nsayer
Pi 3 - no wifi or bt ?
Sat Mar 12, 2016 4:08 am
I had a Pi 2 and before moving the SD card to a new Pi 3, I did:
apt-get update
apt-get dist-upgrade
rpi-update
reboot
So far as I can tell, everything on the 3 looks as it should, but I don't see any evidence of the BT or Wifi.
Is there another step required to get them to show up?
ziddey
Re: Pi 3 - no wifi or bt ?
Sat Mar 12, 2016 4:17 am
Are you using dtoverlay=sdhost to overclock?
If so, change it to dtparam=sd_overclock=100
nsayer
Sat Mar 12, 2016 4:21 am
My config.txt has no dt lines in it at all.
# grep -v ^# config.txt
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=4
gpu_mem=64
max_usb_current=1
Douglas6
Try, from a command line:
hciconfig -a
That should tell you that the Bluetooth adapter is recognized and powered up.
nsayer
Sat Mar 12, 2016 4:30 am
I had to install bluez and bluez-hcidump, but having done that, hciconf -a prints nothing.
nsayer
Sat Mar 12, 2016 4:57 am
This post:
viewtopic.php?f=28&t=138137
has the solution. Two files are missing from /lib/firmware/brcm. I was able to fill in the missing files from
https://github.com/RPi-Distro/firmware-nonfree
At least, that made wlan0 show up. hciconfig -a still shows nothing.
nsayer
Sat Mar 12, 2016 7:58 am
I figured out BT.
I was unable to add pi-bluetooth, because wheezy doesn't have that package, but upgrading the whole system to jessie made it available. That pointed out that what was apparently missing was "bluez-firmware". Now hciconfig -a shows the local host adapter, and I can see some local BT devices with an hcitool scan.
sadsfae
Mon Mar 14, 2016 9:32 am
nsayer wrote:I figured out BT.
Anyone know where to obtain the firmware needed for bluetooth? Fedora doesn't have a "bluez-firmware" package. I've posted in another post here about it.
viewtopic.php?p=928431#p928431
I seem to have the same issue as nsayer with hcitool / hciconfig not showing anything.
Linux User #208453
http://hobo.house
