Ben_der
HDMI 21:9 Screen
Sat Sep 05, 2015 8:21 am
Hello everybody!
actually i have an Issue with a 21:9 Screen (LG 25UW55B).
I Want the Screen to be 2560x1080 60 7 0 0 1
I Wrote the following to the confix.txt
disable_overscan=1
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
hdmi_cvt=2560 1080 60 7 0 0 1
7 is for Aspect ratio 21:9.
According to this Post it should be Possible:
https://www.reddit.com/r/raspberry_pi/c ... pberry_pi/
Even after reboot the system still remains in Mode 58 (1680x1056)
the System should be capable of doing this :
hdmi_mode=76   2560x1600       reduced blanking
hdmi_mode=77   2560x1600 60Hz
hdmi_mode=78   2560x1600 75Hz
hdmi_mode=79   2560x1600 85Hz
hdmi_mode=80   2560x1600 120Hz reduced blanking
What am i doing wrong??
Thanks for Help!
Ben_der
Solved: HDMI 21:9 Screen
Mon Sep 07, 2015 6:55 am
Hi there !
Issue is closed.
Board is not capable of higher Modes then 1920x1080@60.
Overclock of PixelPipeline necessary;Unsupported.
RaTTuS
Re: HDMI 21:9 Screen
Mon Sep 07, 2015 7:51 am
I believe you can get higher resolutions.
I know 4k displays have been done [with some limitation ]
Covfefe
Ben_der
Tue Sep 08, 2015 2:31 pm
Will try this
hdmi_ignore_cec_init=1
hdmi_drive=2
disable_overscan=1
hdmi_group=2
hdmi_mode=87
hdmi_timings=2560 1 64 64 96 1080 1 3 10 31 0 0 1 60 0 185580000 8
max_framebuffer_width=2560
max_framebuffer_height=1280
framebuffer_height=1080
gpu_mem=128
arm_freq=800
gpu_freq=275
sdram_freq=500
hdmi_pixel_freq_limit=400000000
avoid_pwm_pll=1
