I picked up a 3.5inch Waveshare Screen for my Pi Zero and, by vaguely following this guide and working around the issues (in particular, rpi-update needs to be followed up by replacing some boot files, from pre-update backups, no idea why), I've got it basically working. Basically.
One issue is that the kernel modules don't load during startup. They're set up in /etc/modules as per the guide, should all be fine, but no go. 'systemctl status systemd-modules-load' gives:
systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static)
Active: failed (Result: exit-code) since Wed 2016-02-03 22:14:40 UTC; 1min 21s ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 1079 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 1079 (code=exited, status=1/FAILURE)
Feb 03 22:14:40 raspberrypi systemd-modules-load[1079]: Failed to find module 'flexfb regwidth=16 nobacklight init=-1,0xb0,0x0,-1,0x11,-2,250,-1,0x3A,0x55,-1,0xC2,0x44,-1,0xC5,0x00,0x00,0x00,0x00,-1,0xE0,0x0F,0x1F,0x1C,0x0C,0x0F,0x08,0x48,0x98,0x37,0x0A,0x13,0x04,0x11,0x0D,0x00,-1,0xE1,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0xE2,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0x36,0x28,-1,0x11,-1,0x29,-3 width=480 height=320'
Feb 03 22:14:40 raspberrypi systemd-modules-load[1079]: Failed to find module 'fbtft_device name=flexfb speed=16000000 gpios=reset:25,dc:24'
Feb 03 22:14:40 raspberrypi systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
Feb 03 22:14:40 raspberrypi systemd[1]: Failed to start Load Kernel Modules.
Feb 03 22:14:40 raspberrypi systemd[1]: Unit systemd-modules-load.service entered failed state.
sudo modprobe flexfb nobacklight regwidth=16 init=-1,0xb0,0x0,-1,0x11,-2,250,-1,0x3A,0x55,-1,0xC2,0x44,-1,0xC5,0x00,0x00,0x00,0x00,-1,0xE0,0x0F,0x1F,0x1C,0x0C,0x0F,0x08,0x48,0x98,0x37,0x0A,0x13,0x04,0x11,0x0D,0x00,-1,0xE1,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0xE2,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0x36,0x28,-1,0x11,-1,0x29,-3 width=480 height=320
sudo modprobe fbtft_device name=flexfb speed=16000000 gpios=reset:25,dc:24
I've had a look online, but every solution I can find for a systemd-modules-load failure is stop trying to load the modules that are failing (with the implication they don't exist and aren't needed), which isn't exactly helpful here; I'm not just trying to clear an error message, I need these to load. I can kludge it by setting the modprobe commands to run at each boot within init.d or something, but that doesn't seem proper. How do I track this down?
