didster
Pi3 UART and Bluetooth
Fri May 13, 2016 1:22 pm
I have an app that needs to make use of the PL011 UART connected to a modem. It also needs to make use of Bluetooth.
I have configured the Pi to use the pi3-miniuart-bt overlay to move Bluetooth to the mini-UART. I have updated hciattach.service to use /dev/ttyS0. I have removed the attachment to the console from cmdline.txt. I have set core_freq to a fixed value in config.txt. All that works fine, and I can mostly use both Bluetooth and the hardware uart OK.
But oddly, every now and then when I boot the mini-UART doesnt respond. hciattach returns timeout when run and nothing, other than rebooting, brings it back to life. This seems to happen 1 boot in every 5 or so. Once its up it seems to stay up OK.
Has anyone else had this? Thanks
Relevant files
/boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
/boot/config.txt
dtoverlay=pi3-miniuart-bt
enable_uart=1
core_freq=250
# I have also tried combinations of the below to lock core clock as docs seem to differ
#arm_freq=700
#arm_freq_min=700
#force_turbo=1
/lib/systemd/system/hciattach.service
[Unit]
ConditionPathIsDirectory=/proc/device-tree/soc/gpio@7e200000/bt_pins
Before=bluetooth.service
After=dev-ttyS0.device
[Service]
Type=forking
ExecStart=/usr/bin/hciattach /dev/ttyS0 bcm43xx 921600 noflow -
[Install]
WantedBy=multi-user.target
