NOsen
Jessie lite apt-get issues
Wed Jan 13, 2016 7:59 pm
I cant install any pkgs at all i get this error over and over
i tested on 2 brand new RPI2 and i tested 3 diffrent NEW memory cards
anyhow this is the "error" i get
sudo apt-get install vim
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libgpm2 vim-runtime
Suggested packages:
  gpm ctags vim-doc vim-scripts
The following NEW packages will be installed:
  libgpm2 vim vim-runtime
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,892 kB of archives.
After this operation, 28.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgpm2 armhf 1.20.4-6.1 [35.1 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-runtime all 2:7.4.488-7 [5,047 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim armhf 2:7.4.488-7 [809 kB]
Fetched 5,892 kB in 1min 25s (68.6 kB/s)
Unquoted string "of" may clash with future reserved word at /usr/share/perl/5.20/Carp.pm line 3.
debconf: Perl may be unconfigured (syntax error at /usr/share/perl/5.20/Carp.pm line 3, near "of
# inheritance are less efficient.
sub trusts "
syntax error at /usr/share/perl/5.20/Carp.pm line 20, near "}"
BEGIN not safe after errors--compilation aborted at /usr/share/perl/5.20/Carp.pm line 25.
Compilation failed in require at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/Handle.pm line 6.
BEGIN failed--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/Handle.pm line 6.
Compilation failed in require at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/File.pm line 11.
BEGIN failed--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/File.pm line 11.
Compilation failed in require at /usr/share/perl/5.20/FileHandle.pm line 9.
Compilation failed in require at (eval 1) line 3.
BEGIN failed--compilation aborted at (eval 1) line 3.
) -- aborting
Selecting previously unselected package libgpm2:armhf.
dpkg: unrecoverable fatal error, aborting:
 files list file for package `sudo' contains empty filename
E: Sub-process /usr/bin/dpkg returned an error code (2)
any ideas?
ShiftPlusOne
Re: Jessie lite apt-get issues
Wed Jan 13, 2016 8:03 pm
What does 'df -h' say?
NOsen
Wed Jan 13, 2016 8:07 pm
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 15G 885M 13G 7% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6.2M 457M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p1 60M 20M 41M 34% /boot
jackokring
Wed Jan 13, 2016 8:12 pm
looks like the output is due to the 'vim' package, having a bad script in. (This is an educated guess). Did you update and upgrade first?
NOsen
Wed Jan 13, 2016 8:16 pm
yes update and upgrade works but after that all apt-get fails
like this trying to install alpine
 sudo apt-get install alpine
  alpine-doc mlock
Suggested packages:
  aspell mail-transport-agent exim4
  alpine alpine-doc mlock
Need to get 1,871 kB of archives.
After this operation, 7,239 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main mlock armhf 8:2007f~dfsg-4 [33.0 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main alpine armhf 2.11+dfsg1-3 [1,488 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main alpine-doc all 2.11+dfsg1-3 [350 kB]
Fetched 1,871 kB in 39s (47.0 kB/s)
sub trusts "
) -- aborting
Selecting previously unselected package mlock.
Wed Jan 13, 2016 8:22 pm
That looks like file system corruption of some sort.
Were the SD cards all the same type, or were they different?
ShiftPlusOne
Wed Jan 13, 2016 8:26 pm
Very strange. I've just installed vim without any problems, but that doesn't really help you.
Any overclocking or fancy kernels (rpi-update?)... anything else that might be of interest in config.txt?
Are all the sd cards you've tried from the same source or the same brand?
jackokring
Wed Jan 13, 2016 8:39 pm
The beginning of the file Carp.pm of the initial error is as follows, and a search shows 'of' is not used outside comments on my local debian linux box.
package Carp;
{ use 5.006; }
use strict;
use warnings;
BEGIN {
    # Very old versions of warnings.pm load Carp.  This can go wrong due
    # to the circular dependency.  If warnings is invoked before Carp,
    # then warnings starts by loading Carp, then Carp (above) tries to
    # invoke warnings, and gets nothing because warnings is in the process
    # of loading and hasn't defined its import method yet.  If we were
    # only turning on warnings ("use warnings" above) this wouldn't be too
    # bad, because Carp would just gets the state of the -w switch and so
    # might not get some warnings that it wanted.  The real problem is
    # that we then want to turn off Unicode warnings, but "no warnings
    # 'utf8'" won't be effective if we're in this circular-dependency
    # situation.  So, if warnings.pm is an affected version, we turn
    # off all warnings ourselves by directly setting ${^WARNING_BITS}.
    # On unaffected versions, we turn off just Unicode warnings, via
    # the proper API.
    if(!defined($warnings::VERSION) || eval($warnings::VERSION) < 1.06) {
	${^WARNING_BITS} = "";
    } else {
	"warnings"->unimport("utf8");
NOsen
Wed Jan 13, 2016 8:41 pm
Well the wierd part is as long as i do not run apt-get upgrade i can install any pkg w/o any errors
after i run apt-get upgrade no more so i really dont understand why the upgrade would corupt my filesystem?
jackokring
Wed Jan 13, 2016 8:55 pm
So assuming an update without an upgrade will leave you able, (very likely, although depends if distribution servers change), then the upgrade must be upgrading apt-get, perl or a dependency. is it possible to say n to the upgrade, but print the list of packages it wants to upgrade?
