CannibalCorpse
Shell not working after sucessfully SSH external connection
Fri Apr 15, 2016 4:26 pm
In local network I can connect in the SSH normally.
The port used for ssh connection is already open on external network, and I acess the apache server's page from my pi on external network.
Finally on /var/log/auth.log I got this:
Apr 15 05:46:05 raspberrypi sshd[947]: Accepted password for xxxxx from xxx.xx.xx.x port 24029 ssh2
Apr 15 05:46:05 raspberrypi sshd[947]: pam_unix(sshd:session): session opened for user xxxxx by (uid=0)
But it looks like the terminal does not response after put the password, I can't do anything.
Somebody help?
dgordon42
Re: Shell not working after sucessfully SSH external connect
Fri Apr 15, 2016 8:21 pm
Are you trying to connect to a Pi 3 using it's built in WiFi?
If so, one possible solution is to add the line:
IPQoS cs0 cs0
to the end of the file:
/etc/ssh/sshd_config
and reboot.
For more information on this, have a look at this thread.
Hope this helps,
Dave.
CannibalCorpse
Fri Apr 15, 2016 8:41 pm
You killed my problem. That's exactly what I'm doing, Pi3 on WiFi built-in.
Arian
