defaults
i get this:
insserv: warning: script 'K01tightvncserver' missing LSB tags and overrides
insserv: warning: script 'tightvncserver' missing LSB tags and overrides
when i run: sudo /etc/init.d/tightvncserver start
i get:
/etc/init.d/tightvncserver: 6: /etc/init.d/tightvncserver: Syntax error: word unexpected (expecting ")")
i don't know what the syntax error is as i am unfamilliar with this. it was co;py and pasted...
i get this:
i get:
I have updated the "vncboot" script on the http://elinux.org/RPi_VNC_Server page to enable copy/pasting it.
The cause of the "insserv: missing valid name for `Provides:' please add." error was the multiple spaces between "# Provides:" and "vncboot". I replaced them with single spaces and now it works flawlessly.
Many thanks for the hint! Removing blank spaces make the command:Splitlocked wrote:I have updated the "vncboot" script on the http://elinux.org/RPi_VNC_Server page to enable copy/pasting it.
### BEGIN INIT INFO
# Provides: vncserver
### END INIT INFO
#!/bin/sh
# Set the VNCUSER variable to the name of the user to start vncserver under
VNCUSER='pi'
case "$1" in
start)
echo "Starting VNC server for $VNCUSER "
su $VNCUSER -c '/usr/bin/vncserver :1 -geometry 1920x1080 -depth 24'
stop)
echo "Stopping VNC server"
/usr/bin/vncserver -kill :1
exit 1
esac
exit 0
I tried your code, still on adding it to defaults I got LSB errors! What worked for myself was getting the files with
After, I edited the file where necessary, wit terminals nano or a GUI
1. Change to username between the quotes if you have a different username.
2. Add visual settings by adding the text after :1.
The rest is the same, just make it executable and add the script to defaults.
Tested on Soft-float Debian “wheezy”
wget http://www.penguintutor.com/otherfiles/tightvncserver-init.txt
sudo mv tightvncserver-init.txt /etc/init.d/tightvncserver
export USER='pi'
su $USER -c '/usr/bin/tightvncserver :1 -geometry 1920x1080 -depth 24 '
hey guys
i got a problem
i want to autostart the vncserver so i follow the instructions and i have the script,
i can read it by sudo nano /ect/init.d/tightvncserver
but i cant move it or do anything because it says "no such file or directory" "or cannot access no story"
please help me
i got a problem
please help me
pjc123 wrote:alexeames posted a working version here. I am now up and running:
Alex, Steve, Many thanks for this. Of all the advice in posts that has been tried, this is the only one that has worked.
Excellent stuff Steve and Alex.
Robin
I have followed your suggestion but I don't know if it works correctly. In short, after the download of tightvncserver, I created this file:
then I pasted the script that I took here:
http://www.penguintutor.com/otherfiles/ ... r-init.txt
where I have removed ALL the spaces.
then I have executed:
Finally, I have done:
but I have these warning:
Is it normal, or I should resolve this, too?
Thank you very much!!
#!/bin/sh
### BEGIN INIT INFO
# Required-Start: $local_fs
# Required-Stop: $local_fs
# Short-Description: Start/stop tightvncserver
### END INIT INFO
# More details see:
# http://www.penguintutor.com/linux/tightvnc
### Customize this entry
# Set the USER variable to the name of the user to start tightvncserver under
export USER='pi'
### End customization required
eval cd ~$USER
case "$1" in
start)
su $USER -c '/usr/bin/tightvncserver :1 -geometry 1440x900 -depth 24'
echo "Starting TightVNC server for $USER "
stop)
pkill Xtightvnc
exit 1
esac
exit 0
I found this document
http://help.directadmin.com/item.php?id=379
where is explained that it's just a warning. Today I will try to remove the:
bye!
because it's the only difference with the example of the script on the link.#!/bin/sh
bye!
Thanks for that, although it explains why a bit, their solution is to remove the program!crystal13 wrote:I found this document
where is explained that it's just a warning. Today I will try to remove the:because it's the only difference with the example of the script on the link.#!/bin/sh
Not exactly running with the idea of programming/tinkering! More a case of if a light on your dashboard comes on, put some sticky tape over it so you can't see it!
The directions did not exactly work for me. I got this message when I tried to run "update-rc.d vncboot defaults"
unable to read /etc/init.d//etc/init.d
After changing the script to the following, my rc update was sucessful.
root@raspberrypi:/etc/init.d# update-rc.d vncboot defaults
I wanted to keep it as close to the original directions as possible so I used a mixture of the script from the first guy on this page and the original from here.
https://www.raspberrypi.org/documentati ... ccess/vnc/
I liked using a variable for the username, even though not necessary. I left that from the guy on this page, but I did export it. I used the original /usr/bin/vncserver instead of /usr/bin/tightvncserver from the script on this page.
This worked for me:
1. I set it all up from this https://www.raspberrypi.org/documentati ... ccess/vnc/
2. I could not use port 0 because that was taken, so I also changed the port to :1.
3. Changed the /etc/init.d/vncboot script to this:
This worked for me:
#! /bin/sh
## /etc/init.d/vncboot
### BEGIN INIT INFO
# Script: vncboot
### END INIT INFO
## Original Script /etc/init.d/tightvncserver
VNCUSER='pi'
export VNCUSER
case "$1" in
start)
su $VNCUSER -c '/usr/bin/vncserver :1'
stop)
echo "vncserver stopped"
echo "Usage: /etc/init.d/vncboot {start|stop}"
exit 1
esac
exit 0
This code should replace the code I posted before.
#! /bin/sh
### BEGIN INIT INFO
# Script: vncboot
### END INIT INFO
VNCUSER='pi'
export VNCUSER
case "$1" in
start)
# su $VNCUSER -c '/usr/bin/vncserver :1'
su - $VNCUSER -c "/usr/bin/vncserver :1 -geometry 1280x800 -depth 16 -pixelformat rgb565"
stop)
su - $VNCUSER -c '/usr/bin/vncserver -kill :1'
exit 1
esac
exit 0
THANK YOU!! At last! I have managed to get the vnc to auto start thanks to jarymokin. I am going to change his code just a little as I want the screen size to fit my monitor which is 1920x1080, and the colour depth to 24 so the code I will change will be
su $VNCUSER -c '/usr/bin/vncserver :1 -geometry 1024x1080 -depth 24'