Either that or some other computational or logical failure has occurred.
NOsen
Thu Jan 14, 2016 1:33 pm
Well i have no idea on the ods but i sure wish i would had played a few bucks on it... i got 2 broken RPI2...
i tested the none working sdcards in a rpi2 i have had running for awhile and there is no issues there at all.
NOsen
Fri Jan 15, 2016 4:49 pm
Scratch the above...
i went to the store today picked up yet another new RPI2 and a sdcard
Exakt same error on this one !
So i did a test run with wheezy and it all works there.... it has to be a bad perl-package on Jessie lite distro couse its after the perl gets updated it all goes down the toilet.
sofixa
Fri Jun 10, 2016 11:27 am
Same problem here. A Raspberry Pi 3 B+ with an 16 GB Kingston Micro SD card, running Rasbpian Jessie installed with NOOBS v1.9.1.
Whenever i try to install something i get this:
root@raspberrypi:/home/pi# apt-get install vim
  vim-runtime
Suggested packages:
  vim vim-runtime
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,857 kB of archives.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-runtime all 2:7.4.488-7 [5,047 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim armhf 2:7.4.488-7 [809 kB]
Fetched 5,857 kB in 1s (3,669 kB/s)
sub trusts "
) -- aborting
 unknown user 'package' in statoverride file
(after running apt-get update && apt-get upgrade upon first boot)
After a quick Google search i stumbled upon this on the Debian bugs thingy, and it seems similar:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=77247
But i am not sure i understand this part, which is marked as the solution:
AFAIK, the only fix for this is disabling the perl alternatives mess,
which is already planned. I don't see that this is a debconf problem at
all; dependancies on perl-5.6-base should only be satisfied if perl
points to it; it is the current version of perl after all.
Funnily enough, in the same version of NOOBS, OSMC had a multitude of problems(upon first restart, systemd would fail miserably).
sofixa
Tue Jun 14, 2016 8:06 pm
Sooo anyone have any ideas? Unless i am running in a very specific case, Raspbian is basically unusable(an update screws it up).
Besides the Perl issues, i also had mtp fail, because libmtp-runtime is missing and my Pi won't boot; and i can't install it because apt-get doesn't work due to the bloody Perl issues.
I'll try to downgrade Perl and see if that helps.
Tue Jun 14, 2016 8:26 pm
sofixa wrote:Sooo anyone have any ideas? Unless i am running in a very specific case, Raspbian is basically unusable(an update screws it up).
It seems you are running in a very specific case (or you have some other problem, which is more likely), otherwise there would have been a great many other people complaining about upgrades messing up their systems.
Usually a situation like this is caused by a bad SD card (corruption, fake or broken).
wouterds
Fri Sep 16, 2016 7:25 pm
Any working fix?
I still have the same problem. Keeps occurring, even if I re-install the whole system on a different SD card.
I'm not sure when, it's starts happening after a random time.
About the following I did before it started to happen:
- clean install
- apt-get update
- apt-get dist-upgrade
- apt-get install git zsh screen
And that's about it. After that apt-get breaks and I can't install / remove anything anymore.
debconf: Perl may be unconfigured (Can't find string terminator '"' anywhere before EOF at /usr/share/perl/5.20/warnings.pm line 355.
Compilation failed in require at /usr/share/perl/5.20/Carp.pm line 5.
BEGIN failed--compilation aborted at /usr/share/perl/5.20/Carp.pm line 5.
Compilation failed in require at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/File.pm line 8.
BEGIN failed--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.20/IO/File.pm line 8.
) -- aborting
dpkg: error processing package debconf (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
wouterds
Fri Sep 16, 2016 8:46 pm
Third time did a clean install with the jessie lite image.
Finally configured everything and everything is up to date..
Trying to install `htop` and out of nowhere it's broken again.
➜  ~ sudo apt-get install htop
Suggested packages:
  ltrace
  htop
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 68.8 kB of archives.
After this operation, 135 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main htop armhf 1.0.3-1 [68.8 kB]
Fetched 68.8 kB in 0s (148 kB/s)
debconf: Perl may be unconfigured (FileHandle.pm did not return a true value at (eval 1) line 3.
) -- aborting
Selecting previously unselected package htop.
(Reading database ... 33265 files and directories currently installed.)
Preparing to unpack .../htop_1.0.3-1_armhf.deb ...
Unpacking htop (1.0.3-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up htop (1.0.3-1) ...
hal8000
Fri Sep 16, 2016 8:59 pm
Had the same problem on a fresh install of Jessie Lite on a Pi Model B (first version).
This is how I solved it. Comment out /etc/apt/sources.list with your favourite editor so it looks like:
#deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
You can use nano which is installed by default,
sudo nano /etc/apt/sources.list
Save the file and run apt-get update
sudo apt-get update
Ignore any error messages, now delete the comment so its back to normal
Save the file and run sudo apt-get update again.
Now try and install something, e.g.
